#1 |
Member#: 117790
RMIC
Vehicle:2006 Impreza 2.5i Black |
i have heard a couple different ways to debadge an impreza trunk does anyone one the best way??? thanks!
#2 |
Member#: 120716
Vehicle:2002 psm ver7 wrx reversed and rotated |
BEST WAY... take fishing line or dental floss and saw off the badges... put it between the badge and the trunk and go back and forth... fishing line works better... then use goo off or whatver it is called.. you may need to buff the area too
#3 |
Member#: 117790
RMIC
do you know if that works for the bigger subaru logo in the center also?
#4 |
Member#: 120716
yup thats what i did on my trunk, i had like 30 logos on there when i got it haha
#5 |
Member#: 125884
VIC
Vehicle:2006 Lan Evolution 9 MR SE Tarmac Black |
http://videos.streetfire.net/video/9...89EE0B9E08.htm
-007 If you have an 06/07 the subaru center emblem will not come off as it is bolted on. |
#6 |
Member#: 124376
NESIC
Vehicle:2005 Legacy GT Wagon TDC Silver |
You guys don't use heat?
I've used a hairdryer and lots of patience, especially if it's cold (like winter). A heat-gun could be too aggressive with its temp.....unless you're experienced with that. I use a heat gun and start at least a foot away and slowly heat the surfaces. A good tip is: if the heat is too much where you can't hold your hand near the badge, then you are too close and risking damage to the surrounding areas. |
#7 |
Member#: 117790
RMIC
so is there anyway to get the center logo off on the 06 impreza?? cause that is what i have
#8 |
Member#: 83638
SCIC
Vehicle:2002 wrx winglesswhitesaloon |
use a shotgun
#9 |
Member#: 103340
Vehicle:2004 STI Saved from the junkyard |
#10 |
Member#: 120485
SWIC
Vehicle:2006 tr w/APS stuff crash and burn |
I would use a shotgun but I'm scared of loud noises, I also would like to no how to remove emblem without use of shotgun
#11 |
Member#: 6418
trading trunks with another new age impreza would be the only way.
#12 | ||
Member#: 25187
Vehicle:'03 WRX Sedan MBP '08 Forester Prem TGM |
#13 |
Member#: 120152
Vehicle:2006 WRX, ESP 92 CNY Overall Pax Winner! |
As stated before (but no one seems to have read yet) the back of the emblem for the 06 has two posts on it. These posts are inserted into holes in the trunk and bolted in place. If you remove it, you are left with two holes. You either need to trade trunks, or get the holes welded, sanded, painted, etc. Or just leave the center badge alone.
#14 |
Member#: 6418
not to mention that there is an indentation as well as the 2 holes.
#15 |
Member#: 138728
W. Canada
Vehicle:MY06 2.5i Impreza Aspen White |
I got quoted $200 to fully debadge my trunk because of Subaru's stupid idea to have the fat emblem bolted on in the 06 trunk.
Have to have the holes patched and my trunk repainted, now why couldn't they have just left it alone.... |
#16 |
swap the trunk man
#17 |
Member#: 100311
SCIC
Vehicle:'05 Impreza 2.5 RS crystal grey metalic |
personally i am not a huge fan of the debadge.....but hey we all have our personal preferance.. I like people to see a cool car and know what car they are looking at. :P
Although I do really like the shotgun idea... maybe bird shot wouldn't be the way.. How about a nice big 12guage slug? |
#18 | |
Member#: 115199
South East
Vehicle:2003 WRX PSM |
#19 |
Member#: 168187
SCIC
Vehicle:04 WRX Wagon 16G+Built Motor |
The problem that I am having is that after I have removed all the goo and stuff, there are still like scuffs around where the letters used to be, so it looks scuffed and then clean in the shape of the old letters so you can still see their outline. Any way to get rid of this or sort of blend it?
#20 | |
Member#: 169792
NESIC
Vehicle:2005 STI Aspen White |
#21 |
Member#: 181309
NWIC
Vehicle:2002 WRX AW |
i just buffed it out with a good microfiber cloth and bug/tar/goo gone stuff and it blended in very well. just depends on the condition of your paint because the paint behind the emblem has been protected from sun, dirt, rain etc until now.
#22 | ||
have you thought about leaving just the logo emblem? maybe repainting it like i did..? it would save you having to deal with the holes...check out some of the pics in this thread...http://forums.nasioc.com/forums/show...7#post23211497 |
#23 |
Member#: 171741
Vehicle:2005 Impreza 2.5 RS SRR/Gold |
I just did mine
Materials Fishing Wire Hairdryed 3m Adhesive remover A few Rags Wax Heat up the emblems first then use the fishing wire to pry them off. Once you get all the emblems off there will be some residue use the 3m remover with a rag to wipe off (heat up first as well) Once you get all the residue off I washed my car and especially the trunk. After Washing I waxed. You can still see the outlines of the SUBARU logo but after time and a few wishes it will fade away. Hope this helps |
#24 | |
Member#: 157634
RMIC
Vehicle:2007 STi CGM |
THANK YOU for not talking out of your arse. I'm sorry, but if you posted on this thread about it being bolted or there being an indentation (not sure about the 08, but i imagine it's identical), you've obviously not done this simple mod and should not recommend anything. Seriously, bolts?! Did you even take it off? I hope i never get a recommendation from you guys on a mod. Btw - heat gun works well, but a hair dryer is just as easy and probably safer on the paint. Use some goo gone to get the rest of the glue off the car. |
#25 | |
but yeah, hair dryer is probably best...just takes effing forever...i was planning on putting my badge back on after painting it anyway, so i got impatient and just ripped it off... |
