Old 02-26-2007, 07:17 PM   #1
bc_1981
Member#: 85688
2000 Impreza OBS
Question 2.5 head gasket
So here's the story....
My girlfriend buys a used '01 Forester in the fall and she took it to Subaru (Barrie) for an oil change and they tell her that she needs a head gasket replaced. But here's my problem; a buddy of mine took his '03 forester to the same dealer and they said the same thing. I haven't gotten a second opinion yet.
Common problem or possible scam?
bc_1981 is offline   Reply With Quote
Old 02-26-2007, 07:22 PM   #2
Mike1967
Member#: 87762
Yes and Yes
If it is not overheating...or losing coolant....or blowing dark smoke....and it is running fine......then tell them "thanks, but no thanks on the head gasket"
Mike1967 is offline   Reply With Quote
Old 02-26-2007, 07:24 PM   #3
Mike1967
Member#: 87762
I would be curious to know what price they quote for replacing the headgaskets.
Old 02-26-2007, 07:42 PM   #4
bc_1981
Member#: 85688
2000 Impreza OBS
Everything seems to be fine. I've checked the driveway several times, it's not losing any fluids..
And they quoted the job at just under $2000 CAN. That's for the head gasket, timing belt and a couple other little things they suggested.
Old 02-26-2007, 07:49 PM   #5
bc_1981
Member#: 85688
2000 Impreza OBS
Also they are building a new dealership and I can't help but think that this is a way to help pay for it.......ripping people off that is (more than usual anyway).
Old 02-26-2007, 08:31 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
For that kind of money you could buy all the tools needed, the service manual, and the parts. And when your done you would still have money left over.
Tim Sanderson is offline   Reply With Quote
Old 02-26-2007, 09:21 PM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Some piss poor suggestions and comments in this thread...
No its not a scam, yes headgaskets on the EJ25's really do fail that often. Its not a "scam" by dealerships, just a poor design on Subaru's part.
However, depending on the condition, and whether its leaking coolant or oil and how much its leaking, yes you can drive on it awhile. If its spewing oil or coolant or mixing the oil and coolant in the engine, or the coolant and oil levels are getting lower on a regular basis, definatly get them done ASAP. But you need to find out exactly what the diagnosis was and how bad the gaskets were (usually they say its leaking 3/5 or something like that, to indicate how bad the leak is, and whether its leaking coolant or oil) and go from there.
Headgaskets are not an easy job, and yes dealers do get money off of them but they also take A LOT of time and can back up a shop VERY quickly if you get a few in at a time...
Old 02-26-2007, 09:55 PM   #8
kleinkid
Member#: 27091
2010 STi SE
I have had my 2.5 '00 head gasket changed twice. External leak. On the drivers side, look at the rear of the engine real good with a light. Also, take the front left wheel off and inspect from that vantage point, looking where coolant would drip off the rear of the engine and drip on the drive shaft. Warranty might cover this work, did on mine, twice.
kleinkid is offline   Reply With Quote
Old 02-26-2007, 09:59 PM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Indeed. And If you have the coolant campain performed, it extends the warranty to like 8yrs/100k miles for the headgaskets. Although only for external oil leaks I believe (or is it coolant? Im not sure, ill check)...
Old 02-27-2007, 03:14 AM   #10
Hippie
Member#: 139854
1998 Impreza 2.5 RS
get a second opinion for sure.
oh and hi everyone, im hippie
Hippie is offline   Reply With Quote
Old 02-27-2007, 11:25 AM   #11
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Ditto. I've gone roughly 20k with a head gasket dribbling out a bit of coolant.
t3hWIT is offline   Reply With Quote
Old 02-27-2007, 11:32 AM   #12
emmalu
Member#: 142024
i am second owner of 2001 outback; purchased 12/06; i recently noticed odor of anti-freeze; 97+ miles; original owner performed all necessary maintenance with dealer; if this is a head gasket problem, will i be covered under the warranty to 100,000 miles??? thanks for your help
emmalu is offline   Reply With Quote
Old 02-27-2007, 12:17 PM   #13
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
That could be anything...
If you are not very good at diagnosing things like this on your own, your best bet is to take it somewhere experienced with Subarus to diagnose it (Dealer or a local Subaru specialist, whichever you prefere)
Old 02-27-2007, 05:09 PM   #14
rickG888
Member#: 14820
2002 WRX wagon
Sedona Red
I work at Barrie Subaru (Sales Manager) and can assure you that we do not scam our customers. Go for a second opinion if you like but our guys are just letting you know before you are on the side of the road with a blown gasket or worse. Maybe it is just a minor leak but if they didn't say anything and you came back a week later with it pouring you'd be pissed they never at least took the time to consult you.
