Old 02-19-2007, 01:04 PM   #1
NYCshopper
Member#: 5126
Default First Drive: 2007 Nissan Sentra SE-R and SE-R Spec V (Car & Driver)
http://www.caranddriver.com/previews...-r-spec-v.html
The latest SE-R is crisp and fun to drive, despite an upright stance and low-tech suspension design.
We’re going to come right out and say it: the new Nissan Sentra SE-R (above) does not recall the glory days of the original 1991-1994 SE-R. Actually, it’s unlikely that any Sentra SE-R will top the adulation for the initial version, given the positive taint that years of nostalgia have bestowed upon it. The first SE-R is a lot like your first kiss or your first batch of pancakes, both of which were probably sloppy and not as delicious as you now fondly remember. Since the first generation, the subsequent two generations were met with indifference and disappointment. So maybe the new, fourth-generation SE-R can’t top the original, but it’s vastly better than the previous model, at least when it comes to driving. As before, the hot Sentra comes in two versions: SE-R, and Spec V (next page). The SE-R comes only with a CVT, and the higher-output Spec V engine is mated to a six-speed manual.
Exterior and Interior
We’re still getting used to the upright looks of the Sentra, which shares a platform with the Renault Megane. The SE-R makes an effort to correct the awkward proportions with 17-inch wheels, aggressive front and rear fascias, and a rear spoiler. The effect is a subtle improvement, but it will never, ever be called pretty.
On the inside, there’s an oil pressure gauge and a g-meter to measure acceleration and deceleration. The rest of the interior is mostly unchanged from the Sentra, except for new front seats with red stitching and SE-R logos on the headrests; the Spec V gets the added flair of red seat belts. Despite the sporty looks of the front buckets, the side bolsters don’t do much to hold your upper body in place, and while the seat bottom accommodates cheeseburger-laden waistlines, skinnier posteriors will slide around during hard cornering. The Sentra SE-R has a 13-cubic-foot trunk and rear seats that can hold fully-grown adults. Front, front-side, and head curtain airbags are standard.
Engine and Transmission
Under the hood is the 2.5-liter QR25DE inline-four, which is also used in the Altima. In the SE-R, it makes 177 horsepower and 172 pound feet of torque. The Spec V has a higher compression ratio (10.5 versus 9.6), a 7000 rpm redline (up from 6200), and unique intake and exhaust manifolds, connecting rods, pistons, and camshafts to increase output to 200 hp and 180 lb-ft. The CVT in the SE-R works in automatic mode, or the driver can use steering-wheel-mounted shift paddles to operate in manumatic mode. SE-R engines will run on regular unleaded; the Spec V requires premium.
Chassis
Behind the 17-inch wheels are 11.7-inch front and 11.5 inch rear disc brakes in the SE-R; the Spec V upgrades to 12.6-inch rotors. ABS is standard, but the Sentra SE-R is one of the only sporty compacts extant that doesn’t offer stability control. In the SE-R, stiffer springs are the only other major chassis change from the base Sentra. The Spec V goes a step further with more aggressive summer tires, 0.4-inch lower springs, a larger 25mm front stabilizer bar, and extra bracing in the front and rear. The Spec V also offers an optional helical limited-slip front differential. Both cars retain the front strut and torsion-beam rear suspension setup. Despite being less sophisticated than an independent rear suspension, Nissan engineers claim the torsion beam gives the rear end enough stiffness without creating a harsh ride.
Driving Impressions
The engine starts (via an optional keyless system in the SE-R) and runs with remarkable smoothness—especially compared with the thrashy mill in the previous-generation SE-R. That smoothness continues all the way up to the 7000 rpm redline in the Spec V, and a soft rev limiter lets the engine sit exactly at the redline. The exhaust note is noticeable but not at all loud—most owners will probably look for an aftermarket exhaust. In manual mode, the SE-R effects gearshifts at its lower redline, whether the driver likes it or not. Nissan is optimistic about the CVT—the company sees the SE-R model as an alternative for customers who live in high-traffic areas where shifting is a pain. The manual mode is meant to bestow the automatic with some semblance of sportiness, and indeed it switches between the six pre-set ratios quickly and with almost zero delay. But unlike conventional automatics with a manumatic mode or dual-clutch manuals, the CVT keeps engine revs relatively constant, so ultimately you’ll get better engine response by leaving the transmission in automatic mode. The short-throw six speed in the Spec V is an improvement over the rubbery shift lever in the standard Sentra.
