02-25-2007, 04:15 PM | #1 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
Starting and Idling Issues
OK, it looks like I solved my original problem of slow cranking with getting a new battery. But the car still cranks forever before it will actually kick over and start. It will pop and fart like it wants to start, but then keeps cranking. All the while, I'm blipping the throttle to try and get it to start. Finally it starts and I have to keep revving it in order to keep it running. If I go off throttle, it will sputter for a second or two at 700-800RPM and then die out.
Also, no matter what RPM I'm at, the wideband is showing about 15:1 to 17:1. I figured no biggie, it's not following the idle target table because its to lean. So add some fuel into the fuel map and all should be well. Well I added fuel into the fuel map and the AFR didn't change. What am I missing here?? Thanks, Tim
02-26-2007, 12:59 PM | #2 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Let's start here:
1. What hardware revision do you have? 2.0 box or 2.5 box? 2. Whose map are you using? 3. What injectors are you using? Better yet, list all of the car's mods. 4. You added "some fuel". Define "some fuel". As in... where in the fuel map did you add it, how much did you add (percentage)... etc. Could be 1 or many of about ... 30 things going wrong. |
02-26-2007, 01:11 PM | #3 |
Member#: 44351
2.1 box running 2.14 software
Phil sent me a base map for 1000cc low impedence injectors. Wiseco pistons (8.9:1) Pauter rods stock crank stock heads and cams KingPin GT35R kit FUEL SYSTEM ***167; Walbro 255 L/hr intank pump ***167; Aeromotive A1000 external pump & filter ***167; Custo designed swirl pot ***167; Aeromotive fuel pressure regulator ***167; -8 braided lines supply ***167; -6 braided lines return ***167; Ultimate racing 1000cc injectors ***167; Ultimate racing fuel rails ***167; Custom mounting tray ***167; All mounting hardware and fittings APS FMIC That's all the important mods that I can think of. Once I got the car to start, I was holding it at about 2000RPM and the cell that was yellow, I added some fuel in. For example, if the number was .9, I bumped it up to 1.2 without any change in the AFR. |
02-27-2007, 09:09 AM | #4 |
Member#: 44351
Everyone remember to make sure your plugs aren't fouled out.
02-27-2007, 05:32 PM | #5 |
Member#: 8512
South East
That was EXACTLY the next question.
02-15-2012, 02:42 PM | #6 |
Member#: 288311
NESIC
Vehicle:2002 WRX A/T Wagon Aspen white |
#3 Loves going first being right next to the turbo, I'm pretty sure it's from turbo heat but hell I could be wrong!!! Next time you change plugs compare the other plugs W/#3
02-15-2012, 02:48 PM | #7 |
Member#: 8512
South East
This thread was 5 years old that you replied to
Won't start, having idle issues | KKoepp31 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 12-20-2008 02:00 PM |
Walpro and idle issues? | shgilman | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 12-26-2006 05:31 PM |
SVX Tec II Fuel and Idle Issues | cdigerlando | Other Engine Management | 12 | 09-29-2006 04:20 PM |
1985 GL : Ignition and idle issues | 1985_Subaru_GL | 'Old School' Subaru Forum | 3 | 10-24-2004 12:54 PM |
help 91' justy 5sp starting and idling problems | silv3l2 | 'Old School' Subaru Forum | 0 | 02-10-2004 09:17 PM |