Yes we are building a new dealership to help serve you better. To think we are scamming, I am sorry you feel that way and don't have any trust. Maybe we have to work harder at gaining your trust. Ask for Guido our service manager if you need clarification or want to know more details.
Subaru has a known issue with HG's and we do at least 1-2 engine jobs a week.
Better to spend the money before it is even more costly to your GF. It's up to you it's your car but headgaskets on a 2.5L NA engine are part of the maintenance program. Anywhere between 80K-200K they will go.
Search if you don't believe me. If I can be of any help please call me at the dealership.
rickG888 is offline   Reply With Quote
Old 02-27-2007, 05:15 PM   #15
rickG888
Member#: 14820
2002 WRX wagon
Sedona Red
In Canada there is no such goodwill warranty extension on HG's. SOC and SOA are separate companies and have different warranty policies Sorry.
Old 02-27-2007, 05:26 PM   #16
02darkRS
Member#: 80918
02-7 MBP RS/i hybrid
now w/ AVLS!
it's for internal coolant leak (though they may let an external one slide as covered)
mine was leaking oil externally & they denied the claim stating what i put above.
no coolant leaky no coverage....
02darkRS is offline   Reply With Quote
Old 02-27-2007, 06:02 PM   #17
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Missed that part, sorry.
Old 02-27-2007, 06:35 PM   #18
Major Johnson
Member#: 120705
2007 FXT Sports
World Rally Blue
What mods could void that warranty?
'Cause recently I've had a small leak, very coolant smelling, dripping looks like right before the header meets the cat section... this is gonna suck isn't it?
Major Johnson is offline   Reply With Quote
Old 02-28-2007, 12:50 AM   #19
Mike1967
Member#: 87762
How many miles are on this car?
Definitely get a second opinion and some competitive quotes. $ 2,000 is a significant investment.
Also, get a quote from them on parts and labor....and then shop the parts on the internet to get an idea of what their markup is. Also, share the quote data here. The forum is here for information sharing...and there are people here who can probably tell you what they paid for parts and also for labor.
I'm assuming they are at least wanting to do the headgaskets, timing belt and water pump.
I view $ 2,000 as a great deal for the shop. Anyone who has the tools and experience on these engines can knock this job out in a day. You are maybe talking $ 200 in parts costs.....so don't listen to any crap about how you are filling up their shop. $ 1,700 is pretty good pay for a days work..
Old 02-28-2007, 08:41 AM   #20
aross
Member#: 831
11 Blurple WRX
03 BH MBP
As far as GTA dealers go, Barrie Subaru is the most honest I have come across, Rick who replied earlier is a great guy, and tells it as it is.
Do get a second opinion at another dealer though, OR go back to see Rick at Barrie Subaru, and ask to see the leak, I am sure they will show you, and explain the risks.
Good luck.
aross is offline   Reply With Quote
Old 02-28-2007, 11:33 AM   #21
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
It takes at least two days for both headgaskets. Shop techs dont work non-stop all day... Its possible to do one side in a day, but not both including removing/reinstalling the engine and properly setting everything and cylcing the engine.
And yes, if its an external leak, get your ass under the car with a flashlight and look at it yourself if you dont believe them.
Old 02-28-2007, 01:32 PM   #22
rickG888
Member#: 14820
2002 WRX wagon
Sedona Red
most tech I have seen prefer to remove the engine from the car when doing both headgaskets.
Old 02-28-2007, 02:12 PM   #23
Mike1967
Member#: 87762
An experience tech should be able to pull these engines within 2 hours easy.
Old 02-28-2007, 02:19 PM   #24
Mike1967
Member#: 87762
Provide a breakdown of time required for each major step (i.e. pulling engine, removing timing belt, camcaps and heads, installing headgaskets, putting heads and cams/seals back together, resetting the timing belt, cycling the engine.
Also, give me a breakdown of the parts and the costs.
Maybe I am wrong on the costs....but I would like to see how you get to $ 2,000 on this job.
I would expect that the addition of the timing belt would only be the cost of the belt. There is zero additional labor on a timing belt because all of the labor is already being done on the headgasket replacement. The only difference being that you are putting on a new belt instead of the old one.
Old 02-28-2007, 02:20 PM   #25
Mike1967
Member#: 87762
Also, what is the shop labor rate?
so is this 2.5 head gasket thing under control? sky44 Newbies & FAQs 2 04-28-2008 12:34 PM
2.5 head gasket replacement in car dude6033 Service & Maintenance 0 02-14-2007 06:02 PM
pic of 2.5 head gasket on 2.2 head JoshP Normally Aspirated Powertrain 9 06-24-2006 01:26 AM
2.5 head gasket blown? scuby22b Normally Aspirated Powertrain 6 09-01-2005 02:44 PM
DOHC 2.5 head gaskets!!!!!!! joemamad Legacy Forum 13 10-25-2002 05:36 PM