On the road, the Spec V accelerates with gusto, and the SE-R is similarly quick but feels like it’s lacking more than the 8 pound-feet of torque stated in the specifications. The Spec V engine works best above 4000 rpm, close to its 5200 rpm torque peak, and while it’s not nearly as asthmatic at low revs as the Honda Civic Si, it lacks low-end punch. Neither car feels as fast as more powerful competitors—or even the 200-hp turbocharged Volkswagen GTI. The upside is that the Spec V is usually rolling by the time significant torque kicks in, so torque steer is kept to a minimum. That alone makes the new SE-R better than its predecessor, but the new car has more to offer than that, like excellent balance. Upon entering a corner, the front end grips nicely and resists transitioning into understeer. Lift up on the throttle or jab the brakes and the back end will step out slightly—not a scary amount, but enough that the car can be positioned with the throttle. And speaking of the brakes, the bite is substantial and we noticed no fade. Unfortunately the steering, which is boosted electrically, is not quite as solid as the rest of the car. There’s a good feel for what’s going on with the car itself, but the road feel—what’s going on beneath the tires—is somewhat isolated.
The Verdict
The Sentra SE-R and SE-R Spec V aren’t quite as lively as the outgoing Mini Cooper S, but they hold their own compared with four-door sporty compacts. The Sentra SE-R Spec V edges the Honda Civic Si on turn-in, power, ride comfort, and overall livability. If the Sentra isn’t quite as refined as the Volkswagen GTI, it isn’t as expensive, either. Sure, the SE-R, even in Spec V trim, isn’t as extreme as the 263-hp Mazdaspeed 3, but the SE-R can still cover miles of curving back roads at high speeds and put a smile on its driver’s face. As a bargain pocket rocket, the new SE-R fits the mold cast by the original, albeit a larger, ungainly mold.
NYCshopper is offline   Reply With Quote
Old 02-19-2007, 01:05 PM   #2
NYCshopper
Member#: 5126
Old 02-19-2007, 01:05 PM   #3
NYCshopper
Member#: 5126
Old 02-19-2007, 01:07 PM   #4
melayout
Member#: 69316
2005 Legacy 2.5 GT
Black OBIS.blah.blah.DAN
The aborted fetus of a Maxima + Saturn Ion.
melayout is offline   Reply With Quote
Old 02-19-2007, 01:12 PM   #5
DJJ
Member#: 38244
2008 BMW 335i
I'm sorry but this re-designed Sentra is awful compared to what this segment of cars has to offer these days.
DJJ is offline   Reply With Quote
Old 02-19-2007, 01:13 PM   #6
roksax
Member#: 56126
2012 VW CC
If only they'd made it look more sporty. It reminds me of a saturn ion from the side. But the more competition in the sport compact segment the better!
roksax is offline   Reply With Quote
Old 02-19-2007, 01:31 PM   #7
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
What a joke. I would take an Si or a Cooper S any day over this POS.
Old 02-19-2007, 02:43 PM   #8
Len
Member#: 39937
2011 328i 6MT
LMB
Mazda keeps both of its small and midsize sedans sporty and fun.
Nissan decided to make one boring and the other sporty, and proceed to make the small one boring and the big one sporty. I don't get the logic.
Len is offline   Reply With Quote
Old 02-19-2007, 03:11 PM   #9
whoosh
Member#: 40989
OT vag inspector
reminds me of a toyota corolla S
whoosh is offline   Reply With Quote
Old 02-19-2007, 03:15 PM   #10
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
Wow, so lame. The old spec V and SE-Rs were 1000x better.
amukaoen is offline   Reply With Quote
Old 02-19-2007, 03:38 PM   #11
teh POD
Member#: 90195
non-turbo 4-bangers needing premium FTL!
teh POD is offline   Reply With Quote
Old 02-19-2007, 04:35 PM   #12
CapeRex
Member#: 81070
What a POS!!!!
