Old 02-18-2007, 11:51 PM   #1
scorpio75
Member#: 100675
2014 Jeep
Grey
Default need help with ecutek easy ecu
This S%$T is pissing me off. I have been using my easy ecu for a while now and now it is acting up. I tried to use it and it was not reading the interface cable. I tried uninstalling it and installing it again but I keep getting the same error when I try to use delta dash. All the drivers are working correctly and the device manager does not show anything wrong. Could it be the cable or is it that I'm that computer iliterate??
Has anyone had the same problem?
scorpio75 is offline   Reply With Quote
Old 02-19-2007, 07:51 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
You should probably post in the Engine Management forum and include the EXACT error message you're getting
If you're using a USB interface the problem is often due to unplugging it without going through the 'Safely Remove Hardware' sequence. Did you re-boot after doing the reinstall?
UkNuck is offline   Reply With Quote
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
I need help with friend STi ecu ?? qtr_wrx Engine Management & Tuning 2 01-26-2007 06:20 PM
Ecutek Easy ECU race gas and pump gas tunes on Stage 1 STI - Dyno Flash Dyno Flash Proven Power Bragging 4 11-01-2006 10:09 PM
Re Post: Need help with RS-T ECU Code Malfuctions, and if TEC II will Solve it. yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 14 07-31-2001 05:17 PM
Need help with RS-T ECU Code Malfuctions, and if TEC II will Solve it. yebokmj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-31-2001 07:34 PM
