Old 07-22-2011, 11:02 PM   #426
punkrockdave
Member#: 125816
2006 wrx wagon
steel gray
I just got the CEL for the air pump so I plan on removing the whole assembly, but is it really that easy to turn off the CEL's on the accessport.
Is there a tutorial somewhere out there?
Originally Posted by EvileyeZ88 View Post
Accessport Race tuner allows you to turn off the CEL's
punkrockdave is offline   Reply With Quote
Old 07-22-2011, 11:43 PM   #427
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Get AccessTuner Race from Cobb, install it on computer.
Open it then choose File, load map, browse to your map and open it.
Next click "Edit" then click "Advanced Parameters".
A box will pop up with a lot of check boxes and OBDII codes. Uncheck the boxes for the CELs you want to turn off, click OK. Then click File, save map, I suggest naming it a new name.
Finally you load the map onto the AccessPort and reflash the ECU. You have to do a full reflash for the CELs to turn off and not just switch to a realtime map.
WRX_02_227 is offline   Reply With Quote
Old 07-23-2011, 12:21 AM   #428
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
^you got it
EvileyeZ88 is offline   Reply With Quote
Old 07-23-2011, 04:58 AM   #429
punkrockdave
Member#: 125816
2006 wrx wagon
steel gray
do you have to have an AP, or can you just get a tactrix cable and do it on your own?
i did some research and for some reason, i can't find the software for mac.
is romraider/ecuflash PC only, for now?
Old 07-23-2011, 09:49 AM   #430
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Tactric, RR, Eflsh is how I killed mine.
1 Lucky Texan is offline   Reply With Quote
Old 07-23-2011, 04:22 PM   #431
punkrockdave
Member#: 125816
2006 wrx wagon
steel gray
Doesn't seem like there are mac versions of this program, right?
Old 07-23-2011, 04:47 PM   #432
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
How much is the race tuner software?
Tuned200 is offline   Reply With Quote
Old 07-23-2011, 05:07 PM   #433
EvileyeZ88
Member#: 233501
99 outback sport
About free.99
Old 07-24-2011, 02:04 AM   #434
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I admit I don't know. Perhaps you could borrow someone's PC compatible laptop for the operation. Unless you want to get into some tuning outside of just killing the 14-15 or so codes associated with the bad air pump system, it's a set and forget deal. It's outlined pretty well in one of these threads, try a search on my handle plus tactrix. I couldn't have done it without the advice and support here.
Old 08-03-2011, 09:23 PM   #435
RedSpyder
Member#: 220714
Hi guys!
I have 07 WRX and I just got this damned CEL (P0140). Lets supose Im a lazy bastard, can I just leave the whole Air Pump Assembly crap there and just erase the code with "reflash"?
Like it wont hurt leaving the air pump there doing nothing?
Thanks in advance.
RedSpyder is offline   Reply With Quote
Old 08-04-2011, 12:49 AM   #436
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Originally Posted by RedSpyder View Post
Hi guys!
Thanks in advance.
Depends on if the valves are stuck closed or open. If they are closed you can pull the fuses and clear the codes with a reflash. That's what I did on my 08 Forester and haven't had any trouble. The very best idea though is to install block off plates and turn off the codes. I have the block off plates from KS Tech just waiting to be installed.
Old 08-15-2011, 10:46 PM   #437
juanvaldez
Member#: 291569
Default Instructions for Removal 06 9-2X
Does anyone have a guide for the removal/replacement of the secondary air pump on an 06 WRX / 06 Saab 9-2x. My mechanic is a bit hesitant to do the repair seeing he can't find any info on the repair in his repair software. He said if I found some documentation on what needs to be done we could undertake the repair.
Mine is stuck closed with CEL and code p2441 Secondary air injection switching valve stuck shut.
I would do the re-flash but the rom raider appears to cost $500, anyone in MN metro area with experience?
Thanks!
Patrick
juanvaldez is offline   Reply With Quote
Old 08-16-2011, 01:56 AM   #438
EvileyeZ88
Member#: 233501
99 outback sport
Well if they are stuck shut then just shut the codes off and forget it nothing wrong there, unless you want to remove the whole system.
I've taken a few of these bastardous systems out, if you got any questions please feel free to Pm me.
Old 09-08-2011, 01:18 PM   #439
airplnmdls
Member#: 218510
Hey guys, well i got P4224...valve stuck open (Bank 2)...2007 WRX...after reading over this entire thing twice, I understand what I need to do but I have a couple of questions...
