Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 08-26-2013, 09:37 PM   #801
JonnyV2889
Member#: 197384
2006 WRX Ltd
Originally Posted by Leafy View Post
It was easier to just tap the port in the head and thread a bolt in with a copper washer than try to extract the ones I broke off. Tough I didnt have the luxury have having the engine out.
Done it both ways (plates & bolts). Use grease to hold chips from dropping in the head.
JonnyV2889 is offline   Reply With Quote
Old 08-26-2013, 09:42 PM   #802
Leafy
Member#: 330625
2006 WRX
Yeah my drivers side is a plate and the passenger side is a bolt. I wasnt too concerned about chips, I let them fly, at worst they mess up the turbine blades on my td04. More than likely they just chill at the lowest point of the headers.
Leafy is offline   Reply With Quote
Old 09-03-2013, 07:42 PM   #803
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
For the 06 can I just delete the CEL and be ok if the codes are just pulling for the secondary air pump, p0410??
breezeby is offline   Reply With Quote
Old 09-04-2013, 10:07 AM   #804
123mfg
Member#: 360741
2006 WRX Wagon
FWIW, I have an 06, just got finished with removing air pump and all pipes associated with it. I did however plug in the (pressure sensor?) that is located on the drivers side. This was done in conjunction with a Cobb Stg 2 and ACT HD Clutch and streetlite flywheel. I have about 150 miles on it with no CEL yet. I read some posts that say you don't need to plug in the sensor, but until I get time to test, I can't be sure if you can leave the two sensors unplugged when eliminating the air pump system and not get a CEL.
123mfg is offline   Reply With Quote
Old 09-04-2013, 10:10 AM   #805
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
WRX or STI ?
1 Lucky Texan is offline   Reply With Quote
Old 09-04-2013, 10:34 AM   #806
breezeby
Member#: 132658
07 TR vf39ed
i was just thinking on deleting the CEL's, would this be an issue? anyone think
Old 09-04-2013, 11:13 AM   #807
123mfg
Member#: 360741
2006 WRX Wagon
Originally Posted by 1 Lucky Texan View Post
WRX or STI ?
06 WRX Wagon
Old 09-04-2013, 11:18 AM   #808
123mfg
Member#: 360741
2006 WRX Wagon
I will have to research the FSM, but my opinion is that if you delete the CEL relating to the pressure sensor the car may run, but not run optimally. Think "electrical tape over the check engine light" I am not 100% sure, but that sensor allows the ECU to adjust boost based on atmospheric pressure.
Old 09-04-2013, 12:07 PM   #809
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
06 WRX Wagon
hmmm, didn't think we had a sensor in our valve.
Old 09-04-2013, 12:09 PM   #810
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
my valves are stick closed and I just deleted the codes - 14-15 of them )it's in this thread WAAAAAY back up there somewhere)
no problems years later. (I may have the parts pulled and plates installed if the engine ever comes out)
Old 09-04-2013, 12:42 PM   #811
breezeby
Member#: 132658
07 TR vf39ed
P0410 ?
Old 09-04-2013, 01:12 PM   #812
123mfg
Member#: 360741
2006 WRX Wagon
Well, I wasn't sure either. The sensor looked similar to what some folks posted who owned 07+ and when I looked at the wiring diagram in the FSM one of the two valves shown was labeled "SECONDARY AIR COMBINATION CUT VALVE LH (WITH BUILT-IN PRESSURE SENSOR)" So, I am assuming that my car has that sensor. I have not checked the build date on the mfr tag; maybe mine is a late 06? I have looked into this some more but cannot find out what the pressure sensor does or what other systems it is affected by.
