Old 06-18-2012, 10:55 PM   #601
AWSnare
Member#: 249431
05 STi
Yep. Sawsallll
AWSnare is offline   Reply With Quote
Old 06-18-2012, 11:02 PM   #602
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Same as above sawzall on drivers side, used a body air saw on the passenger side fitted with a full length hacksaw blade. Needed more reach under the intake manifold.
EvasionOfTruth is offline   Reply With Quote
Old 07-12-2012, 05:07 PM   #603
Babelyy
Member#: 325946
2006 WRX, ALLBLACK
cant you just pull the valves out, blast the rust an water away, put it back in an be ok?
Babelyy is offline   Reply With Quote
Old 07-12-2012, 05:33 PM   #604
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
And what good do you think that'll do?
imma_stocker is offline   Reply With Quote
Old 07-12-2012, 05:35 PM   #605
StealthTL
Member#: 206912
2006 Forester XT
Possibly.
The top solenoid part of the valves is kinda sealed and hard to work on, and even if you got all the rust out, the condensation and acids would have the whole system clogged again real quick.
StealthTL is offline   Reply With Quote
Old 09-24-2012, 06:27 PM   #606
millcityrex
Member#: 333179
2006 WRX
Grey
I am planning on removing my air pump and I'm not sure how or if the cel codes can be deleted and still pass emissions inspection.
millcityrex is offline   Reply With Quote
Old 09-24-2012, 07:19 PM   #607
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Remove them via access port race tuner, or have your tuner shut them off.
I have passed VA emissions and safety inspection 2 times with no issues.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 09-24-2012, 07:46 PM   #608
AWSnare
Member#: 249431
05 STi
~Evil
This.
Old 09-24-2012, 08:00 PM   #609
millcityrex
Member#: 333179
2006 WRX
Grey
~Evil
So it can be removed with a Cobb Access Port?
Here is my situation, my car threw out a couple of codes which is "secondary air valve stuck open bank 2". Ive been reading this thread for the past hour or so and can't figure out whats the best way to deal with the situation. What is the best and cheapest way to fix the problem? I dont have a Cobb AP but I can get one for cheap if needed. Just trying to find the cheapest way to do this because the dealer wants to charge me 330 a piece for the valves and they are not sure that will fix the problem because they also think its an electrical issue which is another 90/hr.
Old 09-24-2012, 08:44 PM   #610
EvileyeZ88
Member#: 233501
99 outback sport
Get rid of the system and be done with it.
Buy block off plates and gaskets, remove the system and install plates and gaskets.
You can either have someone open source tune with a tactrix cable to remove the codes.
Or go with the Access port and have someone tune them out.
Either way you'll never have to worry about that system failing again.
~Evil
Old 09-24-2012, 08:51 PM   #611
stevejones19
Member#: 275250
2006 WRX
The dealer sells the block off plates for $3.70 a piece. That's cheap. Only thing is waiting for them. I just ordered 2 and they said there was only 1 in the country. So its getting shipped all the way here from Portland, and they have to order another one from over seas. But if you mind the wait, its cheap, and you can just take it to a tuner to erase the codes.
stevejones19 is offline   Reply With Quote
Old 09-24-2012, 09:03 PM   #612
millcityrex
Member#: 333179
2006 WRX
Grey
~Evil
Ok. Is it cheaper to get a Cobb AP or have a tuner delete the codes? What other benefits do I have for getting the Cobb?
Old 09-24-2012, 09:05 PM   #613
EvileyeZ88
Member#: 233501
99 outback sport
You can also get them from here immediately.
http://www.kstech.biz/servlet/the-Ai...ete/Categories
The tactrix is going to be cheaper but all it is, is a cable to connect a car to a computer.
The access port is a tool you can use to monitor many aspects of your engine, along with data logging, on the fly map changing, and a plethora of other dohickeys that make you feel good. It was the obvious choice for me when I had to make a decision.
~Evil
Old 09-24-2012, 09:27 PM   #614
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
In my case, I was getting the "stuck open" code only intermittently.
I got it one day and the next day it was gone. I figured one of the 2 valves was starting to act up and it had trouble opening/closing but it wasn't completely stuck yet.
So, I waited until the next morning to see whether or not the code would pop back up. I started the car and I listened for the typical noise of the air pump to confirm that the whole air injection system was actually operating.
I waited a minute or two until the air pump noise stopped and I kept the car idling for an additional one or two minutes. I looked at the instrument panel and there was no CEL; so I shut the engine off, popped the hood and removed the air valves fuse and pulled the air pump relay out (if you look at the label/diagram at the back of the under-hood fuse box cover you'll figure it out).
