Welcome to the North American Subaru Impreza Owners Club Wednesday October 22, 2014
Old 11-21-2008, 02:00 PM   #176
SatinWhitePearl
Member#: 170780
2007 STi
Satin White Pearl
Originally Posted by Mechie3 View Post
On my 06 WRX I removed the black snail pump, the rubber hosing, both solenoids, and the hardline to the passenger side with no ill effects. I did not ground out any wires at all.
07 STI's only have 1 solenoid. I don't know if this functions differently that the 06 WRX in terms of the pressure sensor.
Thanks!
Bump for more info!!
-Chris
SatinWhitePearl is offline   Reply With Quote
Old 11-21-2008, 02:13 PM   #177
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Originally Posted by SatinWhitePearl View Post
So what exactly can be removed? Sorry if my questions seems somewhat repetitive, but I'd like to know if only the black snail looking pump gets removed or more can be removed?
-Chris
Everything. You just need the atmospheric pressure sensor plugged in for things involving relative pressure such as boost control.
gabedude is offline   Reply With Quote
Old 11-21-2008, 04:35 PM   #178
SatinWhitePearl
Member#: 170780
2007 STi
Satin White Pearl
Perfect, with that being said, you just leave that solenoid and call it a day...everything else is removed?
I really would love to remove the solenoid....but I guess we can't
Thanks,
-Chris
Old 11-27-2008, 03:37 PM   #179
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
This is what I removed
One of the stupid Ksketch plate was off, the holes where not concentric to the bolt holes so I have to fix them. Do you guys remove these two solenoids as well?
Old 11-28-2008, 01:14 AM   #180
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I removed the same as you. Only had to disable 2 codes. Most seem to leave these alone...since they generate a bunch of other codes, and also contain one of the pressure sensors. I forget which, but it is covered earlier in the thread.
aboothman is offline   Reply With Quote
Old 11-28-2008, 03:05 PM   #181
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
On my 06 WRX, everything is removed, car runs great, no codes, and was tuned by one of the best tuners in the world... Clark Turner.
I have yet to see any evidence or proof that anything is needed if tuned out correctly.
irascible is offline   Reply With Quote
Old 11-30-2008, 10:02 PM   #182
Mechie3
Member#: 120152
I took out the solenoids and put the plates directly on the back of the heads.
Mechie3 is offline   Reply With Quote
Old 12-01-2008, 12:10 AM   #183
Nuke209
Member#: 108089
2003 WRX
NF Performance
06-07wrx, you remove the solenoids and pump, and block off both heads
07sti (not sure about 08+), remove pump, but block off driver side head and leave solenoid in for the atmospheric pressure sensor (or car will go coo coo)
Nuke209 is offline   Reply With Quote
Old 12-05-2008, 09:04 PM   #184
valetudospang
Member#: 144007
Haha I did the same thing. I believe you need to take that plate off of the valve and put it on the passenger side of the block. That why it doesn't fit well.
valetudospang is offline   Reply With Quote
Old 12-27-2008, 09:44 PM   #185
ejones707
Member#: 196976
2008 STi
Having a problem on an STi here as well.
Code is deleted but comes back every time I start the vehicle.
Is it a problem with the Cobb - and the code is not actually doing what it is targeted for?
ejones707 is offline   Reply With Quote
Old 12-28-2008, 03:48 AM   #186
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
OK, so before my most recent tune I removed both sensors as well. As several have already said, it runs great once the codes are deleted. TGVs deleted as well with no negative effects
Old 12-28-2008, 09:58 AM   #187
gabedude
Member#: 10108
07 STI
I guess the ATM Pressure sensor is somewhere else on the 06-07 WRX.
Old 12-28-2008, 02:22 PM   #188
[D.I.]WRX
Member#: 116314
I took out both sensors with all the piping as well....only problem i had was having more room in the bay
[D.I.]WRX is offline   Reply With Quote
Old 01-27-2009, 01:19 PM   #189
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
can anyone report on the presence of an "atmospheric pressure sensor" on the '08 sti's that might impede removing this system entirely. Need to free up space on top of my engine .
