Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Mid Atlantic Impreza Club
Old 02-24-2007, 10:21 PM   #1
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
Default Bigger turbo and AP question
If I was to go with a bigger turbo does access port or any other engine management system still work once the turbo is installed? Just a question that has been on my mind for some time. Im trying to decide in the future if i should go with a bigger turbo.
dumpstercrusher is offline   Reply With Quote
Old 02-24-2007, 10:29 PM   #2
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
When you do something that drastic, you will need a new tune.
But yes, there are engine management systems that are flexible enough to handle that change. Hang out in the Factory 2.5L forum and the various engine management forums.
john
Old 02-24-2007, 10:33 PM   #3
siopao2000
Member#: 63247
2014 XV Crosstrek
Desert Khaki
doesn't cobb have "vfxx" OTS maps?
siopao2000 is offline   Reply With Quote
Old 02-25-2007, 12:52 AM   #4
Matt_H
Member#: 107000
2015 BMW X1
Here is a list of every map that comes preloaded on a V2 Access Port.
Anti-Theft
Economy Mode
FP18G 91
FP18G 93
FP18G ACN91
Stage1 91
Stage1 93
Stage1 ACN91
Stage2 91
Stage2 93
Stage2 ACN91
Stock Mode
VF39 91
VF39 93
VF39 ACN91
Valet Mode
Matt_H is offline   Reply With Quote
Old 02-25-2007, 08:44 AM   #5
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
That's the basic point of having aftermarket EM systems ... to accomodate modifications to the car. An AP will definately handle any turbo you want to throw at the car as long as the rest of the car is adequately modified (injectors, etc) to support it.
Car vs. Driver is offline   Reply With Quote
Old 02-25-2007, 08:46 AM   #6
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Anti-Theft
Economy Mode
FP18G 91
FP18G 93
FP18G ACN91
Stage1 91
Stage1 93
Stage1 ACN91
Stage2 91
Stage2 93
Stage2 ACN91
Stock Mode
VF39 91
VF39 93
VF39 ACN91
Valet Mode
What he's trying to say is...
Cobb has maps for an FP18G and a VF39 on an '06 WRX. Anything else will require a custom tune.
Jard is offline   Reply With Quote
Old 02-25-2007, 09:32 AM   #7
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
Is there any turbo's that i can just bolt right on and dont have to worry about the fuel injectors or fuel pump?
Old 02-25-2007, 09:33 AM   #8
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Yes, with an '06 you should be able to run up to an 18G without changing injectors. Fuel pumps are cheap, like $100. I would do the pump just for fun.
Old 02-25-2007, 09:49 AM   #9
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
You will still need engine management and a tune, you cannot simply bolt in a turbo and go without expecting potentially disastrous results.
Old 02-25-2007, 10:05 AM   #10
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
Im looking at http://blouchturbo.com/turbos/result/, does it matter which of the 18g turbos you get to put into your car, which you dont have to change fuel injectors? Because it is showing 4 different types and i dont know if for all 4 you dont need a change.
Old 02-25-2007, 10:06 AM   #11
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
I guess that makes more sense.
Old 02-25-2007, 10:34 AM   #12
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Yes, sorry. My post about not changing injectors was still assuming you already had an AccessPort.
Old 02-25-2007, 12:37 PM   #13
TurbojonLS
Member#: 38772
2 Cars, No Bling
They all have the same size compressor wheel, so no.
TurbojonLS is offline   Reply With Quote
Old 02-26-2007, 06:59 AM   #14
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
If you switch to an 18G you will definitely, absolutely, pisitively need some sort of aftermarket engine management. Cobb AP, UTEC, reflash, etc. I would also recommend a custom tune. I gained about 30WHP over the "stock" Cobb Stage 2 map after I was tuned.
Old 02-26-2007, 01:03 PM   #15
synergyknight
Member#: 136921
2006 STi
your UTEC or AP will still work with whatever turbo you decide to put on. you can have someone tune your car for whatever setup you have, then they can load that map onto your AP or UTEC, so you can still use your EM after you upgrade.
synergyknight is offline   Reply With Quote
LOOKING TO BUY VF39 STI Turbo Or other bigger turbos and Bigger than STock Top Mount alieus RMIC Private Classifieds 2 08-03-2007 02:17 AM
Going to a bigger turbo.. and got a few questions. 03WRX83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-01-2004 10:28 PM
Yeah, so I need a bigger turbo and a dogbox DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 15 03-23-2004 10:55 PM
How many are running bigger turbo and TMIC without heatshield? MAD REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-22-2003 11:02 AM
Bigger TURBO and What else to go with it??? ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-11-2002 03:40 PM
