Old 02-26-2007, 07:53 PM   #1
qoncept
Member#: 44762
2013 BRZ
Default Fix your tinted 04+ radio reception!
I got tint a couple months after getting my car and never made the connection that it was the cause of my radio getting absolutely no reception. When I figured it out, I decided to just deal with it. Now, after three years without radio, I finally decided to play around and fix it.
As you know, the 04+ WRX's have an antenna in the rear window. The metallic content of the tint interferes with the reception to varying degrees (in my case, no radio, period). So I tore off the C pillar interior panels to get access to the antenna hookup. See below.
Simple enough. I unplugged it, turned on the radio and suddenly I at least got a little reception.
It's dark so I'm done for tonight, but tomorrow I plan on running 18 gauge wire through my wing and making it my new antenna. But I was wondering -- will it be alright to run unshielded wire from there (the C pillar), along the trunk lid (which is, of course, steel) and then to the wing, or should I get some shielded wire to run up to the wing, and unshielded through the wing?
qoncept is offline   Reply With Quote
Old 02-26-2007, 08:17 PM   #2
Daishi00
Member#: 78952
2005 WRX
CGM
Let us know if it works. The fact that you found an increase in reception by disconnecting pretty much answers a question some of us have been having...is it because the tint acts as a huge faraday cage, or whether the tint was shorting the antenna? Sounds like it's the latter.
Daishi00 is offline   Reply With Quote
Old 02-27-2007, 07:58 AM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I would like to know, looking at your pic, where the black wire comming out of that box goes and what it does? And what about the lower connection in the pic? And the red wire... I'm sure some working installers can answer that, right?
That box, i wonder if it "tunes" the defroster grid, Anttenas are tuned, at least decent ones are...
I know my moms forester has the ant. as part of the rear side window...
There is no telling if un-shielded wire will work, most ant. wire is shielded to the connections...
Maybe wad some tin foil up in the pillar.... har har... but seriously, try some stuff and let us know what you find..
Old 02-27-2007, 08:02 AM   #4
qoncept
Member#: 44762
2013 BRZ
I'm fairly certain that box is the antenna amplifier. The red hot line would be power and the black the coaxial antenna lead from the head unit itself.
Old 02-27-2007, 08:07 AM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Ahh ok,
So if it is an "amp" i wonder if it carries a "matching network" for the ant. also...??
I'm wondering if you DON'T use shielded wire to run out to your wing, wether or not you'll pick up hella amounts of noise... ?
Old 02-27-2007, 08:27 AM   #6
qoncept
Member#: 44762
2013 BRZ
Yeah.. We'll see. The first test, actually, was sticking an extension cord in (it's the same width as a spade connector at least.. :-D) and it seemed to work pretty decent no matter where I moved it. Maybe I should do my reception tests outside of town.
Old 02-27-2007, 08:47 AM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You got reception after disconnecting the cable because there was now an open wire to the radio, away from the shielding created by the tint.
Your plan may work to provide some usable reception, but a random length of unshielded wire is not a very good antenna. The dimensions of the in-glass antenna are calibrated to work properly at the specific frequencies of the AM and FM bands and with the antenna amplifier.
At the very least you should run coax cable from your external wire antenna to the amplifier inside the car. The coax should be rated for RF use (i.e. don't use audio cable), something like RG-174 would work.
There could also be some reduction of signal with the wire inside the wing due to the metallic content of the paint.
Old 02-27-2007, 09:01 AM   #8
Siper2
Member#: 1134
2010 Legacy GT Ltd.
What about hooking up some kind of "internal antenna?" Moving the connection from the window, to something like an antenna but running it under the headliner trim?
Siper2 is offline   Reply With Quote
Old 02-27-2007, 09:12 AM   #9
snorekl
Member#: 78139
2005 Saab 9-2X
Red
Does anybody know where the amplifier is in the wagon?? Same location?? Is that the LEFT side C pillar in the picture above. I have been thinking about doing something for my reception and I don't even have tint (YES, my amp is powered from the head unit, but it's still pretty crappy in metro Detroit).
snorekl is offline   Reply With Quote
Old 02-27-2007, 09:19 AM   #10
qoncept
Member#: 44762
2013 BRZ
That's the driver's side C pillar. If you take a good look at the antenna in the window you can tell which side it connects on. I'd imagine it would be in the same place on a wagon.
Old 02-27-2007, 11:00 AM   #11
LastResort
Member#: 99289
There are a bunch of FM Antenna DIY's on floating around. It should be easy enough to find one that works in the space provided in the wing, but actually putting it there may be the difficult part.
LastResort is offline   Reply With Quote
Old 02-27-2007, 02:00 PM   #12
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
http://www.audiooutfitter.com/store/69850/44ua200.html
problem solved. I've used them on tinted windows and they still work great.
thedaddyb is offline   Reply With Quote
Old 02-27-2007, 02:46 PM   #13
snorekl
Member#: 78139
2005 Saab 9-2X
Red
You say that thing works great. I hope so, because it will look like a$$ on your window if that's where you stick it. Thanks for the info. Don't know if I want to go that far for radio reception.
