Old 02-25-2007, 08:08 PM   #1
jedz123
Member#: 67083
1993 Impreza L HB
EJ25D swap, 5-speed FWD
Default EG33 into a 94 Legacy
Fellas I'm in need of information. I'm looking for any information about an EG33 swap into anything but an SVX. MY SVX is ready for Decommission. I have far to many new problems and I still haven't had a chance to fix all of the old problems. I'm looking into swapping the EG33 into my 94 legacy. The legacy has proved to be a more reliable car and I'm looking into vamping it up a bit. If this EG33 swap is a possible job to do then I'm going to do it.
Where can I find any information about this swap?
Thanks
~Justin
jedz123 is offline   Reply With Quote
Old 02-25-2007, 08:55 PM   #2
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
the wiring part isn't too difficult. the stock ECU is pretty simple, and would be pretty easy to make it work outside of it's original car.....
but, it won't fit. the engine is quite a bit longer, so you'll have to move the radiator. not to say it can't be done...but you've got your work cut out for ya.
Numbchux is offline   Reply With Quote
Old 02-26-2007, 02:58 AM   #3
Sojuuk
Member#: 61423
2004 Outback H6
Champagne
ez30 would be worlds easier as far as fitting it goes
Sojuuk is offline   Reply With Quote
Old 02-26-2007, 09:10 AM   #4
jedz123
Member#: 67083
1993 Impreza L HB
I have the EG33 in its working car..I really don't have the time/money to source an EZ30
IS there a write up about this somewhere? I've done a great deal of searching on the forum but no luck. Where can I get some more detail?
Thanks
~Justin
Old 02-26-2007, 09:54 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i have seen it done but like they say its a tight fit
think pusher fans and maybe a different radiator
Old 02-26-2007, 10:33 AM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I think physically fitting it in is the least of your worries... sell the SVX and buy a EJ20G maybe?
jamesfacts is offline   Reply With Quote
Old 02-26-2007, 11:21 PM   #7
Numbchux
Member#: 71658
'84 Brat
what would give you that idea?! physically fitting it would BY FAR be the hardest part.
I've never seen it done, but I do know it will not fit between the stock tranny and radiator.
Old 02-26-2007, 11:51 PM   #8
Brydon
Member#: 107569
1998 Forester S
SRP
Brydon is offline   Reply With Quote
Old 02-27-2007, 12:49 AM   #9
jamesfacts
Member#: 51282
98 RS
My point was there are even further challenges beyond the actual re-locating of the motor, ie wiring, exhaust, etc.
Old 02-27-2007, 03:36 AM   #10
Numbchux
Member#: 71658
'84 Brat
there are a few....but nothing that difficult. He's got a donor car. exhaust is simple, the stock EG33 header will probably bolt up to the legacy mid-pipe. wiring isn't that daunting, especially if you mark everything as it comes out of the donor car.
I made an EJ22 fit and run in an loyale. this meant stripping down the stock legacy harness to just the bare essentials to make the engine run, give it power, a bunch of grounds, couple wires to the ignition switch, couple wires into the dash, and you're golden. The EG33 just has a couple more wires for the extra 2 injectors and ignition coil.
jedz. if you're up to the task of moving the radiator forward a few inches, the rest isn't too tough. I wrote a walk-through of the EJ22 swap that would be a great start to your wiring challenge. and I also know of a guy that put an EG33 into an XT6, so he'd know how to make the EG33 run using the stock ECU in something other than an SVX.
Old 02-27-2007, 01:26 PM   #11
jedz123
Member#: 67083
1993 Impreza L HB
YES!!!!! I would love to read you write up on your EA82 to EJ22 swap. I pm'd you my E-mail address. I still have been looking around the internet on any kind of swap and I came across a XT6 EG33 swap...probably the same guy. I know A write up is in hand after I complete this project. Thanks numbchux I'll be looking forward in reading your information.
~Justin
Old 02-27-2007, 03:47 PM   #12
Numbchux
Member#: 71658
'84 Brat
~Justin
email sent.
you've got your work cut out for you, but I think it's totally do-able, and TOTALLY worth it
Old 02-28-2007, 11:29 PM   #13
jedz123
Member#: 67083
1993 Impreza L HB
Thanks SO MUCH!!!
Old 03-01-2007, 02:26 AM   #14
Numbchux
Member#: 71658
'84 Brat
Thanks SO MUCH!!!
sure thing. I hope that helped. did you contact huck? are you going to do this?
Old 03-01-2007, 10:11 AM   #15
jedz123
Member#: 67083
1993 Impreza L HB
I'm already making arrangements do borrow a friend's car for about a month so I can do this project. It looks like I will be doing this sometime within the next couple of months. I'm going in to work and requesting a Vacation so I can spend every day on the project...It's just to cold and snowy right now to start the project(I don't have a garage). I'm really excited, I writing up a plan of attack for the project I'll send it to you when It's all set. Cause when I do this I'm also replacing the sport tuned suspension and the leather seats It will all be in the plan of attack. I will get in touch with Huck and get some more info about the swap as well...
