Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 02-28-2007, 06:37 PM   #1
WRXXX
Member#: 9602
'02 WRX
Default DFW Area Tuners?
Just got AP installed, running Stage 2 and am having some weird boost issues. I'm going to undo the "3/16" mod I did to the car back in '02 and see if they evens things out, if not, I'll need to get this looked into. Anybody suggest someone in particular?
WRXXX is offline   Reply With Quote
Old 02-28-2007, 06:40 PM   #2
05redrex
Member#: 86665
2005 WRX SRR 2.5/20g
2010 FXT SWP Cobb Stg2+
Read the map notes, and make your car as close to their notes as possible. Since you can't modify the AP map you are kind of limited.
05redrex is offline   Reply With Quote
Old 02-28-2007, 06:42 PM   #3
WRXXX
Member#: 9602
'02 WRX
It's dead on Stage 2... been that way for 4 years.
Old 03-01-2007, 12:48 AM   #4
darkROAM_1
Member#: 80964
2010 Impreza
umm, boost issues will most likely be from the 3/16 mod, also, check your hoses and replace them if needed. Make sure even the little reducing coupling is in there. That alone will cause issues w/o it.
Once you fix it all, reset the ECU. Also, do not load maps that you got from a CD, those will be corrupted. You must get maps directly from Cobb to the AP. My 02 had bad maps since I got them on a burned CD I got w/ the AP from a vendor.
darkROAM_1 is offline   Reply With Quote
Old 03-01-2007, 09:11 AM   #5
antiks
Member#: 98463
2002 no more bugeye
AW 335i jb3 ;)
what's the wierd boost issue? 3/16 mod can cause spikes..
that reducer pill can cause you to run wastegate boost...
antiks is offline   Reply With Quote
DFW - OpenECU Tuners Cronos Texas Impreza Club Forum -- TXIC 5 01-02-2007 05:10 PM
dyno tuners in DFW area ScobyWRX Texas Impreza Club Forum -- TXIC 2 05-26-2005 12:37 AM
DFW area tuner (with dyno) Anyotherone Texas Impreza Club Forum -- TXIC 19 01-30-2004 10:15 AM
WRX owners in the DFW area jasonstherapy Texas Impreza Club Forum -- TXIC 4 06-06-2001 12:07 AM
Spotted in DFW area Turbo4me Texas Impreza Club Forum -- TXIC 4 05-26-2001 12:21 AM
