Old 04-27-2007, 09:44 AM   #51
sean18337
Member#: 135588
2007 STI *SOLD*
I removed all that crap.. on my 07 STI there was this little black box that one of the hoses from the pump went to that was wedged between the intake mani and the motor and took me over an hour to get out.
Not sure how much it all weighs, but it does make the right side of the motor cleaner looking!!
sean18337 is offline   Reply With Quote
Old 04-27-2007, 09:52 AM   #52
Mechie3
Member#: 120152
I took out my pump and one of the valves. I couldn't get to the other valve with my tools (limited selection). The pump weights about 5+ pounds, the valves are about 2 pounds or so apiece. Then there's all the associated tubing and whatnot.
Mechie3 is offline   Reply With Quote
Old 04-27-2007, 10:06 AM   #53
David Buschur
Member#: 24301
2006 WRX 345hp/345tq
Yes, I removed the entire deal on my car. If I remember right it's around 10 pounds.
David Buschur
David Buschur is offline   Reply With Quote
Old 04-27-2007, 10:15 AM   #54
sean18337
Member#: 135588
2007 STI *SOLD*
David Buschur
Dave, I just installed your block off plates last night and could only find the LH side valve and I blocked it off. I have an 07 STI, where can I find the valve on the RH side of the car.
Old 04-27-2007, 10:28 AM   #55
Mechie3
Member#: 120152
It's near the uppipe. If I remove the bottom subframe (which I did for my swaybar install) I can see it, but it's really down in there. If you follow the tube with the foil corrugated tubing over it than comes from the valve, the other end goes down around the engine block and terminates on the head.
Old 04-27-2007, 10:46 AM   #56
sean18337
Member#: 135588
2007 STI *SOLD*
I cannot even find the valve on that side. Do you have any pics you can show us?
Can I just remove the valve for now on that side and plug off the tube until I get to change my up pipe and that time I can remove the tube??
Old 04-27-2007, 11:03 AM   #57
Mechie3
Member#: 120152
The two valves are both on the driver side. The valve that feeds the passenger side is slightly under the intake header. You can plug the tubes. That's what I did for now.
Old 04-27-2007, 01:47 PM   #58
sean18337
Member#: 135588
2007 STI *SOLD*
I will have to take another look and see if I can find the tube leading over to the passenger side valve. I looked several times last night and did not see anything but I still have the stock up-pipe, turbo, and all the heatshileds so maybe that's why I cannot see that damn thing..!!!
Old 05-02-2007, 04:56 PM   #59
sean18337
Member#: 135588
2007 STI *SOLD*
Are we 100% sure the 07 STI has 2 air pumps? I do not think so..
I looked and looked and there is not a line that runs from the drivers side air pump or air valve to the passengers side..
Can anybody confirm this?
Old 05-02-2007, 04:57 PM   #60
sean18337
Member#: 135588
2007 STI *SOLD*
Also, is used Enginuity to edit the air pump removal codes and used ECUFLASH to flash the ECU..
Old 05-02-2007, 06:56 PM   #61
WRX_UA
Member#: 116189
2006 WRX Wagon 2.5L
Very black with T518Z...
What is the point deleting this system except for 10 pounds weight reduction??? (If the car has no cats at all...)
WRX_UA is offline   Reply With Quote
Old 05-04-2007, 01:53 PM   #62
WRX_UA
Member#: 116189
2006 WRX Wagon 2.5L
bump!!!!
Old 06-24-2007, 02:09 PM   #63
BryanH
Member#: 993
I wouldn't mind an answer to this as well.
Is there any benefit to this? 10 lbs? so what. I mean really....so what.
Better throttle response..I am all over it.
more HP...I am there.
Sounds neat...works for me!
10 lbs? meh....