The idea is to make sure that both valves are indeed closed and that they do remain closed (and they should since the air valve fuse is no longer connected).
Again, this only works if you're sure that both valves are closed.
neg_matnik is offline   Reply With Quote
Old 09-24-2012, 09:42 PM   #615
AWSnare
Member#: 249431
05 STi
Since you don't have the access-port, the cheaper way to solve this problem may be to replace the parts with used ones. I have everything out of my car still in tact except the driver side solenoid, and the tube that goes to the passenger one. Lmk I get it to you cheap. Try to find out what you need
Old 09-24-2012, 09:58 PM   #616
millcityrex
Member#: 333179
2006 WRX
Grey
Excuse my ignorance, but what will this tell me? also, i tried checking the fuse for the SAI but didnt see anything labeled such so I checked all the 10a fuse bcuz thats what someone in another post said.
Old 09-24-2012, 10:11 PM   #617
StealthTL
Member#: 206912
2006 Forester XT
He's saying you could leave everything in place and just pull the fuses, if you are sure the valves are closed when you do it.
You'd still have the CEL, but there should be no performance hit or damage.
The fuses and relay are in their own box, under the airpump, near the battery.
Old 09-24-2012, 10:14 PM   #618
millcityrex
Member#: 333179
2006 WRX
Grey
Oic...But will it pass the emissions test when I go for inspection?
Old 09-24-2012, 11:45 PM   #619
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Not with the CEL...
mechatricity is offline   Reply With Quote
Old 09-25-2012, 08:41 AM   #620
millcityrex
Member#: 333179
2006 WRX
Grey
If I do the same thing as SteathTL and remove the CEL via accessport, will it pass now?
Old 09-25-2012, 11:14 AM   #621
EvileyeZ88
Member#: 233501
99 outback sport
Yes. No CEL, no problem.
Old 09-25-2012, 01:43 PM   #622
millcityrex
Member#: 333179
2006 WRX
Grey
I tried this just to see if the air pump was turning on but I didnt hear anything when the car started. So, now I'm thinking that the relay is no good and I asked a buddy of mine if he knows how to check the relay. He checked it and said that there should be a clicking noise when the relay is removed and replaced while the car is in the on position. We didnt hear any clicks at the relay. Is that true about the relay clicking?
Old 09-25-2012, 02:23 PM   #623
Jaker32186
Member#: 228077
2006 WRX Limited
Default Pass Emissions with CEL
To pass emissions with the CEL on and no way to delete it....
First pick a warm day, the colder the faster the car will cool down. Thats not what we want.
Drive the car so its warmed up.
Pull the battery to reset your ecu
CEL should be gone
Drive atleast 30+ miles on your way to emissions
Stop atleast 3 times, turning the car fully off, remove keys, then back in and back on. The faster the better.
We are driving alot, and shutting the car down to make the ECU look like that it has been running for awhile. If you quickly reset and drive right to emissions, they will tell you your ECU was reset and hasn't been driven enough... This is a good option to get an extension on the test so you can make a proper fix before you get fined.
Then get to emissions. Keep car running.
Pull into emissions and have then plug into your OBD II port with car off
Should pass... did for me.
The Cel only comes on when the car is cold. Like the other posts say the seconcdary air pump only warms the cat up on cold start then off. So if the car is warm it won't throw the CEL. This is also the reason that you reset and the CEL "goes away" for a couple days. It takes a few goes before the car recognizes the air pump is stuck. If its stuck closed you can drive all day like no issue. I've had the CEL on for close to a year... both banks stuck closed. Saving for V2 AP so I can trade V1 in and clear CELs. Eventually Id like to remove the system, but no rush. I hear its a pain in the ass... (read every thread above to confirm) lol
It worked for me, good luck. I used a V1 AP to reset the ECU, but pulling the battery should be the same.
Jaker32186 is offline   Reply With Quote
Old 09-25-2012, 04:18 PM   #624
StealthTL
Member#: 206912
2006 Forester XT
The 'reset and drive a bit' procedure wouldn't work for him - he has a 'stuck open' code.
The ECU would flag it as soon as you restart.
However, open/closed/removed codes can ALL be removed without a trace with a Cobb and their 'race tuner' software.
Old 09-25-2012, 07:10 PM   #625
wrx5562
Member#: 276543
2011 wrx Premium
Lightning red
I agree with evil I had an 06 with the same issue.
wrx5562 is offline   Reply With Quote
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