Frank
Frank A is online now   Reply With Quote
Old 01-29-2009, 04:20 PM   #190
sch3838
Member#: 154636
does anyone have step by step DIY guide?
sch3838 is offline   Reply With Quote
Old 01-29-2009, 05:30 PM   #191
bzbuzz
Member#: 116052
2011 STI ( Sold )
http://www.iwsti.com/forums/how-inst...p-removal.html
it's based on a sti but you get an indea..
bzbuzz is offline   Reply With Quote
Old 01-29-2009, 08:43 PM   #192
sch3838
Member#: 154636
thanks!
Old 02-14-2009, 11:33 PM   #193
sama lama
Member#: 136231
95 LX Impreza
blue
On some high revving race motors they use air pumps as crank case vent pumps. On a ZX12R website they do the same thing its said to help ring seal and flutter it makes negative crank pressure so the pistons should move freely.
sama lama is offline   Reply With Quote
Old 02-15-2009, 12:43 AM   #194
kh15
Member#: 132400
im STILL trying to decided whether or not to pull the pump on my
06
kh15 is offline   Reply With Quote
Old 02-24-2009, 04:54 PM   #195
rmstires
Member#: 113914
2010 STi
Gray
WTB air pump and all pipe and valves involved for 2006 WRX. PST if your willing to part with yours.
rmstires is offline   Reply With Quote
Old 04-12-2009, 07:38 PM   #196
kh15
Member#: 132400
i have 2 question..
1. when i couldnt get the passengers side hose off so i decided to just leave it and cap of the air valve thats next to the intake manifold (the one with the red dot in the picture) well somehow i forgot to and drove around for a day without it capped off! could this have caused any damage? was air able to get into the heads because of this? or was exhaust able to escape through this? I assuming only air can enter the heads through these ports and exhaust still goes down through the exhaust?
2. i have since capped off that valve since its still connected but i just left the other valve alone since its basiclly just sitting there.
can i remove these 2 valves or at least 1 of them?
doesnt one also contain the atmospheric pressure sensor?
oh and the atmospheric pressure sensor is in the ecm for 06 wrx models...
Old 04-16-2009, 05:46 PM   #197
Vid_Maye
Member#: 154197
2006 Impreza WRX
WR Pearl Blue
Dag nabit, I'm throwing the p2443 code as well now. Advance auto read the code and it printed out as:
P2443 Sec.Air Inj.System
Switching Vlv Stuck
Closed Bank 2
I've read through the entire thread and I don't see any mention of unsticking this valve. Is it possible to get to it and unstick it or does it need replacing all together? Or would removing it and killing the CEL be better?
Vid_Maye is offline   Reply With Quote
Old 04-29-2009, 09:31 AM   #198
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 TurboTektuning
The air pump purging/venting the crank case killed the deal for me. Our engines produce a ton of blowby, every bit of equipment that helps minimize blowby is worth keeping IMHO
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 05-08-2009, 11:11 PM   #199
silentt
Member#: 119995
2004 Outback XT
Peachy
Do you need to block off the solenoid for the 07 STI or can it be left alone?
silentt is offline   Reply With Quote
Old 05-13-2009, 04:12 PM   #200
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Colin! :(
When I unhooked the valves on my 07 WRX I found that like the STI one of my valves has an atmospheric pressure sensor in it. I had to hook it back up to get the ECU to see boost correctly again. The car did however drive just fine with out it. I had the car hooked to a wide band at the time and the air fuel #s did not change. But the ECU showed a max of about 7.5psi. I'm tuned for 17.5psi. It also showed vac as high as 20.3. Normal vac for my car is around 10.3.
I hooked every thing back up as I was not sure why this happened until I read this thread.
Is it possible to put an 06 WRX ECU in an 07 WRX? Would this allow me to remove the 2nd valve and not have the ECU seeing the wrong manifold pressure?
Also on the car that reportedly had problems when this was unhooked I have a theory. That car had a bad ground some place in the system to start with and unhooking the valve removed what ever ground it did still have.
Later.
Badmunky is offline   Reply With Quote
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
