Welcome to the North American Subaru Impreza Owners Club Wednesday July 23, 2014
Old 02-19-2007, 12:56 PM   #1
pmbassist
Member#: 132691
1990 legacy L
Burgandy
Default Head bolt actual torques? Has anybody measured this?
Hello, I've done some searching but all i'm finding for head bolt torques are what the haynes manual gives you. I'm wondering if anyone has measured what the torque is when you "turn all bolts right 90*" and "turn all bolts right 90*" again. I've just replaced the head gaskets on my EJ22 (non-turbo) and it was leaking a little stream of oil on the driver's side front near the head gasket. I suspect I've torqued things down incorrectly, maybe too much. I don't want to have to pull everything apart again but there is very little space to work with and I'd rather just use my torque wrench for the final tightening. Thanks for the help!
pmbassist is offline   Reply With Quote
Old 02-19-2007, 03:53 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
The degree of final torquing is designed in. If you're leaking a little steam, I would suspect that one of the surfaces has some gasket material left over from the old gasket.
Jay Storm
Old 02-19-2007, 04:38 PM   #3
rocketman442
Member#: 135219
The degrees you turn the bolt is to stretch it. Head bolts in most modern engines are torque to yield(ones with crazy torque sequences and degrees) You probably botched it on the install and no amount of retorquing can save ya now. Probably gonna have to tear it down again.
rocketman442 is offline   Reply With Quote
Old 02-19-2007, 05:10 PM   #4
pmbassist
Member#: 132691
1990 legacy L
Burgandy
Crap! that's what I was afraid of. Thanks for the replies. I knew I should've gotten new bolts. Since i'm moving into an apartment looks like it'll have to sit for the next 6 months till I buy a house. Unless you know of any way I could make it work for ~10,000 miles. I'm considering a new motor at this point anyways, I think I've fuxored the block and heads. Too bad since the honing marks were still showing in the block.
Old 02-20-2007, 06:15 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
I wouldn't condemn anything until you find out exactly where the leaks are coming from. It's standard practice to re use Subaru headbolts, unlike other makes of motors that require new bolts at every service. That said, one of the bolts (upper right corner, iirc) goes into a coolant jacket and gets pretty corroded over time. If it's not clean and well oiled on assembly, the torque values will be off on the low side and can be contributing to the leaks. Other than that, if the job was done in the car...it's a PIA to get every last bit of gasket material off the block before putting the new stuff on....this will definately cause a bad seal.
Jay Storm
Old 02-20-2007, 06:37 PM   #6
pmbassist
Member#: 132691
1990 legacy L
Burgandy
Definitely agreeing with you on the extra head gasket material. I retorqued it last night and managed to make enough space to torque it properly. after a few seconds of idling, there was a small stream of oil coming from the front bottom headgasket area. I can tell from the sound of the engine the driver side rockers aren't getting anyoil. Since I don't have the time left for another full tear-down I'm going to see if I can do a temporary fix with some rtv gasket.
Old 02-21-2007, 07:37 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
I can almost guarantee it'll be a temporary fix. I would be very concerned about further problems from a lack of oil pressure.
If there's any way to make the time to get back in there...I would suggest to just do it and get it over with so nothing else goes wrong.
Jay Storm
Old 02-21-2007, 10:46 AM   #8
lmohaxx
Member#: 128205
97 Legacy GT
Not sure I am understanding what you're saying. You see a stream of oil coming from the headgasket area and last night you managed to torque the head bolts again? If you removed the timing belt and the camshafts to retorque the headbolts then why didn't you just remove the head?.. My assumption is you're talking about the valve cover leaking?.. Get new valve cover gaskets.
Anyone else agree with me?
lmohaxx is offline   Reply With Quote
Old 02-21-2007, 10:52 AM   #9
lmohaxx
Member#: 128205
97 Legacy GT
I'm sorry I was thinking about the 2.5L DOHC...
Old 02-21-2007, 11:40 AM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I suspect that you may have flipped the head gasket and it's on backwards. Pull it off again and check it.
Tim Sanderson is offline   Reply With Quote
Old 02-21-2007, 06:10 PM   #11
pmbassist
Member#: 132691
1990 legacy L
Burgandy
Thank you for the replies. The other night I simply loosened and retorqued the head bolts with everything else together. The head gasket will only go on one way, otherwise the channel in the upper front won't line up. The valve cover gaskets I did replace when I replaced the head gaskets. It's not a high-pressure stream that's leaking, more like when you cut yourself deep and it goes drip, drip drip. Unless anyone has had a really bad experience doing this i'm going to loosen the bolts this weekend, break the seal on the head gasket, pull it out maybe 5mm and apply rtv sealant to both sides of the head gasket. Retorque to factory specs and let it sit for 24 hours. It would be good if I could drive this for the next 6 months, but if it'll at least go the 50 miles to my new place I'll be satisfied.
Old 02-22-2007, 08:52 AM   #12
rocketman442
Member#: 135219
If its just leaking a lil bit, drive it to your new place and fix it there, If you do what you talking about you will be leaking coolant and oil and probably not have comppresion either. Fix it correctly then there wil be no worries.
Old 02-22-2007, 10:45 AM   #13
Hayes
Member#: 11808
Head bolts are NOT torqued to yield but, only stretched/distorted. If torqued to yield then the torque value will drop significantly and you will have leaks. You should be able to reuse bolts UNLESS over torqued to the yield point. So to be safe always use new bolts since we don't know their history. I think in this case you need to redo the job i.e. remove heads and check for cleaness on the mating surfaces, check gaskets, new head bolts and torqued in the recomended sequence & torque at each step in the recomended procedure. Sorry but, consider this a learning experience and you will be the expert giving advice next time. Ed
Hayes is offline   Reply With Quote
Old 02-22-2007, 12:35 PM   #14
pmbassist
Member#: 132691
1990 legacy L
Burgandy
Definitely a learning experience! The advantage is now it only takes 1/2 the time to tear down and build up because I'm more accustomed to the layout.
I'll be buying a house in 6 months, at that point I'll be able to put the engine on a stand and take care of this at my leisure. I think that'd be the best route. I'll replace everything at that point and do a full rebuild.
Old 02-22-2007, 12:42 PM   #15
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
I would not put anything between the block and the head other than the head gasket. Do not put RTV in there. It will space the head and block further apart and cause less of a seal and more problems.
There must be some old gasket or something keeping it from sealing completely.
I know you don't want to hear it but I really think RTV will make it worse.
Peace,
Greg
b4wantab is offline   Reply With Quote
heads bolt studs torque? eng4280 Built Motor Discussion 13 05-02-2010 10:11 PM
Official Head Bolt/Stud Torque Specs for Various Motors White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 20 06-17-2006 06:42 PM
has anybody seen this car yet? angus Member's Car Gallery 8 06-10-2002 11:56 AM
Has anybody seen this Body style ark101 Interior & Exterior Modification 26 09-08-2001 11:13 PM
has anybody played this PS1 game? jagcars26 General Forum Archive 6 11-14-2000 06:21 AM