Old 11-08-2013, 05:30 AM   #813
TxFxL
Member#: 212702
2007 WRX Wagon
Grey
Default 07 air pump removal
hi all, i have read this thread and searched for my specific question but haven't seen it anywhere so i'm reaching out. if i missed it and its already been said elsewhere a link would be greatly appreciated.
i have the 07 wrx and one of the valve stuck closed codes. i know that i can't simply unplug both air re-circ pumps because i have the atmospheric sensor in one of them. i have no interest in making my car lighter or my engine bay less cluttered at this point. i work a ton so i am trying to handle this with the least time spent as i can. i have contacted a reputable tuner in my area over the phone and the code clearing/computer flashing part of the job is lined up, at least in principle.
what I'm hoping to do is to leave both the valves and the pump in place. I'm thinking i can unbolt and remove the crossover tube and install my block off plates from under the car. would this be feasible? i'm a former auto mechanic (now in factory based assembly work) so i'm sure i'll have all the tools needed. are the bolts accessible for removing the crossover tube accessible from under the car?
thanks for your time and apologies in advance for the noob question
TxFxL is offline   Reply With Quote
Old 11-08-2013, 08:16 AM   #814
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
If both valves are stuck closed, and you don't care about leaving them, just delete the codes. no need to remove any parts including the xover.
Old 11-08-2013, 08:20 AM   #815
Leafy
Member#: 330625
2006 WRX
But there have been reports of valves going from stuck closed to stuck open.
Old 11-08-2013, 08:38 AM   #816
TxFxL
Member#: 212702
2007 WRX Wagon
Grey
As of now only one valve is stuck closed, getting the p2443 code. Pretty sure that's the exact code, at work right now
Old 11-08-2013, 08:44 AM   #817
TxFxL
Member#: 212702
2007 WRX Wagon
Grey
I have been clearing the code when it comes up (usually once every 2 weeks or so) but I have my inspection coming up in January so I'm trying to get ahead of this problem
Old 11-08-2013, 08:46 AM   #818
JonnyV2889
Member#: 197384
2006 WRX Ltd
I would pull power to valves and pump, and seal up the connectors on the harness side. Disable DTCs and call it a day.
Old 11-08-2013, 10:08 AM   #819
TxFxL
Member#: 212702
2007 WRX Wagon
Grey
I have to leave power to the valve with the atmospheric sensor though, or else it will run like crap right?
Old 11-10-2013, 12:51 AM   #820
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I have no idea what the stats are. I think I'm going on about 3 years now. No issues.
Seems to me, if they are corroded enough the solenoid can't move them, they are unlikely to drift open.
Old 11-10-2013, 11:42 AM   #821
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Leave the two valves and the air-pump in place and leave all the electrical connectors plugged-in. (You can remove the air-pump later to free up some under-hood space).
Remove the RH (driver's side) tube going from the valve to the head and install a block-off plate (and OEM gasket) onto the head.
Leave the LH (passenger's side) tube in place (because you can't remove it without removing the intake manifold), cut the mating-head off of the tube where it is attached to the engine-head, and install a block-off plate (and OEM gasket) to the head.
Have a tuner or similar shut-off the codes for the air-pump and secondary valves, but not the atmospheric sensor.
Old 11-10-2013, 11:44 AM   #822
TxFxL
Member#: 212702
2007 WRX Wagon
Grey
Thanks so much, exactly the information I was looking for, good on ya!
Old 11-13-2013, 03:53 PM   #823
sime
Member#: 45275
2007 wrx
98 2.5rs,89 & 95 240sx's
Having local dealership put KStech blockoff plates on my 07. Costing like $400 but didn't like the idea of taking off the intake manifold myself. also having them replace the oil pan and oil pickup. And i'm going to have them keep the parts so i can put the atmospheric sensor back inplug after i mod it.
sime is offline   Reply With Quote
Old 11-13-2013, 05:48 PM   #824
JonnyV2889
Member#: 197384
2006 WRX Ltd
You don't have to remove the intake Mani to do the job.
Old 11-13-2013, 06:14 PM   #825
sime
Member#: 45275
2007 wrx
yeah but its 20 degrees here right now and i dont want to hack at my car trying to get the passenger one out from under the intake. No garage here.
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