Old 03-02-2007, 11:42 PM   #16
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
*subscribed*.
t3hWIT is offline   Reply With Quote
Old 03-03-2007, 07:31 PM   #17
jedz123
Member#: 67083
1993 Impreza L HB
BAM! I got my vacation set for 4/8-4/16 .
My write up on my plan of attack is almost done. I just purchased a welder and an engine lift. I'm hoping that the weather is good next week so I can start transferring chassis parts on to the Legacy....I don't know about you guys but it has been nasty wet and cold up here.
I also have my new battery and charger for my digital camera coming in the mail soon. I want to document the whole project...just in case someone else wants to try something like this.
Old 03-03-2007, 07:53 PM   #18
hummer1331
Member#: 142440
fun stuff
hummer1331 is offline   Reply With Quote
Old 03-12-2007, 07:38 PM   #19
cyberbackpacker
Member#: 35798
2005 Outback
*subscribed*
cyberbackpacker is offline   Reply With Quote
Old 03-24-2007, 01:30 PM   #20
jedz123
Member#: 67083
1993 Impreza L HB
Well Guys I have started Swapping things into the Legacy I thought I would let you know that I have just finished Putting the leather seats into the Legacy. It wasn't easy and I had to do alot of welding to fab the brackets to make them fit.
BUt here is the end product
Here is some of the welding for the brackets
The job took me about 4 hours to do...I think it would have been faster if it wasn't my first time welding with an arc welder...but there always has to be a first time for everything.
I will deliver more pics of this project as they come....I'm going to eat lunch
Old 03-24-2007, 06:30 PM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
What are the seats from? Are they SVX seats?
Pat
Old 03-24-2007, 09:18 PM   #22
PURE EPI
Member#: 2642
IMPORTANT SAFETY TIP:
WELDING IS DANGEROUS ALWAYS USE PROPER ASSOCIATED PROTECTIVE EQUIPMENT!!
seriously Jackie get some cheap gloves for your hands. The first time you have hot slag spatter or drip on your skin you'll regret it!
(just don't like to see people get 3rd degree burns it they can avoid it) way to go doing it your self though! I hope to do the same. MT SVX though.
PURE EPI is offline   Reply With Quote
Old 03-25-2007, 10:57 PM   #23
jedz123
Member#: 67083
1993 Impreza L HB
Yes they are
Amen to that...Thats a pic of my buddy Henry... He grew up on the farm and has welded his whole life so I let him be....as for me, I have and always use my eye and hand protection
Old 03-26-2007, 06:37 PM   #24
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
yea its dangerous alright.... I remember when I first bought my welder; I thought I could just close my eyes and look the other way when I was welding.....
you ever stick sandpaper under your eyelids? yea thats what my eyes felt like for the next 2 days....good luck sleeping !
IllNastyImpreza is offline   Reply With Quote
Old 03-27-2007, 07:54 PM   #25
jedz123
Member#: 67083
1993 Impreza L HB
The Swap Continues but this time I've started the big project...Engine swap...
Wires Wires Every Where but Damn I'm scared to snip!
Today I removed everything till I got to the firewall...wow what a process. It took me about 5 hours to get to the firewall and have nothing but wires left to work with. I have to say I have spent about 6 hours total today on the car. I got my self setup for tommorow so I can start the montonious job of spliting and rewiring wires. The amount of wires in this bad beast is intense!
OH well enough with me rambeling how about some pics
A pic @ 2 hours into the project
Alright 5 hours in and everything I wanted out IS OUT!
My attempt at Organising wires LOL I called it a day after this.
hA Ha The Ecu is out and mine.
Tommorow I plan on splicing... Thats going to suck but I'll get it done and over with. Once my harness is seprated from the pandemonium of the SVX I'll be able to install the ECU and Harness onto the Legacy. I am going to be running both ECUs so I can drive with the 2.2 until engine swap day...so it's as easy as pull the 2.2, drop 3.3, plug, play, and roll. Of cource I will modify the engine bay to accomodate for the new and larger motor. OH well I'll keep you guys updated I'll post some more pics tommorow after I get the harness out and ready for the swap .
94 legacy ej22t into 97 impreza l coupe epil0g Newbies & FAQs 18 04-26-2010 07:56 AM
2.0T into 94 legacy wiring sucks. HellBinder Subaru Conversions 2 02-25-2007 02:50 PM
03 WRX 2.0 into 94 legacy wagon RHD HellBinder Subaru Conversions 24 01-14-2007 06:46 PM
EG33 into 97 OB simpreza2 Subaru Conversions 29 12-16-2004 04:25 AM
Turbo Legacy Engine into a 94 Impreza L? Homemade WRX Subaru Conversions 5 04-11-2003 10:48 AM