BryanH is offline   Reply With Quote
Old 06-25-2007, 12:59 AM   #64
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Its not just about the additional 10lb weight loss. Its about the engine bay clutter. The more unecessary contraptions and tubing out of the way, the less congested the engine bay will be. Under hood temperature will drop. Plus it will look alot cleaner...
cpunlamd is offline   Reply With Quote
Old 06-25-2007, 01:33 AM   #65
Mechie3
Member#: 120152
It helps to declutter the engine bay, reduce weight (front end is already heavier than the rear). You will get some CELS's:
P01491
P0223
P2431
P2433
Please excuse the cell phone pics:
(mid removal pic)
Old 06-25-2007, 07:43 AM   #66
BryanH
Member#: 993
I will get some CEL's....well that is reason enough right there to remove it....
I don't really care about the engine bay clutter. If it was an issue I would be making up some sort of stupid shroud for the entire engine.
Old 06-25-2007, 09:54 AM   #67
Mechie3
Member#: 120152
You can't see it in the pics, but all of that brackety and some of the tubing/connectors were removed as well. I cleaned up the left side too (of other wires). Mike @innovative tuning is making me "custom" maps. Basically it's a copy of my current map with the CEL's shut off for $20.
Old 06-25-2007, 05:11 PM   #68
KSTech
Member#: 143570
Here are some pics of our delete plates installed on a customer's sand rail motor (an '07 I believe):
(click on it for a larger pic)
KSTech is offline   Reply With Quote
Old 06-25-2007, 05:59 PM   #69
Matt_H
Member#: 107000
2015 BMW X1
How easy/hard would it be to put these plates on? Any instructions?
Matt_H is offline   Reply With Quote
Old 06-25-2007, 06:36 PM   #70
bzbuzz
Member#: 116052
2011 STI ( Sold )
I am kinda interested in this one... this stupid air pump gave me big hard time when I was installing cusco MCB.
bzbuzz is offline   Reply With Quote
Old 06-26-2007, 10:01 AM   #71
Mechie3
Member#: 120152
Driver side valve/etc = easy
Air pump=easy
passenger side=!!!!!! (I couldn't get it off with my tools). the uppipe is kinda close. So, I removed everything I could and block of the hose.
Old 06-26-2007, 05:08 PM   #72
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Can the Cobb AP turn the CEL off (from the air pump removed)??
Old 06-27-2007, 12:43 PM   #73
Mechie3
Member#: 120152
You'll need a "custom" map. Mike an innovative tuning is making me a map for $20. I simply e-mailed the codes I need deleted and he'll e-mail my maps back.
Old 07-30-2007, 07:05 PM   #74
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
for those wondering, my 07 STi engine does not have a solenoid on the passenger head...
here are other photos of the pump which is almost all the way removed... just need to cut up and pull out the plastic reservoir sitting underneath the drivers side intake manifold... and i'll be using the flange that i took off to make a blockoff plate for the drivers side and reuse the metal gasket and bolts from the original.
TROLL is offline   Reply With Quote
Old 09-26-2007, 08:54 PM   #75
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
to followup, i found out some more info that 07 STi owners will want to know... and this applies to 07 STi's specifically (possibly 08+ but i dont know yet...).
the atmospheric pressure sensor is integrated into the valve for the air pump, so removing it will cause an error in the way the car reads atmospheric pressure and as a result it will cause an error in the way it reads manifold relative pressure as well, throwing things off across the board.
my logs were only showing 11 psi max (manifold pressure) because by removing the atmospheric presusre sensor which is in the air pump valve, it was throwing an error and defaulting to 21.76 psi instead of 14.7 psi.
so... solution was to replace just the valve itself. i kept the blockoff plate on the head, i did not reinstall the air pump itself, just the valve unit using the black bracket that it came with to secure it in teh engine bay. once that was bolted down i plugged in the connector clearly shown in the photo and now all is well... atmospheric pressure works properly and as a result manifold pressure works as well.
silver unit pictured below is the valve, black connector on the top is the wiring. both were reinstalled. the atmospheric pressure sensor is integrated into this one way or another. black hose coming off the left was not reinstalled, and hardline that leads to the head was also not reinstalled.
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 09:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 11:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 08:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 10:25 PM
