Old 02-22-2007, 10:15 PM   #1
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Default What my car sounds like
Some have asked what my car sounds like with the Borlas, Random cat, Cobb CAI and especially the Fujitsubo muffler. I took two videos from inside the car a week and a half ago to illustrate what it sounds like. If there's enough interest, I'll make a video of the exhaust itself.
TWE Equal-length headers!
http://youtube.com/watch?v=zj63wKQVGKc
Uphill run:
http://youtube.com/watch?v=gvkSK9E2sPY
Flat run:
http://youtube.com/watch?v=HdDA7S41suc
Cold startup, two acceleration runs and some drive bys:
http://youtube.com/watch?v=Q9lq5pylAhk
Three more drivebys and one and a half acceleration runs:
http://youtube.com/watch?v=hD-ppaZLkVU
DLC is offline   Reply With Quote
Old 02-22-2007, 10:30 PM   #2
legacy99black
Member#: 52238
2001 Legacy GT LTD
Hummer Black
Oh man I heart your BE
How loud on the outside?
How loud is the idle?
legacy99black is offline   Reply With Quote
Old 02-23-2007, 12:36 AM   #3
MoclovFlop
Member#: 125534
2004 WRX
I hear Illogic and Aesop!
Also, you you have the classic boxer burble at lower speeds?
MoclovFlop is offline   Reply With Quote
Old 02-23-2007, 01:42 AM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Yup, that's Labor Days
It's a very nice boxer sound at startup, idle and any partial throttle driving. It only gets aggressive sounding, as the videos demonstrate, when I'm pushing it hard and the Cobb CAI lets the engine suck in huge gulps of air
It's pretty free-flowing with the Random cat on it, so the sound is nice. I should do another one tomorrow with cold startup and another with a warm startup and idle from head height so people can get an impression of what it sounds like. It'll probably be snowing tomorrow, but I might also be able to do a driveby if I get creative.
Old 02-23-2007, 02:11 AM   #5
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
[email protected] turn-signal-bright-flash-bobble.
Nice sounding exhaust. I've never had my car over 5k personally. Maybe I'm just a vagina though.
Sub_Speed_Guy is offline   Reply With Quote
Old 02-23-2007, 05:47 AM   #6
MitchGT
Member#: 73684
2012 4Runner
Damn that sounds good!
MitchGT is online now   Reply With Quote
Old 02-23-2007, 10:48 AM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Oh, forgot to mention that this car has the Cobb Street Cams too, which makes it even more aggressive sounding
Old 02-23-2007, 12:01 PM   #8
MitchGT
Member#: 73684
2012 4Runner
Did you buy that off another member a few years back ??
Old 02-23-2007, 12:06 PM   #9
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The car or the cams? The car yes, the cams no.
Old 02-23-2007, 01:18 PM   #10
rougeben83
Member#: 115154
2005 Outback XT
White on grey
How much was it to get the cams installed?
rougeben83 is offline   Reply With Quote
Old 02-23-2007, 01:34 PM   #11
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
That sounds great! How much for the cams?
Wiscon_Mark is offline   Reply With Quote
Old 02-23-2007, 02:29 PM   #12
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Back two years ago when I had my first problems with the head gaskets/heads warping/clogging radiator, I'd actually set it up to get the engine swapped for another EJ251 instead of repairing this one because I was told one of the heads might be cracked. That replacement engine ended up having spent a lot of time around moisture without headers or covered exhaust ports, so the rings were messed up.
Instead of trying to find another engine, I had the mechanic look deeper into my engine, which resulted in finding that the heads weren't cracked, but warped slightly.
Because I had the engine out of the car and the heads off, and because Cobb was a short walk down the street, I got the Street Cams, Exedy flywheel, ACT Stage 1 clutch and Power Pulley installed while everything was pulled apart, saving a LOT on installation (Dealer/SOA paid for most of his work because he was smarter than they were). Stage 2 Cobb NA Legacy GT
Cams are the same as the RS, so they're $500:
http://cobbtuning.com/products/?id=2382
I know, It's a lot more than the Deltas, but I knew what I wanted and they were available immediately. I did need to have the valves adjusted later to make sure everything was in spec. One of the only drawbacks to ANY cams in a Subaru is that they're noticeably louder than stock. Adjusting the lash quieted them down a little, but it's still louder than stock.
