Old 02-26-2007, 06:49 AM   #1
wgas
Member#: 141760
07 wrx sedan
obp
Talking painting subaru star badge & the impreza text on an '07
so i didn't really like the blue star badge or the blue impreza on the back... especially since my calipers are red, and so is my license plate (not in pics, but is a colorado firefighter plate (white/red/black))
note: i left the chrome & only repainted the background. you can also repaint the chrome stars using the same method below, BUT the chrome oval is a separate piece & is not repaintable from the back like the stars/background. therefore you would have to paint the exterior of the chrome, which i would recommend against.
basic how-to:
1. remove front & rear badge w/ heat gun. (be really gentle with back as it is obviously on the actual paint. (both badges are 2 parts: chrome oval, & the whole center). the front pieces are not glued to each other (sorry, forgot to take a pic of it), but the back, the center is stuck to the chrome back, so after taking the chrome off, then remove the center. (alternatively, you can just remove the center from the back & leave the chrome outline, but i had to use tiny screwdrivers & knives to separate the 2 parts & didn't feel comfortable with those tools sliding around so close to the paint.
don't worry about the 2 holes in the trunk, when you put the badge back on, it will fill them again.
2. when you turn them over, you will see that it's basically chrome in indentations the shape of the stars w/ a coat of blue paint over the whole back. i couldn't get any of the cleaners that we had in the fire station to take off the blue paint, & the only thing i could find that would work was brake cleaner (& it didn't damage the plastic, don't worry). anyway, basically just scrub the back w/ brake cleaner to rub off the blue from the flat area, leaving the indented stars. it will look like this from the front after that.
3. then repaint the back part you cleaned off with your choice color. i used enamel model paint for this. do multiple coats until you can't see any light through. i'm sure spray paint would work too, but i had the enamel lying around. then i coated it w/ a clear coat as well.
4. since i was painting the blue badges, the blue impreza looked out of place, so i painted it as well. just used a toothpick to paint 3-4 coats w/ model enamel, & touching up mistakes as i went. then i also did a few coats of clear coat over this part since it will actually be exposed.
5. re stick them on. i was able to save & re-use the sticky from the front badge fine, just reheated it really hot & applied pressure while it dried. for the back, i just used 3m automotive double sided tape.
& voila. total time, around 6 hours or so, but that included sitting around detailing other things while i waited for all the paint coats to dry.
wgas is offline   Reply With Quote
Old 02-26-2007, 07:24 AM   #2
RS2004
Member#: 95450
nice job looks sweet
RS2004 is offline   Reply With Quote
Old 02-26-2007, 11:08 AM   #3
JCity
Member#: 131845
1994 Acura Integra
R-81
came out nice. wish i had the patience for that type of project ! haha.
JCity is offline   Reply With Quote
Old 03-04-2007, 04:03 AM   #4
wgas
Member#: 141760
07 wrx sedan
obp
decided to do the outline of the wrx as well.
used a heat gun to take the letters off to avoid mispainting (& left the sticky on the car still to reuse).
painted a few coats w/ red enamel model paint using a small brush & toothpick for detail.
sprayed whole thing w/ a gloss clear coat, & the chrome still looks the same as it did before.
re-heated & attached.
Old 03-04-2007, 09:23 AM   #5
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
that looks amazing and is a must have on all black rex's. i wonder what would look good on my 07 wrb one though?
bluemax189 is offline   Reply With Quote
Old 03-04-2007, 09:36 AM   #6
crewchief97
Member#: 97269
2007 Toyota Tacoma
Dbl Cab 4x4 Super White
Looks good, especially after you outlined the wrx on the back...that looks awesome
crewchief97 is offline   Reply With Quote
Old 03-05-2007, 02:41 AM   #7
BlackSTI2006
Member#: 105404
2006 FPGreenSTI SOLD
04 GMC 2500HD Duramax CC
you guys have polaris ranger 6x6s for fire & rescue.....nice
i am a polaris dealer, we set up quite a few F&R crews around here with them as well...we actually just did a 4x4 ranger with Mattracks on it for one crew....
to be on topic....the badges came out great....my badges are discoloring so i think im gonna repaint mine as well...good job!
BlackSTI2006 is offline   Reply With Quote
Old 03-05-2007, 02:48 AM   #8
apalileo
Member#: 136784
2007 impreza wrx
urban gray metallic
great job! i actually did that same thing years ago when i owned a 1991 ford escort. i painted the backdrops on the ford badges red. i got so many people hitting me up about it. i'm sure other subaru owners will see your badgework and ask where you got it thinking it's an aftermarket part you bought. it's a good feeling!
apalileo is offline   Reply With Quote
Old 03-05-2007, 03:07 AM   #9
wgas
Member#: 141760
07 wrx sedan
obp
we actually got the ranger from u.s. smokeless tobacco from their donation program.
mounted a compressed air foam system in the back, & it is removable to be replaced by a litter mount for off road hauling of a patient, or mounting brackets to carry scuba setups & extra tanks. (we do dive rescue for the whole county [from flatlands up to the continental divide] so there's some nasty places to get to that we have to dive, & it's pretty impractical to have somebody suited in a full drysuit hiking with all their gear on)
Old 03-05-2007, 03:28 AM   #10
Kangpreza
Member#: 134717
awesome DIY man, love the look. when you used brake cleaner till paint is gone, it didnt melt or damaged plastic? because i remember when i was cleaning my screw driver with brake cleaner, the handle part kinda melted.
