Old 12-04-2001, 12:10 AM   #1
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default fix for noisy Whiteline front swaybar
for those with the Whiteline BSF33 on their WRX sedans, I was experiencing a clunk/clack sound in my front end with that bar. After much inspection and having people shake the car from above, I determined that the noise was definitely coming from the endlink.
I went to Home Depot and bought a few washers (about an inch across, maybe 1/16" thick, big enough to fit over the endlink bolt). One washer behind each end of the bar on the bolt fixed the problem.
My bar was apparently a little too narrow from side to side so the endlink was being pulled into a bad angle, causing much binding and noise. Putting the "spacers" in place reduced the effective width of the endlinks and fixed my noise problem.
washers were 5 cents apiece.
-nick
nhluhr is offline   Reply With Quote
Old 12-05-2001, 11:04 AM   #2
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i guess nobody else had this problem?
oh well.
Old 12-05-2001, 11:10 AM   #3
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
I had the same problem in the rear (don't have the front yet). the nylon in the bolts wasn't holding so they kept backing out.
i check them every couple of weeks to make sure they're tight (i insepect it all before an AutoX anyway)
Orion is offline   Reply With Quote
Old 12-06-2001, 11:39 PM   #4
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
update -
after a couple days, my bar is making the same noise again. I am now suspecting (as above) the bolts are getting loose prematurely and am now going to bust out some red loctite. ARgh! will this noise never go away?!?
Whiteline front swaybar clunk found: fixes? Pain++ Brakes, Steering & Suspension 6 05-08-2007 10:23 PM
Whiteline Front Swaybar for a 05 STi - BSF36XZ rankink Private 'For Sale' Classifieds 2 03-28-2006 09:33 AM
Looking for whiteline FRONT swaybar mounts/bushings Achilles38WRX Private 'Wanted' Classifieds 0 03-24-2004 02:24 PM
Whiteline front swaybar for BE/BH Legacy BrokenCrank Private 'For Sale' Classifieds 1 10-07-2003 07:29 AM
Whiteline front swaybar for D stock? gotsol Brakes, Steering & Suspension 2 01-10-2003 10:56 AM
