Old 12-08-2007, 03:22 PM   #76
DZnutz
Member#: 91837
thanks for that update wrinkleboi... and here i was about to yank it off my 07
DZnutz is offline   Reply With Quote
Old 12-12-2007, 01:22 PM   #77
Mechie3
Member#: 120152
Don't know if the 06 wrx's are the same, but my car has been running fine without it. Did you have a total of 2 valves or just 1? I had a valve over the transmission on the driver side and one under the intake manifold on the driver side.
Mechie3 is offline   Reply With Quote
Old 12-12-2007, 01:29 PM   #78
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
as the photos i posted above show, the 07 STi is different... one valve and the atm. pressure sensor is integrated into the air pump.
TROLL is offline   Reply With Quote
Old 12-12-2007, 01:40 PM   #79
Mechie3
Member#: 120152
All right. I wasn't sure since you said you didn't have a valve on the passenger head, but both of mine were on the drivers side (ie, 2 valves, none on the passenger head). Did your car run really lean/rich or rough with the valve disconneted? My mileage has been roughly the same (went stage 2 since then, etc) so would there be any other way to notice that the ECU is disconnected from the atm sensor?
Thanks.
Old 12-12-2007, 01:42 PM   #80
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Log your barometric pressure, map, mrp..
ExpO is offline   Reply With Quote
Old 12-12-2007, 02:42 PM   #81
The Head
Member#: 98143
04 Cayenne TT
05 SL65, 03 GSXR1000
I'll try to get a pic of mine. It has the same sensor in it (06 FXT) and the wiring diagram in the Subaru service manual indicates it is a sensor as well. No problems running without mine either.
The Head is offline   Reply With Quote
Old 01-23-2008, 03:21 PM   #82
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
i'm almost positive that the 06 WRX does not have this sensor integrated into the valve i am talking about.
i was logging with enginuity trying to monitor some key values including boost and it was only reading 11 psi max ever (my gauge indicated 17-18 psi), so something obviously wasnt right. i dont know what this would affect on the car but it was not tuneable this way and i'm not sure if it would trigger the overboost fuel cut either.
Old 01-23-2008, 03:47 PM   #83
DZnutz
Member#: 91837
^ did you leave any tubes connected to the valve? or did you simply cap both ends of the valve?
or did you blockoff the head and then leave the valve uncapped?
Old 01-23-2008, 03:51 PM   #84
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Have you looked at any wiring diagrams? It may just be the signal running through that plug, not the sensor itself. In which case you could get a plug and wire it to work.. just a though.
I just removed my airpump w/ the buschur plates, still waiting on other parts to put it back together
Old 01-23-2008, 04:16 PM   #85
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
the head was blocked off and either side of the valve was left open since it is no longer part of the system. there is nothing connected to the valve any more, i stripped off everything that i reasonably could. all that remains is the valve itself and the bracket to attach it to the engine.
hmm, someone on enginuity.org helped me troubleshoot the problem and i decided to try plugging that valve back in, it fixed the problem and i never thought more about it. i have not looked at wiring diagrams myself so i'm not sure how things are arranged specifically, but thats an interesting thought.
Old 01-23-2008, 04:51 PM   #86
ronzogonzo
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
ronzogonzo is offline   Reply With Quote
Old 02-22-2008, 04:53 PM   #87
KSTech
Member#: 143570
Originally Posted by ronzogonzo View Post
W00T! Thanks for the plug, Phil.
Does anybody know what the valve situation is on the 2008 WRX or STI? Does it just have the injection into the driver side cylinder head... or both... or what?
Thanks...
Matt
KSTech is offline   Reply With Quote
Old 02-22-2008, 06:42 PM   #88
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Well seems all 07+ Subaru's come with a special pollution control device.
tux121 is offline   Reply With Quote
Old 02-22-2008, 06:51 PM   #89
David Buschur
Member#: 24301
2006 WRX 345hp/345tq
David Buschur is offline   Reply With Quote
Old 02-22-2008, 06:58 PM   #90
WRFX
Member#: 149789
Originally Posted by David Buschur View Post
Just bought some yesterday.
WRFX is offline   Reply With Quote
Old 02-22-2008, 07:46 PM   #91
Geeoff
Member#: 106439
06 WRX TR
'05 Matrix XRS
Thanks...
Matt
Just got my block-off plates today in the mail, thanks!
Geeoff is offline   Reply With Quote
Old 02-23-2008, 02:21 AM   #92
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
Quick question.....I'm having my car tuned on the 2/29/08 by Jorge from P&L..Will he be able to turn off the codes that will come on by removing the air pump? If so then I'm going to have him do that.
06grayrex is offline   Reply With Quote
Old 02-23-2008, 03:25 PM   #93
FaisalT
Member#: 107097
09 Etnies
Gray/Black
yes, make sure he disables all codes related to the secondary air pump.
As soon as i turned mine on I got p2431, p2433, and p2444. My tuner disabled those, and a few days later I got p0410, after I disabled that I got p0411 so I disabled them all. The whole system is gone, might as well.
FaisalT is offline   Reply With Quote
Old 02-23-2008, 04:13 PM   #94
WRFX
Member#: 149789
will the car still run fine with these codes triggered? I probably won't be able to meet with my tuner until a couple weeks after the removal.
Thanks
Old 02-23-2008, 04:19 PM   #95
rhinotech
Member#: 144880
03 Civic
Rollin' hard...
Yes it will run fine,....
you wont have cruise...is all...
rhinotech is offline   Reply With Quote
Old 02-26-2008, 03:10 PM   #96
Stiletto
Member#: 28415
2011 WRX 5dr
Matte black
Why would you lose cruise control by deleting emissions equipment and it's subsequent CELs? Is this applicable to the 06 WRX as well?
Stiletto is offline   Reply With Quote
Old 02-27-2008, 10:17 AM   #97
x99percent
Member#: 27108
2004 STi
2004 A4
On DBW cars, you lose cruise control when you have a CEL. That's all he was saying.
Fix the CEL, and cruise control works again.
x99percent is offline   Reply With Quote
Old 02-27-2008, 10:41 AM   #98
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Never found this thread when I did my block offs about 4-5 months ago.
The 06 WRX does have both valves and the pump. The drivers side valve and hard lines are not too bad to get off. The passenger side is a PITA. What I did was take off the up-pipe, downpipe, and disconnect the inlet tube and then with some twisting and finesse you can lift the hard line and valve out.
I did this when I installed the FMIC and it really does clean up the engine bay.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 02-27-2008, 10:51 AM   #99
Mechie3
Member#: 120152
I took a dremel to my passenger hardline to get it out. Cut it in half and was done with it. Definitely cleans up the engine bay and drops some "useless" weight.
Old 02-27-2008, 10:54 AM   #100
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Also forgot to mention I tune with Enginuity (RomRaider) and disabled all the codes (15 of them) and never had a problem.
-Rene
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
