Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 05-15-2012, 02:39 AM   #576
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
Originally Posted by J-horn92 View Post
If you buy some block off plates do you need to buy some gaskets, or can you just reuse the old ones?
Depends. If you live by the adage "we do it right, 'cause we do it twice", then go ahead and reuse them. Otherwise, no.
northman is offline   Reply With Quote
Old 06-01-2012, 08:39 PM   #577
plode
Member#: 116910
Who makes the block off plates? Would they be hard to make? I have access to aluminum and stainless steel stock and have some metal working stuff(drill press, grinders, sawzall, gasket material etc).
I'm going to rip all of this stuff out of my car on Tuesday or Wednesday. I have passenger side valve stuck closed code, and it sounds like a PITA to remove the passenger side valve, so I'm debating on if that valve is going to come out or not.
I already have all of the codes disabled via Accessport Race/Stage 2 tune.
plode is offline   Reply With Quote
Old 06-02-2012, 12:17 AM   #578
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
KS Tech:
http://www.kstech.biz/servlet/the-10...e-block/Detail
Order a set of gaskets at the same time
Rene2.5RS is offline   Reply With Quote
Old 06-02-2012, 12:17 AM   #579
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
KS Tech:
Old 06-02-2012, 08:58 AM   #580
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
FYI a good silicone gasket maker will be more then adequate for a gasket, no need to order new.
Old 06-02-2012, 06:08 PM   #581
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
They're not hard to make. I used 1/8" steel cause it's what I had. Traced the factory gaskets and reused them. Think it took me about a half hour.
If your engine is in remove the uppipe....I wish I would've....and yeah I pulled the passenger side valvle when I pulled the intake.
mccanixx is offline   Reply With Quote
Old 06-02-2012, 06:45 PM   #582
AWSnare
Member#: 249431
05 STi
CUrrently doing this on my 06 wrx... Drivers side done, all good... Passanger side on the other hand was a bit tricky (I did not take the uppipe off). NOW here is my problem...
How do you snake the pipe out of there!!?? I even cut 4 inches of it off!! I've been working at this portion for a solid hour now and I cant get it to move more than 2 inches either way!!
Help would be fantastic.
Thanks
AWSnare is offline   Reply With Quote
Old 06-02-2012, 08:48 PM   #583
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Sawzall, beer and gloves.
Drink beers, put on gloves, cut the piss out of the pipe, rip it out piece by piece.
That's how I did it, although I did remove the up pipe.
EvileyeZ88 is offline   Reply With Quote
Old 06-05-2012, 06:23 PM   #584
AWSnare
Member#: 249431
05 STi
Thats exactly what I ended up doing! haha
I still didnt have to remove the uppipe! Saved me from buying a new gasket...
I don't understand how to delete the codes in accesstuner... If I have a cobb protuned map, I can't tweek anything or load the map onto accesstuner because of "copyrights" how else would I be able to do it? Otherwise, I would be writing over my map and I obviously don't want to do that...
I'm going to see if cobb will delete the codes for me and send the map back..
Old 06-08-2012, 11:08 PM   #585
J-horn92
Member#: 314815
2007 Wrx
Dude I'm at the point to where I can't snake the pipe out either and I can't get the up pipe off. My turbine housing is right next to the bolt so I can't fit a socket on the bolt. Is everyone else doing this with a stock turbo? It's definitely not as easy as everyone is saying this is. Lol
J-horn92 is offline   Reply With Quote
Old 06-09-2012, 09:48 PM   #586
AWSnare
Member#: 249431
05 STi
You have to use a small wrench... its to the point where if you have more than a 5'' wrench its too long and hits the frame... you have to use a sawsall to get all the piping out if you dont take the uppipe off.
Old 06-09-2012, 10:37 PM   #587
EvileyeZ88
Member#: 233501
99 outback sport
^This, I had the uppipe, turbo, and DP out still had to use a sawzall.
Old 06-09-2012, 11:39 PM   #588
J-horn92
Member#: 314815
2007 Wrx
I'm definitely going to have to try the that then if this rain ever let's up down here in Florida.
Old 06-10-2012, 10:39 AM   #589
AWSnare
Member#: 249431
05 STi
Good luck! Its really not too bad.. if i had to do it again id be able to fly through the uninstall. Also, i just had cobb delete my codes bc thats where i got my protune and they were very nice about it.
Old 06-12-2012, 07:37 PM   #590
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
When the codes are tuned out does it leave a "not-ready" status for the emissions check? Trying to read up and see if a resistor will tell the ECU everything is good without messing with fuel.
imma_stocker is online now   Reply With Quote
Old 06-12-2012, 11:59 PM   #591
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I have gotten 2-3 emissions stickers since deleting codes on my 06 WRX.
1 Lucky Texan is offline   Reply With Quote
Old 06-13-2012, 12:55 AM   #592
J-horn92
Member#: 314815
2007 Wrx
Where did y'all exactly saw this thing out at? It seems pretty sketchy trying to saw it from bottom with it being so close to the block and all. Also I finally did get the up pipe and dp out, only part left is getting that damn pipe out. Lol
Old 06-13-2012, 01:07 AM   #593
AWSnare
Member#: 249431
05 STi
from the middle (under the intake) I took small chunks out from there and eventually it came out..
Old 06-15-2012, 01:10 PM   #594
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Trying to do this on a 2007 FXT, without removing the uppipe is proving to me more difficult than I thought it would be
EvasionOfTruth is offline   Reply With Quote
Old 06-15-2012, 01:26 PM   #595
J-horn92
Member#: 314815
2007 Wrx
Yeah I had to end up removing my downpipe, up pipe, turbo, and some coolant lines but i also didn't cut anything out. The pipe came straight out when I pulled it.
Old 06-17-2012, 08:53 AM   #596
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
KSTECH makes some and they come with gaskets only around 30-40 bucks My car operates fine.
SUBARIFFIC is offline   Reply With Quote
Old 06-18-2012, 04:30 PM   #597
Geranimo
Member#: 176999
2006 Wrx Limited
WFC#1122
Finally got my Air pump out about a week ago. Drivers side is super easy to do, but passenger side will make you want to punch a baby.
I ended up just disconnecting the harnesses, and i pulled the driver side valve out. I left the passanger side valve in due to it being impossible to get out without taking the intake manifold out. So i just cut the pipe connected to the head on the passenger side with a dremel and blocked off the head. I wouldn't recommend anyone do the delete unless your valves are bad or stuck open. Luckily i had install my EWG Upipe anyways so i knocked out 2 birds with 1 stone.
But yeah no problems what so ever after i did the delete. I deleted all related codes and everythings going good.
Geranimo is offline   Reply With Quote
Old 06-18-2012, 05:21 PM   #598
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Finished mine over the weekend, like everyone else has stated drivers side was cake. I cut the pipe going to the passenger side in 2 spots and was able to remove it without removing the turbo or uppipe. Atleast I got my downpipe installed during the process.
Old 06-18-2012, 10:07 PM   #599
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
what are you guys cutting the pipe with?
in case I ever wanna pull the parts....
Old 06-18-2012, 10:25 PM   #600
EvileyeZ88
Member#: 233501
99 outback sport
^Sawzall!!!!!!! FTMFW
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
