Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-05-2009, 12:12 AM   #251
fulltimeW.O.T.
Member#: 120414
2009 WRX 5Dr DGM
Stage 2+Meth
tempted to remove it in my 09. Would be the same thing i assume.
fulltimeW.O.T. is offline   Reply With Quote
Old 10-14-2009, 05:17 PM   #252
fast06wrxtr
Member#: 206590
Originally Posted by KSTech View Post
I am getting a lot of conflicting info from the Subaru manuals and from people I've talked to. I am not so sure the atmospheric pressure sensor is in one of these valves now. The manuals imply that the valve with a pressure sensor is to read air pump pressure for air pump diagnostics, not atm. pressure. Also talked to people who have removed both valve and had no issues.
Has anybody with a 2007+ removed both valves (and pump) and checked their atmospheric pressure reading? It should be constant - about 14.7psi at sea level and around 12.2 psi up at elevations around 5000' (like here).
I actually just left the thing in there. Can you log ATM pressure with a Cobb AP? If so, I'll try unplugging the valve this weekend and report what happens. This is in a MY06, though...
fast06wrxtr is offline   Reply With Quote
Old 10-18-2009, 09:59 AM   #253
05-rsx
Member#: 101188
MY07 WRX Wagon
Some progress, and a few things of note:
1) I've been driving around my 07 with pump removed and both valves unplugged for a a week or two. Did not notice any ill effects.
Initally I did leave the Pass/Sensor valve plugged in, but as the block-off plates hadn't arrived, and it was still connected up to the head, this caused exhaust to leak 'backwards' out the solenoid on cold-starts for ~30s.
Also happened to have the car dynoed whilst the valves were unplugged. It wasn't quite as rich as I thought it'd be. I don't know if this is simply coincidence.
2) KS-Tech plates arrived from the US at the end of last week. As promised to Matt, I said I'd shoot up some pictures. Only did 'driver' (well technically 'passenger' for us RHD people) side. Simply didn't have the time to pull everything apart to get to the other side behind the turbo. Might attack this later when I do dumppipe.
Few pics of the beautifully produced KS gear. I take my hat off to these guys. OEM-like fitment and fantastic customer service.
The valve/solenoid/associated piping to be removed:
Blank on:
Also grabbed a (I believe in-prototype) cover for the solenoid, for if it does have to be kept on the 07 models. Like the block-blanks, fitment was perfect.
The only issue I did have was that the HD plastic plate is thinner than the OEM-metal flange. This meant that the RHS bolt bottomed out in it's thread in the cast housing before becoming snug on the plate.
Could be easily rectified by either:
-making the plate a bit thicker (difference pictured below)
-shortening the bolt.
That said, I doubt that bolt not getting snug will actually prohibit it's simple function of just preventing crap getting into the solenoid. But thought I should mention it none-the-less.
05-rsx is offline   Reply With Quote
Old 10-19-2009, 10:09 AM   #254
KSTech
Member#: 143570
Thanks for the info, Campbell. That valve plate is actually black-anodized aluminum, not plastic. I used some allen-head screws on the one here, so that's why I didn't notice the bottoming out. We will have to include screws with it.
KSTech is offline   Reply With Quote
Old 10-19-2009, 09:18 PM   #255
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
You would have to be a masochist to try and get the passenger side off without taking off the manifold and turbo:
stuff removed:
Bad Noodle is offline   Reply With Quote
Old 10-19-2009, 09:36 PM   #256
sch3838
Member#: 154636
i ended up cutting the pipe near the passenger side, it was pain in the ass because i didnt removed the up pipe, but its do-able. i didnt block off my atmospheric sensor, just 2 holes on the block. the car drove about 10K now, no problems, of course tuned and turned off CELS
sch3838 is offline   Reply With Quote
Old 11-01-2009, 12:20 AM   #257
QweQwe
Member#: 30791
Ive been reading up about it and i had a few questions.
Currently i have a 07 sti chassis and main harness with a 05 sti longblock
the 05 sti engine has no provisions for airpump
So my question is,
if i keep the Atmospheric pressure sensor plugged in does it not throw any check engine lights? i could also keep the airpump plugged in also.
if anyone could shed some light on this subject it would be greatly appreciated.