1) I want to check the fuses/relays first. Are the relays for the valves on the main fuse box under the hood, labeled something like A/C CUT 1 or A/C CUT 2?
2) If im doing the plate delete on passenger side, if I want to cut off the flange head instead of removing the piping, do I still need to remove the downpipe/uppipe, or can I just work around it?
3) While I'm trying to sort all this out the next few days, my valve is stuck open, is it bad to be driving to work with it?
4) Bank 2 is driver's side correct? Does that mean A/C CUT 2?
5) Does anyone have this bank 2 valve they are interested in selling (if it works)? thank you!!!
EDIT: The relays I'm looking at were actually AIR CUT 1 and AIR CUT 2, are these the correct ones that control the valves?
airplnmdls is offline   Reply With Quote
Old 09-08-2011, 01:46 PM   #440
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I think they say AIR cut.
not confident to answer the other questions.
good luck.
Old 09-08-2011, 02:56 PM   #441
T-dub
Member#: 244480
'07 WRX TR
CGM
You will have to pull the up for sure. I did any way. One of the bolts wont come out with it on there.
T-dub is offline   Reply With Quote
Old 09-09-2011, 08:03 AM   #442
airplnmdls
Member#: 218510
Hmmm ok, not gonna be fun....I pulled the codes again last night and I had 3! P2442, P2443, and P1410...The first two contradict themselves, it says the bank two valve is stuck open and stuck closed. Then the third code seems to just say there's a general issue with the valve...I don't know what's happening...I switched the two relays just incase it was bad. We'll see in a couple of days...
Old 09-17-2011, 04:39 PM   #443
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Originally Posted by Bariga View Post
looks like no one has balls to do it, so i did it.
After i open it up i realize it was not necessary to cut anything, you can do it from top with sharp knife just cut and you set! Make sure you heat up the top of it for easy cutting!
So, I cut mine as well, what are the little leads showing on the bottom for, the air-pump motor? Should we worry about them shorting out? I'm gonna look at the factory service manual and hopefully find what pins the are the pull them out of the connector...
BeBop86 is offline   Reply With Quote
Old 09-17-2011, 09:46 PM   #444
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I think they are the power to open the solenoid and I don't think I did anything special to get rid of mine. I did cable-tie the unit in the engine bay in a way that any moisture would drain off.
Frank A is offline   Reply With Quote
Old 09-18-2011, 08:44 PM   #445
T-dub
Member#: 244480
'07 WRX TR
CGM
I just wrapped mine with a generous amount of electric tape and a zip tie. You don't need the manual. Just check continuity with a multimeter.
Old 09-18-2011, 09:53 PM   #446
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Good point...
Old 09-19-2011, 11:26 AM   #447
lancelot86
Member#: 240032
2010 FXT
I took my 2007 WRX into the Subaru dealership today and was quoted $830 for parts and labor. The code mine is throwing is P2441. Outrageous. I'm not wasting my money. I've already ordered the block off plates and I'm planning on getting a CobbAP.
Oh, and on top of that already ridiculous price they quoted I had to pay $52 for them to tell me what I already knew. If you get this code thrown don't even waste your time taking it into the dealer.
lancelot86 is offline   Reply With Quote
Old 09-19-2011, 11:37 AM   #448
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Did they happen to mention if the parts have been redesigned and this won't happen again in 4 years?
yeah, I didn't think so.
Old 09-20-2011, 06:54 PM   #449
lancelot86
Member#: 240032
2010 FXT
Nope. The guy was adamant that no such thing as an "air pump" existed on my car. I told him the 06 WRXs had 2 and the 07s had 1. He thought I was crazy. Maybe they don't call it an air pump.
I told him I wasn't gonna spend close to $900 to have thing crap out again in 30k miles. I said I'd remove the POS and delete the codes using a CobbAP.
CORRECTION: 06 and 07 WRXs have 2 "valves" to block off.
Old 09-30-2011, 10:05 PM   #450
some dude
Member#: 100300
06 WRX
CGM
I read this ENTIRE thread looking for detailed instructions on how to DELETE the CEL with OPENSOURCE tuning. I was unable to find the thread when searching your handle + tratrix ( I also tried tactrix). The last thing this thread could use is a detailed explanation of HOW TO DELETE CELs.
some dude is offline   Reply With Quote
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 09:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 11:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 08:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 10:25 PM
