Old 02-22-2007, 11:11 PM   #1
aka_tur
Member#: 109847
97 4dr L WRX R.I.P
Panda
Default dash swap and motor swap questions
do you have to swap the dashes when you do a motor swap. i have a 97 l and like the way my dash looks. i have no problems doing wiring work since ive done motor swaps before but just wanted to know since this will be my first subaru swap.
also with the motor swap. i have two optionss from my friend. i still have to see what versions these are but he has an sti motor and a wrx motor. just need to know since i have an 97 L do i need the rear diff. i know the ration for the 97 up 5sp is like 4.11 or something like that. do i need to change that up for the wrx and sti?
aka_tur is offline   Reply With Quote
Old 02-22-2007, 11:47 PM   #2
Ackit
Member#: 133833
2000 RSTi R.I.P.
AW E46 M3
I have the stock dash with a 04 STi engine So no you dont...
Ackit is offline   Reply With Quote
Old 02-22-2007, 11:52 PM   #3
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
yes you need the rear diff that matches the final drive ratio of the tranny. And no you dont need the dash. You can splice the engine into your exsiting dash. If you get a drivetrain from 97 it should be plug and play with your dash. I think even 94-97 engine will be plug and play with your dash. Make sure you get ALL of the wiring.
circaisdashiat is offline   Reply With Quote
Old 02-24-2007, 08:25 PM   #4
aka_tur
Member#: 109847
97 4dr L WRX R.I.P
Panda
thanks for the info. im planning on doing a version 4 sti swap but need to find a motor or a front clip. i found this online but need to know about its reliability . http://www.flashoptions.com/product.asp?prodID=219 if anyone else know of one please let me know. and if anyone can tell me the version 4 final drive so i know if i need a new diff or not. and will the version 4 sti front clip be just plug and play in a 97 L AWD 2.2
Old 02-24-2007, 08:31 PM   #5
kheff46
Member#: 66739
2002 WRX wagon
i did a V4 STi swap. i wish my car was a 97+ for the correct dash/cluster fitment. my 95 L has a different dash, cluster bezel, etc and dosen't mate with the newer cluster. they have a different angle completely.
the wrx/sti V4's have 4.444:1 FD ratio. and get the diff from it is possible. it will be a LSD most likely. theres some usdm cars that have that FD, but not too many. so it may be easier to source from the clip/engine supplier and get it shipped altogether on one bill.
good luck!
--keith
kheff46 is offline   Reply With Quote
Old 02-27-2007, 10:22 AM   #6
Guru
Member#: 142023
You have to do something in order to get speedo to work. 98 and older use cable speedo and sti is electronic signal.
Guru is offline   Reply With Quote
Old 02-27-2007, 05:21 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
First off, 93-97 is a cable speedo, 98 is electric, but requires the cluster to interpret a signal, 99+ is fully electronic.
Now that I've got that out of the way, its very simple to wire up a electric speedo ecu in a car with a cable speedo - just tap the signal from the cluster harness, where the stock ecu in a cable speedo car gets its signal from.
jamesfacts is offline   Reply With Quote
Trunk swap and rear deck questions subiedude676 Interior & Exterior Modification 11 05-12-2010 06:21 AM
yes another 2.5 swap.....and all the questions to go with it lin4tw Subaru Conversions 13 04-06-2009 09:12 PM
22b replica 2.5rs... Full kit, wrx dash and motor swap eyehate Member's Car Gallery 67 06-17-2008 09:25 PM
99 2.5 rs suspension and motor swap, into 97 impreza s/w?? mm88swrt Subaru Conversions 5 09-10-2007 11:31 AM
doing the 6 speed swap and have a question about DCCD fc735 Transmission (AT/MT) & Driveline 0 01-25-2004 09:33 PM
