Notices
Old 02-27-2007, 07:47 PM   #1
gatts
Member#: 131092
black
Default Where is the keyless entry control module?
I have a wrx which is supposed to come with keyless entry but i think it was taken out. If someone could tell me in detail where its at or a pic would be great. thanks!
gatts is offline   Reply With Quote
Old 02-27-2007, 09:41 PM   #2
Uncanny
Member#: 133012
2015 STi
Lightning Red
its above driver's side kick panel....ill take a picture if i get a chance, but its right there.
Uncanny is offline   Reply With Quote
Old 02-27-2007, 11:16 PM   #3
joe r
Member#: 53412
2003 Outback
Black and Gold.
to the left of the steering colum when you pull the lower drivers side knee panel off.
joe r
joe r is offline   Reply With Quote
Old 02-28-2007, 03:09 AM   #4
hector
Scooby Scammer- Do Not Buy From User
Member#: 132902
2006 wrx tr silver
99 BMW 323is
DIRECTWIRE™ WIRING INFORMATION - SUBARU / IMPREZA / 2004 / Keyless Entry
[PRINT THIS PAGE]
12volts white + ignition harness
Starter white/black + ignition harness
Ignition green + ignition harness
Power Lock red/white - gray plug at integrated module
Notes: The integrated module is to the left of the steering column.
Power Unlock yellow/red - gray plug at integrated module
Lock Motor orange 5wi blue plug at integrated module
Unlock Motor red 5wi blue plug at integrated module
Parking Lights+ black/red or orange + parking switch
Parking Lights- black/white - lighting switch
Notes: The negative parking lights wire only works with the ignition on.
Hazards same as turn signal wires
Turn Signal(L) black/green + steering column
Turn Signal(R) lt. green/black + steering column
Door Trigger yellow - gray plug at integrated module
Dome Supervision blue - blue plug at integrated module
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Horn Trigger red/green - steering column or keyless
Notes: The keyless entry control module is above the driver kick panel.
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
hector is offline   Reply With Quote
Old 02-28-2007, 03:10 AM   #5
hector
Member#: 132902
2006 wrx tr silver
99 BMW 323is
I dont know if this will help but I have access to directtechs so I thought I would take advantage for you in case yours has been removed and you want to go to an aftermarket peice.
Old 02-28-2007, 01:53 PM   #6
gatts
Member#: 131092
black
is it a black box with a blue and gray plug going into it and says integrated unit?
Old 03-01-2007, 12:27 PM   #7
gatts
Member#: 131092
black
Anyone? i cant find any pics of the control module
Old 03-01-2007, 12:37 PM   #8
randy98mtu
Member#: 38197
04 WRX Wagon
Java Black Pearl
No, that's the intergrated module to the left of the steering column. The keyless module is on a metal bracket directly above the fuse panel. I believe it has a single white connector on it. Sorry, I'm at work and can't do much in terms of pictures.
randy98mtu is offline   Reply With Quote
Old 03-01-2007, 06:27 PM   #9
VR4Impreza
Member#: 78818
'06 Forester XS
'11 Outback 2.5i
It is located to the upper right of the fuse panel. It should have two plugs, a white one on the left and blue on the right.
at least for the '05.... I would guess if it's missing you'll see the two plugs hanging there. If you see two boxes that have all the plugs there, then it should be there. I beleive if you get under the dash and press the lock button you can hear it click (that's the relay).. may be wrong with that... but then if it's missing (or at least not working..) that may not work
VR4Impreza is offline   Reply With Quote
Old 03-01-2007, 07:17 PM   #10
funkylemons
Member#: 39161
06 STi
SGM
Should be ABOVE the fuse panel under the dash, the plug is coming out of the left side of it.. its up almost wedged between the dash and the top of the fuse box.. It has 1 10mm nut directly under it between it and the fusebox, take that out and you'll be able to remove the module..
funkylemons is offline   Reply With Quote
Old 03-01-2007, 09:57 PM   #11
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Just a note that the alarm system (and presumably keyless entry as well) was changed for MY04 on Imprezas.
Here's a .pdf of the installation instructions for the MY02/03 keyless entry that should help you out: www.armands.net/Other/2002ikeyless.pdf
Old 03-01-2007, 10:00 PM   #12
gatts
Member#: 131092
black
Ok so i found it and here the relay click but its not programming for some reason. I put the key in and went from lock to on 10x and no honk? Any ideas? thanks!
keyless entry control module Diabolus 1993 - 2001 Impreza Specific Parts 2 06-18-2009 12:43 PM
WTB: 06 WRX keyless entry control module LightningXC20 Private 'Wanted' Classifieds 0 01-14-2008 09:04 PM
Where is my keyless entry button? iathon Car Audio, Video & Security 2 10-17-2007 08:31 PM
Keyless Entry Control Module pt.II carrman Legacy Forum 0 10-02-2004 01:33 AM
Keyless Entry Control Module carrman Legacy Forum 1 09-28-2004 09:59 PM
