Old 02-24-2007, 01:13 PM   #1
dpk777
Member#: 97537
2005 Saab 92x Aero
Default Low RPM at idle
After your car has been fully warmed up what rpm does it idle at in neutral?
My car idle's a little below 500 rpm. Is that normal? Should I be concerned?
I'm running Cobb AP stage 2 (protuned) with a Perrin UP and TXS Stealthback exhaust system.
dpk777 is offline   Reply With Quote
Old 02-24-2007, 10:09 PM   #2
Thugthizzle
Member#: 114098
yeh thats normal. Mine is protuned with turbo upgrade and all that stuff and mine idles the same. Your good man!
Thugthizzle is offline   Reply With Quote
Old 02-24-2007, 10:32 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Probably another case of reading the Tachometer wrong. The first tick right next to Zero is 500rpm. The tick that you are reading "500" at is really 750. IIRC Idle speed is 650 +/- 100. So you are idling ok.
Old 02-24-2007, 10:51 PM   #4
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
yea its perfect
99subi is offline   Reply With Quote
Old 02-25-2007, 06:44 PM   #5
InjenSubiGirl
Member#: 139224
2003 WRX 2.0 Turbo
Custom Blue/Black
sounds normal to me, mine is the same, unless the AC is on of course...
InjenSubiGirl is offline   Reply With Quote
Old 02-26-2007, 11:59 AM   #6
JerseyKid
Member#: 135901
2011 WRX
Satin White Pearl
Same thing here, when i hooked it up to a Genisys scan tool , it was telling me about 750ish , but the tach looked like it was at 500
JerseyKid is offline   Reply With Quote
Old 02-26-2007, 12:43 PM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if people would learn to read tic marks properly this woudn't be an issue.
some are THICK and some are THIN for a reason.
low vacuum at idle, low boost; HELP! Deuce Cam Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-08-2009 11:14 PM
High RPMs at idle jayjay75 Service & Maintenance 6 05-30-2009 05:03 PM
Bouncing RPM at Idle...? Chigae Normally Aspirated Powertrain 10 08-02-2006 10:28 AM
RPMs at idle acting funny..? SjpWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-29-2004 01:06 AM
problem - fluctuating rpm at idle Jejunum Normally Aspirated Powertrain 12 03-30-2003 01:09 PM