It would be so nice if there was an old fashioned external rod antenna or one of those little fuba antennas like on the v-dubs. Those are much better for reception than in-glass antennas. The other problem is that the on-glass antenna is tuned for the stock head unit. When you replace the stock head unit, reception goes down hill even with amplifier wired properly.
Old 02-27-2007, 06:54 PM   #14
Daishi00
Member#: 78952
2005 WRX
CGM
The EASY solution to all of this is simply go with a ceramic based tint
Not cheap though around $500 a tint job.
Old 02-27-2007, 07:25 PM   #15
MikeBuzzsaw
Member#: 66443
2011 Toy-OTAAAA
four-runner!
A shop will do it for 400-450 formula one ceramic tint.
You can always go dyed tint which is 200ish all around.
MikeBuzzsaw is offline   Reply With Quote
Old 02-27-2007, 07:41 PM   #16
Daishi00
Member#: 78952
2005 WRX
CGM
Huper Optik is what I'm getting...about $500 installed, so yeah it's expensive no matter where.
I still don't believe those guys who say the dyed tint doesn't fade over time...just call me skeptical.
Old 02-28-2007, 02:47 PM   #17
subeerex
Member#: 87430
02/5 BugEye-Peanut
Sedona Red Silver
Thumbs up
I've been using this same or similar antenna and no problems. Got mine at Pep-Boys and hooked up to the rear section described earlier and basically just tucked it in between the window glass and the roof liner/rug-material. You can't even tell that it's there...as a matter of fact, I forget sometimes where I hid it! The antenna just plugs right in and you're set. And!...I actually get a better reception from this antenna, both FM and AM (even better on the AM) than the stock set-up!
subeerex is offline   Reply With Quote
Old 02-28-2007, 04:10 PM   #18
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
i had ceramic done on my wagon, all side and rear window for $135... johnson films brand.
dantastic is offline   Reply With Quote
Old 10-12-2007, 02:37 PM   #19
chanders
Member#: 131319
2003 JDM STI
World Rally Blue
Anyone know how they are connected inside the amplifier? This would help a lot seeing I got the amplifier but no leads coming from the unit.
chanders is offline   Reply With Quote
Old 06-01-2009, 10:20 PM   #20
Heider
Member#: 172173
2005 Impreza WRX
so that's why my radio reception sucks!
Heider is offline   Reply With Quote
Old 06-02-2009, 01:59 AM   #21
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
The FM signal isn't completely blocked by the tint... but it's either getting shorted to ground or the elements are being shorted together by your mangy tint. If all RF signals were completely blocked by tint then your cell wouldn't work. Your check for this? Take a simple FM walkman into the car... betcha you'll still get some FM signal. 3M makes a nice ceramic based tint that won't cause issues... but i doubt you wanna change tint to get this working. I can't see that site since it shows under construction but here's two alternatives that should work fine for under $30.....
http://www.crutchfield.com/p_12044UA...&tp=3449&avf=N
Stringing a wire is fine if you have the time to play with the length... normal antennas are usually in the 25-30" length since that corresponds to the quarter wavelength of your average FM wave.... so there is some science and tuning that goes with the length of the wire. I have no idea what the ideal wire length is for an amplified antenna... unless you're an electrical engineer or have access to one, you're gonna have to guess and check. Any ol' wire might work, but it's not going to be optimal.
Main reason a stock radio works well for a stock antenna is the mfgr can tune the antenna for the radio... where as aftermarket tuners are generically tuned... I seem to remember some old radios (sony?) having adjustments available to dial em in.... no one ever did though. I THINK (as in I'm guessing) the main reason masted antennas work better than glass ones is orientation.
couchflambeau is offline   Reply With Quote
Old 06-02-2009, 02:02 AM   #22
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
My guess is soldered to the pc board...
Old 06-02-2009, 11:16 AM   #23
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Nice kill, that last reply was from 07' mang...
Old 06-02-2009, 11:54 PM   #24
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
FTW... !!
sometimes i hate this forum lol...
Old 03-23-2010, 11:19 AM   #25
tittykaka7
Member#: 187709
2013 WRX
OWP
So this thread is old .. but I'm trying to fix the reception on my '04 wrx. The pic showing where he disconnected it doesn't seem to be working. Does anyone have another pic showing where to dig into this thing? Are there any new solutions to update this thread with? Lets start with the cheapest first
tittykaka7 is offline   Reply With Quote
bad radio reception and hd radio ? sittinsideways Car Audio, Video & Security 5 03-25-2010 07:16 PM
04 WRX w/ poor radio reception tfields04 Car Audio, Video & Security 3 06-16-2009 05:41 PM
Radio reception after tint th3w0rm Car Audio, Video & Security 25 07-31-2006 10:41 AM
New tint job = messed up radio reception doobyscooby Interior & Exterior Modification 18 05-25-2005 08:42 AM
Problem on radio reception on my 04 STI STI808 Electrical & Lighting 10 12-29-2003 09:42 PM
