Old 12-03-2001, 01:13 PM   #1
RaceCarRiot
Member#: 6542
1997 Ver IV
Unhappy raspy ricey rattle coming from my prodrive exhaust...
ahh, alliteration is fun...
anyways, i stopped at the gas station yesterday, and heard this constant "tick" at idle coming from the back of my car, which seemed to be coming from the exhaust system...so i rev it a bit, and much to my horror, on top of it's usual roar, it made that horrible metallic chainsaw cutting into a tin can of ball bearings raspy rattle (you know, the kind cheap universal mufflers make).
so of course i was immediately panic stricken, but figured there was nothing i could do about it, and nothing looked like it was coming apart or anything, so i went on about my business and drove home.
start it up this morning, and it sounds fine...
soooooo, ummm...any ideas? could it be part of the cat breaking up, and blowing through the system?
Simon, i'm looking in your direction... don't get me wrong...i love the system, especially now that it's broken in, but i hope this racket doesn't surface again!
-adam-
RaceCarRiot is offline   Reply With Quote
Old 12-03-2001, 01:42 PM   #2
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Is the noise definitely coming from the exhaust or just from underneath the car? You might have some loose heat shields.
Jason
2.5GT is offline   Reply With Quote
Old 12-03-2001, 03:28 PM   #3
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Yup, probably the heat shield.
My friend's muffler on his Civic has the sound muffling packing come loose (at least that is what we both think) and his car has that rattle from inside the muffler everytime.
Since yours is gone, it probably is the heat shield.
Keiho is offline   Reply With Quote
Old 12-03-2001, 03:52 PM   #4
RaceCarRiot
Member#: 6542
1997 Ver IV
now why didn't i think of that??
especially considering it was after a little rally excursion...
silly, silly me...
Old 12-03-2001, 04:04 PM   #5
jeffg
Member#: 2958
2001 6.0?RS
unless the heat shield fell off I dont think it would just stop making noise over night. Unless you got some sort of magic self tightening bolts.
I have an STI exhuast and it makes that same sort of rattle. Mine only seem to do it when it is cold. This makes me think that mine is some sort of loose weld. The metal expands when it is hot and stops rattling.
Next time you notice it, try and see if it is coming from the muffler itself or some where near it.
Jeff
jeffg is offline   Reply With Quote
Old 12-03-2001, 04:51 PM   #6
RaceCarRiot
Member#: 6542
1997 Ver IV
nope this was doing it while it was HOT, no doubt about that...it's almost time to go home...we'll see what happens when i start it up... (crosses fingers)
Old 12-03-2001, 06:36 PM   #7
m750
Member#: 2278
8Sti | 07 allez
White | Comp
EXHAUST LEAK...
that is most likely what you've got. Do you have borla headers? they sound terribly loud w/ a crack or hole. Or... maybe at the flange where your prodrive meets your mid pipe has a leak. Check it.
AO
m750 is offline   Reply With Quote
Old 12-04-2001, 08:44 AM   #8
RaceCarRiot
Member#: 6542
1997 Ver IV
no borla headers, but there is a SMALL exhaust leak coming from the headers (i think)...and combine that with a little bit of heat shield vibration...
VzRzOzOzOzOzOzOzM!
Old 12-04-2001, 10:48 AM   #9
Siper2
Member#: 1134
2010 Legacy GT Ltd.
Default It probably IS the heat shield...
That noise is very reminiscent of heat shield problems I had with my Hondas ('88 Civic and '94 Integra). It happens to a lot of cars, but it's very common on Hondas. The solution is to reattach it with stronger brackets, or remove it altogether.
Now... it COULD be a hole in the exhaust, but my bet is still on the heat shield. It's not that the shield magically re-bolted itself. The noise only becomes prominent when the exhaust is nice and hot. So you likely WOULDN'T have noticed it first thing the next day.
-S2-
Siper2 is offline   Reply With Quote
Old 12-04-2001, 04:14 PM   #10
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Talking
i got $ to lay that it is definately the heat shield...
you probably got a little rock kicked up i there...
and it was rattling about...
ding.. tick.. ding... tick...
and fell out n that's why you dont hear it anymore...
or...
your heat shield is just slightly off key..
and is vibrating and rattling...
i pounded mine back into place
no more annoying rattle!
hehehe
either way, good luck
Jamie
www.subiegal.com
Old 12-04-2001, 04:22 PM   #11
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Woah, a whole day of posts and you still don't believe me
Subie Gal, add my money to your wager. . . let it ride
Back to the original idea which is your heat shields . . . I cut mine off completely. I just don't park over any dried leaves or grass
Jason
Rattling noise coming from my tranny... AM5562 Newbies & FAQs 5 03-19-2010 02:14 PM
Help: Loud rattle coming from High Flow Cat in my MRT header! Robmat Normally Aspirated Powertrain 4 10-25-2002 05:16 PM
I finally found where that rattle comes from! GooseMan Service & Maintenance 15 12-05-2001 04:35 PM
awful smell coming from my exhaust the spacecowboy Normally Aspirated Powertrain 9 02-13-2001 12:19 AM
Rattle coming from the rearview mirror. munkis Car Audio, Video & Security 4 07-12-2000 07:25 PM