Kangpreza is offline   Reply With Quote
Old 03-05-2007, 03:44 AM   #11
wgas
Member#: 141760
07 wrx sedan
obp
it didn't affect the plastic at all, but i didn't pour it on. i sprayed it into a cup, & then used a small piece of paper towel, dipped it in, & rubbed the paint off.
also, i used crc brakleen fwiw.
Old 03-05-2007, 11:20 AM   #12
ntg06
Member#: 136164
1984 Sheep Dog
yup the brake cleaner works. Powerfull stuff
ntg06 is offline   Reply With Quote
Old 04-26-2007, 05:27 PM   #13
ethanrob
Member#: 132440
reading through this thread,when you took the two parts of the badge apart would you say that the center part(with the stars on) is the same size as the 01-05 stars badge mate ???
i am after a pink stars badge,but i aint a great painter so would prefer to seperate the badge,and fit a resin pink 01-05 badge instead
mark
ethanrob is offline   Reply With Quote
Old 06-24-2007, 02:20 AM   #14
Nok
Member#: 148780
2006 STi
SGM
mark
The painting is actually the easiest part from what I found out doing my front badge today. The chrome stars are actually indented into the the badge, so cleaning off the background color is quite simple as long as you don't puddle the brake cleaner. I used Krylon Semi-Gloss Black spray paint for mine, only needing about 3 decent coats I think it turned out quite nice.
And to the OP: First off, thank you for the write-up it looks really great on your car! As mentioned above, I completed my front badge tonight after installing my grillcraft and am really wanting to do my rear badge but am scared of messing it up somehow taking it off. Does it come off fairly easy with the right amount of heat? Are the holes merely guides, or actually bolts? If you could supply a little more detail with what you did with the rear, I would really appreciate it! Thanks again!
Nok is offline   Reply With Quote
Old 06-24-2007, 03:46 AM   #15
biba028
Member#: 109331
2015 STI
CWP
nice project..
i'll take pics of mine..
although, i did mine the other way..
I took out the chrome on the whole badge, painted the background with a touchup paint to match my car, then the stars and borders with gold.
biba028 is offline   Reply With Quote
Old 06-24-2007, 03:57 AM   #16
Suby*Doo
Member#: 148732
OT dates super
models. Deal with it
looks amazing...better if you put that red lip thing on the grill
Suby*Doo is offline   Reply With Quote
Old 06-24-2007, 02:56 PM   #17
eld4au6
Member#: 105089
05 STi/ Toyota
Land Cruiser
looks great
eld4au6 is offline   Reply With Quote
Old 06-24-2007, 08:40 PM   #18
ib2qwik2c
Member#: 147890
2007 WRX TR
BLACK
Originally Posted by biba028 View Post
nice project..
got pics?!?!
ib2qwik2c is offline   Reply With Quote
Old 06-24-2007, 09:14 PM   #19
Nok
Member#: 148780
2006 STi
SGM
Well I managed to get the rear badge off with no problems, but I can't seem to get the actual badge out of the chrome housing. Any tips from anyone? It's driving me crazy...
Update: I knew it would happen, I screwed it up... I guess I got it too hot and tried to flex the badge a bit to get something under it and it dented the chrome ring, looks bad. Any tips on how to get the next one off my replacement badge? lol
Old 06-24-2007, 10:29 PM   #20
Black07Impreza
Member#: 131390
2010 5 Door
Spark Silver
that looks awesome... especially the painting around the WRX badge. Really good job.
Black07Impreza is offline   Reply With Quote
Old 07-03-2007, 04:09 PM   #21
Schnitz
Member#: 119499
2006 STI
I just painted my headlight housings and my front badge. Can someone write out 'exactly' how to remove the rear badge? Do the brass fittings on the inside of the trunk come out? Do you put the heat gun directly over the badge? I would love to do this but I am very concerned that I might ruin my trunk lid by melting the paint
Schnitz is offline   Reply With Quote
Old 07-03-2007, 04:31 PM   #22
Dragonbreak
Member#: 96860
2006 STI
Subscribed.
Dragonbreak is offline   Reply With Quote
Old 07-05-2007, 10:15 PM   #23
Dragonbreak
Member#: 96860
2006 STI
BUMP for more info on how to remove the rear badge.
Old 07-05-2007, 10:37 PM   #24
imprezaowner27
Member#: 131299
2006 Impreza
Go to the local CVS or Walgreens, and buy one of those glasses repair kits
take the small screwdriver that comes with it and tuck it under one of the corners of the blue part of the badge and pull up just enough to get another screwdriver under there....
note: the small screwdriver is very weak and will bend if you try to use that one to rip out the badge...
also note: the chrome surround DOES NOT, come off just the plastic badge itself
imprezaowner27 is offline   Reply With Quote
Old 07-05-2007, 10:42 PM   #25
Dragonbreak
Member#: 96860
2006 STI
Is it possible to heat it up and use some kind of strong string, like debadging the rear, to get it off?
'08 STi Badges on an '07 STi!!! gregbenoit Member's Car Gallery 23 12-13-2012 03:00 AM
Burning coolant on an '07 Impreza superAL1394 Normally Aspirated Powertrain 1 01-18-2010 12:54 AM
Installing Subaru Star Badge on Debadged Trunk wrxslickg Interior & Exterior Modification 6 06-08-2008 07:18 AM
Impreza I badge for trade for a 02-03 WRX Subaru Stars Badge only1agam Private 'For Sale' Classifieds 9 11-30-2005 10:42 PM
Front Subaru stars badge...anyone have one? JGard New England Impreza Club Forum -- NESIC 1 08-28-2002 09:55 PM