I would like to have no CEL and i have no problem running the airpump and atmospheric pressure sensor as i need to the smog the car since it is salvaged. I just dont want to deal with any headaches
QweQwe is offline   Reply With Quote
Old 11-01-2009, 12:22 AM   #258
QweQwe
Member#: 30791
also im looking to buy a atmospheric pressure sensor
Old 11-13-2009, 03:24 PM   #259
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
i did this last weekend w/a friend that had done it to his 07 sti. we removed the pump and the metal fitting that goes onto the block on the drivers side. we didn't do anything to the pieces on the pass side ( i kept telling him i think there's 2 holes on the block that need to be blocked off. )
is that correct? on an 07 wrx ( seems like there's alot of confusion as to what model has what and what to do to each one )
at start up i am hearing like a burrrrrr sound and goes away after a few seconds. is this from the atm meter or do i need to plug or remove something else?
boostdog is offline   Reply With Quote
Old 11-13-2009, 03:25 PM   #260
boostdog
Member#: 149752
2017 wrx
Originally Posted by juanmedina View Post
This is what I removed
One of the stupid Ksketch plate was off, the holes where not concentric to the bolt holes so I have to fix them. Do you guys remove these two solenoids as well?
i removed all the parts above..exact same ones. Jaun did you have to block off / remove anything on the pass side?
Old 11-18-2009, 07:34 AM   #261
boostdog
Member#: 149752
2017 wrx
bump for answers please.
Old 11-18-2009, 09:56 AM   #262
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
so removing this on an 06 wouldnt throw any codes?
jsnm is offline   Reply With Quote
Old 11-19-2009, 12:25 PM   #263
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
sorry for delay, no you don't have to remove anything else. Just what you see on the pics
GL
Old 11-19-2009, 12:31 PM   #264
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Did you read the thread?? Of course it will throw codes. The pump is gone! Sensors are gone! However, a tuner can remove these codes.
Old 11-19-2009, 12:36 PM   #265
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
i read what i could out of 11 pages while at work
Old 11-24-2009, 01:27 PM   #266
boostdog
Member#: 149752
2017 wrx
GL
great thanks man!
Old 11-27-2009, 04:25 PM   #267
Baay
Member#: 139645
07 WRX
UGM
I can confirm some findings i have just tested,
If the 6 pin plug solenoid with the sensor is unplugged, the ECU will default to 21.71PSI reading. I plugged it back in and saw it fall to 14.22 PSI, and as far as i can see, the ECu has no other sensors for Atmospheric Pressure readings.
So, take from that what you want
Baay is offline   Reply With Quote
Old 12-03-2009, 11:31 AM   #268
TexRyker
Member#: 199059
08 STi Wagoneer
White/Gold
On the 6 pin.... it is tied to several different sensors including the manifold pressure sensor. This problem might be able to be fixed with a resistor??
Here is the pinout:
LH Tied to:
1. Pin #1 Color:R
a. Elect. Throttle Cont.
b. Manifold Absolute Press. Sensor
c. Tumble Gen. Valve LH
d. Tumble Gen. Valve RH
e. ECU A19 (See chart)
2. Pin #3 Color: BL
c. Engine coolant temp sensor
d. ECU A29 (See chart)
e. Knock Sensor
f. Tumble Gen. Valve LH
g. Tumble Gen. Valve RH
3. Pin #4 Color W
a. Engine GND
4. Pin #2 Color RY
a. A27 (See chart)
5. Pin #6 Color BR
a. Power from relay and fuse block
6. Pin #5 is empty
RH Tied to:
1.
a. Engine GND (Pin #1 Color: W)
b. Power from relay (Pin #2 Color: BrR)
TexRyker is offline   Reply With Quote
Old 12-15-2009, 02:02 AM   #269
tcr04
Member#: 102871
2006 wrx
is it possible to remove the CEL on a stock 06 wrx without removing the air pump?
tcr04 is offline   Reply With Quote
Old 12-15-2009, 11:07 AM   #270
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
You can disable it, but why would you? Do you have a CEL from something failing?
06rexwagon is offline   Reply With Quote
Old 12-15-2009, 12:31 PM   #271
tcr04
Member#: 102871
2006 wrx
its throwing the p2444 code
Old 12-24-2009, 06:43 AM   #272
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
I removed entier system from 07 sti. hoses and all. the only thing left is the opening on drivers side head. I will put a plate there to shut it. after pro tune will I have issues?
slava from goshen is offline   Reply With Quote
Old 12-25-2009, 08:20 AM   #273
05-rsx
Member#: 101188
MY07 WRX Wagon
Without a plate on that 'hole in the head', your exhaust will leak out, your turbo will not spool, and your car will run like ****.
Either put the plate on before you run it, or reattach the solenoid (although still unplugged from the connector) to 'seal' it.
Old 01-30-2010, 08:09 PM   #274
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Have any one tired cutting that valve in half and just take out the connector with the sensor???
Bariga is offline   Reply With Quote
Old 01-30-2010, 10:50 PM   #275
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
looks like no one has balls to do it, so i did it.
After i open it up i realize it was not necessary to cut anything, you can do it from top with sharp knife just cut and you set! Make sure you heat up the top of it for easy cutting!
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