Old 02-23-2007, 03:56 PM   #13
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Yeah, Deltas are good only if can afford the downtime to have the cams removed and reground and shipped, or if you can get a 2nd set of cams.
I didn't know you had that much work done to your BE. Are you using any piggyback with the cams or anything? I thought you had to use one...
Old 02-23-2007, 04:36 PM   #14
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
No piggyback. Everything I've done is within what the ECU can tolerate. I do get a CEL if I'm over 50-55 with a load, like the freeway onramp or going uphill. It goes away in 100 miles or so. No big deal.
I'm putting together another video of the car at startup from outside, driving around with another few acceleration runs and some slow drivebys so that people (and me) know what it sounds like outside. Expect it in an hour from now or so.
Full mod list: http://legacycentral.org/mylegacy.htm
Old 02-23-2007, 05:50 PM   #15
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Thumbs up
12345
KD7000 is offline   Reply With Quote
Old 02-23-2007, 06:41 PM   #16
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Added another link to a longer, better, more interesting video.
Old 02-23-2007, 08:26 PM   #17
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Sounds really good. The car kind of sounds like my new setup, especially the part that it doesn't hit a rumble until like 2000 rpms (lower than that its just a single note).
Pretty damn quick for a car that big too. Is the clicking the cams?
Plays_With_toys is offline   Reply With Quote
Old 02-23-2007, 08:42 PM   #18
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Thanks DLC, now I miss my BE even more
fibuz is offline   Reply With Quote
Old 02-23-2007, 08:48 PM   #19
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The ticking you hear around the engine is the effect the cams have on noise. It's quieter now than it was, and I've sorta gotten used to it.
You're welcome fibuz :P
Old 02-24-2007, 01:59 AM   #20
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Well hurry up and get a Legacy again!
Old 04-11-2007, 03:52 PM   #21
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I added a fourth video of three drivebys at three locations and one and a half acceleration runs. The car sounds a little different when the CEL/MIL is off, and my TWE EL headers are due any time, so I figured I'd get it while it's sounding it's unequal best.
Windows rolled down for the driving. Love the quality of the mic on this cam (Fuji F10).
Old 04-11-2007, 03:59 PM   #22
SLI99
Member#: 134819
2005 Ford F150 FX4
Not to offend you guys with BE's but my DOHC BD seems to go alot faster..dont take that offensivly...just saying
SLI99 is offline   Reply With Quote
Old 04-11-2007, 04:08 PM   #23
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Take into account that I'm at ~4500ft elevation, which isn't helping.
It always feels faster when actually accelerating than watching the speedo and tach.
I've never recorded a hard launch from a dead stop, mostly because I don't do that sort of thing. It's mostly for the sound, less so for the rate of acceleration
Old 04-11-2007, 04:40 PM   #24
badbasser98
Member#: 104801
2011 WRX Limited
sounds good. Can't wait now to finish my exhaust and custom intake.
*waits for warmer weather*
badbasser98 is offline   Reply With Quote
Old 04-11-2007, 05:00 PM   #25
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
They're a lot heavier.
my car sounds like a vw bus! IntraWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-04-2004 06:36 AM
My car sounds like in reverse gear but when moving forward sonicowrx03 Transmission (AT/MT) & Driveline 4 06-20-2004 12:22 AM
Why does my car sound like my mom's car? wlchan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 11-27-2003 01:14 AM
My car sounds like a low-rider Big_Hitter Texas Impreza Club Forum -- TXIC 6 06-14-2002 11:34 AM
My car sound like a V8 Chevy! adamsrs Normally Aspirated Powertrain 23 03-15-2001 12:52 AM