Ugly,ill-proportioned,cheap looking.......the last SE-R was already bad enough.The name officially means nothing to me anymore.This just reinforces what I feel about Nissans of the past 6-7 years.....tacky as hell.The Altima SE-R is the only car in their line-up that does anything for me.
CapeRex is offline   Reply With Quote
Old 02-19-2007, 06:01 PM   #13
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
I love the G meter. I know that's going to make for some great conversation over on the Nissan forums. I can see the thread topic now, "Which springs will make me pull 1+ G on the meter?"
Yoo Shin is offline   Reply With Quote
Old 02-19-2007, 06:14 PM   #14
hhcchen
Member#: 35619
09 impreza 2.5i
i guess i am the only one think it looks good...
the side profile reminds me of the upcoming 2008 corolla...
overall... looks pretty nissanish... definitely a member of the nissan family...
i guess people don't like the humping huh...?
well... a sti wing... or even, the new gtr wing will take care of that...
hhcchen is offline   Reply With Quote
Old 02-19-2007, 06:56 PM   #15
sential
Member#: 105288
who was assigned to design this car? it's as bad as the aztek.
sential is offline   Reply With Quote
Old 02-19-2007, 07:11 PM   #16
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
i think it's ugly.
distorto is offline   Reply With Quote
Old 02-19-2007, 07:29 PM   #17
CapeRex
Member#: 81070
The world has truely gone topsy-turvy....I would rather drive a Chevy compact (Cobalt SS) over a Nissan Sentra.
Old 02-19-2007, 08:38 PM   #18
Len
Member#: 39937
2011 328i 6MT
LMB
I bet you were in Nissan's focus group.
Old 02-19-2007, 08:39 PM   #19
Dash_Martino
Member#: 78728
04 STi
that things goofy lookin
Dash_Martino is offline   Reply With Quote
Old 02-19-2007, 09:09 PM   #20
morektzdaddy
Member#: 135267
How un-inspiring. They have the new GT-R coming out and they give us this. What a damn shame.
morektzdaddy is offline   Reply With Quote
Old 02-19-2007, 09:37 PM   #21
roksax
Member#: 56126
2012 VW CC
I think it's the lights that are ruining its look. They should've made it somethin like this:
All I did was take off the top of the lights that extend above the hoodline. Almost looks like an older Audi S4
Old 02-19-2007, 11:51 PM   #22
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
It's just too bad that thing is fugly....
e11ys is offline   Reply With Quote
Old 02-20-2007, 09:26 AM   #23
Len
Member#: 39937
2011 328i 6MT
LMB
I refuse to believe that those are 17" rims. Look as big as 15" steelies.
Old 02-20-2007, 09:55 AM   #24
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
wow, i thought my 04 was worse than the 02-03's now even the 04 looks beautyful!!!
Still glad i traded it for the STI.
jnorth85 is offline   Reply With Quote
Old 02-20-2007, 11:52 AM   #25
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
They really need to put a edge on all SE-R versions. Forget about making them pleasant to all drivers. They were launched by offering a harder core version of the standard models
mhoward1 is offline   Reply With Quote
Full Test: 2007 Nissan Sentra SE-R Spec V (edmunds.com) NYCshopper Non-Subaru News & Rumors 31 10-11-2007 09:33 AM
First Drive: 2007 Nissan 350Z Nismo (edmunds.com) NYCshopper Non-Subaru News & Rumors 7 03-29-2007 12:59 AM
First Drive: 2007 Lamborghini Gallardo Superleggera (Car & Driver) NYCshopper Non-Subaru News & Rumors 7 03-26-2007 12:11 PM
First Drive: 2007 Chrysler 300C Touring AWD (Car & Driver) NYCshopper Non-Subaru News & Rumors 4 03-14-2007 08:45 PM
2007 Nissan Sentra SE-R Spec V pio!pio! Non-Subaru News & Rumors 56 12-06-2006 09:23 AM
