Old 02-21-2007, 05:46 PM   #1
d40winker
Member#: 128010
2002 Impreza WRX
white
Default Accuracy of AP live boost read
Hey everyone,
Since the AP is reading the bost from the ecu, is it as accurate as the oem boost gage? Im upping my wastegate actuator and the readings are quite different from the gauge to the AP live boost. Any ideas?
d40winker is offline   Reply With Quote
Old 02-21-2007, 06:14 PM   #2
Airboy
Member#: 72829
2006 HTA68'd wagon
Powered by RomRaider
How different is "quite different"?
Airboy is offline   Reply With Quote
Old 02-21-2007, 10:53 PM   #3
d40winker
Member#: 128010
2002 Impreza WRX
white
I push .1 bar on stock gauge which is I think 14.7 psi, and the AP is reading 16.4.
Old 02-22-2007, 01:01 PM   #4
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
I would consider the AP more accurate.
It's simply interperating the what the stock ECU thinks your boost is.
parker/slc/gc8fan is offline   Reply With Quote
Old 02-23-2007, 09:36 AM   #5
d40winker
Member#: 128010
2002 Impreza WRX
white
That's strange I would think the boost gauge would be more accurate because of the fact that it's tapped in, not just electronically reading it. Any other input?
Old 02-23-2007, 10:26 PM   #6
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
I think that the ECU is the most accurate, especially if you have a mechanical boost gauge....I mean it's like doing math by hand vs. using a calculator...the calculator will always be a step faster and a step more accurate 99% of the time. The sensors in the engine are more accurate than the spring in a mechanical boost gauge IMO. However, both my AP and Mech. boost gauge read about the same and at most are maybe .5 PSI different sometimes.
Force is offline   Reply With Quote
Old 02-23-2007, 10:42 PM   #7
El Capitan
Member#: 121261
06 STG 2+ STi
CGM
If you are talking about the colum mounted boost gauge, it isn't reading bars. The stock gauge reads in MPa & .1MPa is 14.5psi.
16.5psi is .113MPa. I'd say that based on how small that gauge is that the AP and the gauge are real close. I have the same set up and it's pretty much the same based on trying to look down and drive at the same time.
Convertion tool link.
http://www.chapelsteel.com/psi-mpai.html
El Capitan is offline   Reply With Quote
Old 02-25-2007, 07:15 PM   #8
Silver_Bell_WRX
Member#: 7677
2005 WRX
My ap and autometer boost guages both read the same up to the limits of what the ap will read. Max boost ap reads is 18.4 were a regular boost gauge can read higher if it has the range.
Mike
Silver_Bell_WRX is offline   Reply With Quote
Old 03-02-2007, 10:15 AM   #9
jruben4
Member#: 50784
2005 STi
I thought the stock boost gauge reads the ECU boost data, not a true vacuum line - doesn't it install with just an electrical connection?
jruben4 is offline   Reply With Quote
Old 03-02-2007, 04:23 PM   #10
VWGrk1
Member#: 57882
2004 WRX
No, the boost line is T'd off from the BPV line.
VWGrk1 is offline   Reply With Quote
V1 Live boost reading kooklie AccessPort 2 06-30-2009 04:55 PM
Boosting 17.1 on AP Live boost on Stage 2 06WRXTR AccessPort 14 02-15-2007 11:36 AM
live boost readings? -=EJ20T=- AccessPort 4 07-31-2006 04:52 PM
Something wrong with AP Live Boost Reading? sandwi54 Engine Management & Tuning 6 02-04-2006 06:21 PM
Accuracy of the factory boost gauge. Boosted Factory 2.0L Turbo Powertrain 3 02-24-2002 05:14 PM
Message Board Statistics All times are GMT -4. The time now is 03:08 PM.
