Old 02-21-2007, 12:04 AM   #1
06slvrsti
Member#: 139497
06 STi
Default 06 STi 1st and 2nd gears are hard to shift when cold?
Attention Sti gurus; I have an 06 STi with 1200 miles and the tranny is hard to shift when cold, specially in the morning. I often have to double clutch just to get into first gear and it is hard to pull it out to go into 2nd. Getting into 2nd is not smooth either. I had my local dealer document the issue and they told me nothing is wrong. What do you guys think? Anyone from a cold climate experience the same issue?
06slvrsti is offline   Reply With Quote
Old 02-21-2007, 12:10 AM   #2
toulakid
Member#: 39832
02 +06 speed,r180
blue
i have the same issue espically in 3rd gear
toulakid is offline   Reply With Quote
Old 02-21-2007, 01:58 AM   #3
bWRX
Member#: 6672
You are going to force me to make a smart-assed comment about how the fix is to let the transmission warm up if you don't like the way it performs when it is cold, or something about every single gearshift heck every single mechanism I have ever operated in the cold has been a little stiff until it warmed up, or something about how my very own muscles and tendons are often very stiff if I haven't taken the time to warm them up before training.
bWRX is offline   Reply With Quote
Old 02-21-2007, 03:07 AM   #4
PA04STI
Member#: 37418
0491 STi FPGreen'd
GSX Evo III 16G
cold +'s thick fluid then when warm...Let it warm up 1st before you drive.
Matt
PA04STI is offline   Reply With Quote
Old 02-21-2007, 04:45 AM   #5
WhiTe_07_WRx
Member#: 135623
2007 Subaru
Be easy or let completly warm up when cold. Fluids deff ened to warm up
WhiTe_07_WRx is offline   Reply With Quote
Old 02-21-2007, 01:41 PM   #6
06slvrsti
Member#: 139497
06 STi
Well, I have found out that my car likes to shift after it warms up for 20 minutes during cold temperatures. I was only allowing for about 10 minutes on average. Thanks everyone I appreciate your input.
</IMG>
Old 02-22-2007, 01:13 AM   #7
Robspec
Member#: 23507
2007 UGM 07 sti lmtd
06 volvo v70r 10 mini jcw
use motul or neo sythetic libricants had the same problem used and now im hooked for life
Robspec is offline   Reply With Quote
STi 7: how to get full boost in 1st and 2nd gears? GDB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-06-2015 07:01 AM
06 STI stuttering in 2nd gear when accelerating mcrawford General Community 16 09-24-2007 12:36 PM
1st and 2nd gear......on the 06 aznkyuusai Newbies & FAQs 18 08-04-2006 10:57 AM
Blitz SBC-id vs. Apex'i AVC-R w/respect to full boost in 1st and 2nd gear annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-30-2003 11:18 PM
How safe is it to run 1st and 2nd gear @ 16psi? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-17-2002 11:22 AM
