#1 |
Member Sales Rating: (23)
Member#: 24464
Vehicle:2007 WRX STi (SWP) Surgeline Tuned |
I put the Holy Shift into my 2007 STi this weekend and have some initial impressions.
What it is: A complete replacement of every pivot point in the shifter mechanism with harder durometer material. This includes: * Front stay (Kartboy) * Rear stay (Kartboy) * Lever pivot (TiC) * Linkage bushings (TiC) ![]() The install: Not bad really. Once the transmission support cradle is out of the car, the shifter is easy to get to. I did not drop my midpipe as they suggest, but you may have to with an OEM system. The only tricky part is deciding whether to punch out the roll pin or remove the bolt in the shifter U-joint assembly (necessary for replacing the linkage bushings). Each has its own perils and I chose the latter. A little prying and the transmission moves enough to extract the bolt. I liberally greased every point as I hate squeaks and it seems to have done the trick. The feel: Much more positive into the gates with no slack whatsoever. I liked the shifter before and now I'm bordering on love. Drawbacks: The stiffer bushings transmit a bit more noise into the cockpit, but I've really only noticed it in 3rd and 4th gear. I would class the noise as "sporty" rather than "annoying". I would recommend this upgrade if you place a lot of value on your shifting experience.
| Thread Tools | |
| Display Modes | |
| FS: (PA) TiC Holy Shift Set [stock shifter] | Espo | Drivetrain | 0 | 11-23-2009 02:30 PM |
| AccessPORT V2, Tic Holy Shift Kit, Blue Sti Mats,17x8 Sport Edition ST3 | New2Subaru! | Tri-State Area Private Classifieds | 51 | 09-03-2009 05:20 PM |
| TiC 06-07 Holy Shift Set | abz15cool | TXIC Private Classifieds | 5 | 08-18-2009 03:21 AM |
| FS: (CO) TIC Holy Shift Set, Cobb Double ADJ. Shifter & Cobb Knob | cleatis | Drivetrain | 5 | 07-27-2009 10:29 PM |
| TIC Super Shift Kit (PROBLEMS) PLz Help!! | Stikid04 | Transmission (AT/MT) & Driveline | 5 | 03-23-2008 12:43 PM |
