Old 02-25-2007, 01:18 PM   #1
Jhovany
Member#: 137317
2006 STI
Rally Blue
Default APS SR56 Turbo
I just got my car back from dyno comp in Scottsdale, AZ....got all my stuff installed (APS SR56 turbo, APS DR525 FMIC, APS 70mm Intake, TGV deletes, Walbro Fuel pump, 850cc Power Enterprise injectors, split fuel rails, APS B.O.V., and a protune cobb accessport) and I put down on their dyno 335AWHP. I will have to admit, it is very laggy and no quite producing the power that I wanted (I atleast wanted 350awhp) I am running on 91 octane and suggestions or opinions????
Jhovany is offline   Reply With Quote
Old 02-25-2007, 01:21 PM   #2
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
Take it back and ask for more. They should oblige you.
nicholam is offline   Reply With Quote
Old 02-25-2007, 01:43 PM   #3
lev98
Member#: 140529
01 Ferrari 360 spy
what kind of dyno was it
lev98 is offline   Reply With Quote
Old 02-25-2007, 01:49 PM   #4
2TG8V
Member#: 67335
2015 wrx
You need either 93 octane or 91 with meth.I usually mix 3 gallons of 100 octane with the rest 91 this gives me around 93.
2TG8V is offline   Reply With Quote
Old 02-25-2007, 01:51 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
how much boost are you running? post your tune
fastnoypi is offline   Reply With Quote
Old 02-25-2007, 01:55 PM   #6
nubesube02
Member#: 77708
02 wrx
platinum silver
meth and retune
nubesube02 is offline   Reply With Quote
Old 02-25-2007, 02:23 PM   #7
Sypher
Member#: 106366
2006 WRX
^^^^^^^^^ ditto but that is loooooooooow what psi? Or maybe your tuner just suks
Sypher is offline   Reply With Quote
Old 02-25-2007, 04:36 PM   #8
import111
Member#: 24447
2010 Evo GSR
GG
Dyno Comp has been known to tune VERY safe. I am sure there is much more power to be had out of your setup.
import111 is offline   Reply With Quote
Old 02-25-2007, 04:56 PM   #9
Andrew
Member#: 1170
2005 STi
335 sounds weak. I thought 49lb turbos put out 350whp on 91. A 56lb should be about 385
Andrew is offline   Reply With Quote
Old 02-25-2007, 07:36 PM   #10
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
i have a friend that is making close to 400 with that setup
Poweredbysnail is offline   Reply With Quote
Old 02-25-2007, 09:10 PM   #11
Jhovany
Member#: 137317
2006 STI
Rally Blue
How is your friend have on his car that he is making 400??? how much does a meth kit cost or should i just go with a different turbo?? if yes....what turbo???? and a rotated mount is not an option at this time maybe in the future! Richard Garcia @ dyno comp tuned my car and i think he does a wonderful job its just that i want MORE out of the setup that i have ALSO.....should i get some type of boost controller and crank it up (within reason of course)?? oh and i am at 19psi
Old 02-25-2007, 09:19 PM   #12
Poweredbysnail
Member#: 74753
Team Snail
same set up and dyno comp tuned
Old 02-25-2007, 09:22 PM   #13
Jhovany
Member#: 137317
2006 STI
Rally Blue
im not understanding.....did your friend just ask for it to be tuned to 400awhp??? or is he running on 100 octane....in other words what is he doing that I am not?
Old 02-25-2007, 11:48 PM   #14
AlSickinger
Member#: 116594
Richard Garcia is an excellent tuner. His dyno reads very very low. Did he do a baseline run on what your car was putting down stock? That way you could truly see what type of gains you got.
AlSickinger is offline   Reply With Quote
Old 02-26-2007, 02:14 PM   #15
Jhovany
Member#: 137317
2006 STI
Rally Blue
what kind of gain will i get with a meth kit with this setup?
Old 02-26-2007, 02:27 PM   #16
Andrew
Member#: 1170
2005 STi
a meth kit is going to cost 2 dollars more a gallon to run
Old 02-26-2007, 02:41 PM   #17
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Dyno numbers are useless without a baseline....
conker69 is offline   Reply With Quote
Old 02-26-2007, 02:54 PM   #18
Jhovany
Member#: 137317
2006 STI
Rally Blue
well before when i had just my invidia downpipe, hks hi power exhaust, cobb accessport stage 2, injen short ram intake i put down 269whp and 279lb torque (on a different dyno thats the problem) and at dyno comp after installing the turbo i put down 335whp and 319lbs torque. I want WAY more power what should i do....can i just buy a boost controller and turn up the heat??? or should i buy a different turbo?
Old 02-26-2007, 02:57 PM   #19
Jhovany
Member#: 137317
2006 STI
Rally Blue
what do you mean by this???
Old 02-26-2007, 03:02 PM   #20
conker69
Member#: 59692
WRB-Gold
You can't compare those numbers. You can only compare your car prior to any changes on the same dyno, on the same day. Without that information the numbers you get are rather useless.
Old 02-26-2007, 03:15 PM   #21
Andrew
Member#: 1170
2005 STi
I mean that along with your standard gas fillup you will be paying 2 dollars on top of that to run the car. So expect to pay 5 bucks + a gallon.
Old 02-26-2007, 03:22 PM   #22
Jhovany
Member#: 137317
2006 STI
Rally Blue
Well regardless of the actual numbers....i just want more power!!! that is the objective....you are right...numbers are useless....but again i just want to be way quicker and faster....any suggestions????? my car is laggy right now.....and is not going anywhere fast!! i guess my question to the public is....which is the ultimate bolt on turbo for an 06 STI?
Old 02-26-2007, 07:02 PM   #23
STIred05
Member#: 115223
2005 Subaru STI
If you want to stay bolt on go w/ a FPred 8cm housing and Meth. I don't know for sure how much more it will cost you to run meth, but I have a really hard time beliveing that it would cost $5 + a gallon to run it... That is why they call meth the poor mans race gas.
If you want great power go w/ a rotated mount or the red or other turbo's close in size. The red from personal experience will come on just before 4k w/ the 7cm housing and the 8cm should be at about 4100 ish.
STIred05 is offline   Reply With Quote
Old 02-26-2007, 07:14 PM   #24
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
In regards to lag, you just have to learn where to put the car in the RPM range before you go. Don't try and gun it from 2500 RPM cuz you're not goin anywhere that low.
Have you even talked to Rich about this?
Black-Falcon is offline   Reply With Quote
Old 02-26-2007, 10:24 PM   #25
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Can you post a dyno sheet? Have you talked to rich about this? have you done a compression test on the motor? Your power numbers seem low, but it would be good to know what you put down before the tune. To gauge what kinda power you put down.
DoctorNick is offline   Reply With Quote
APS SR56 Turbo on 2008 Midevil Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 04-01-2008 07:00 PM
APS SR56 turbo Jhovany Proven Power Bragging 40 06-17-2007 01:42 AM
TX: APS SR56 Turbo w00dst0ck Engine/Power/Exhaust 12 05-05-2007 01:09 AM
APS SR56 Turbo Jhovany Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 02-11-2007 06:21 PM
Quick APS SR56 turbo question! Jhovany Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 01-27-2007 01:41 AM
