Old 12-04-2001, 07:00 PM   #1
gumball
Member#: 1209
Default Help- squeaking noise that goes away
Hey, this is bugging me, I have a squeaking
noise from the engine bay that almost sounds
like a loose drive belt- its noisy at idle.
But the strange thing is, it goes away when
I press the clutch in about 1" and stays
away as long as the clutch is depressed.
So if its not a belt, what is it? Or if
it IS a belt, why does it go away when the
clutch is in?
thanks for any help!
gumball is offline   Reply With Quote
Old 12-05-2001, 01:30 PM   #2
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
It's probably is a loose belt. Try checking the deflection for each belt by putting a straight edge between the two pulleys that the belt goes around. Then press on the belt away from the straight edge. The belt should not deflect more than 1/4". See the picture below:
Richard L. is offline   Reply With Quote
Old 12-05-2001, 01:37 PM   #3
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
I just noticed the same thing on my car. At idle, there is a squeek. When I just touch the throttle, bringing the rpm's up maybe 200, it goes away.
I'll have to check the belt myself, when I get a chance.
tcs007 is offline   Reply With Quote
Old 12-06-2001, 12:57 PM   #4
gumball
Member#: 1209
Thanks for the info!
What worries me is that it goes away when
I hit the CLUTCH. So wouldn't that suggest its coming from the somewhere else, like the transmission? Though I can't imagine such a thing.
Old 12-06-2001, 01:47 PM   #5
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Could it be your transmission mounts?
Richard
Clunk/Grind... that goes away when braking? twizzstyle Transmission (AT/MT) & Driveline 3 10-02-2008 12:49 PM
help! squeaking noise WickedGrip Interior & Exterior Modification 0 04-25-2007 02:55 PM
Thumping noise that goes faster with speed JEEENKINNNS Transmission (AT/MT) & Driveline 5 12-06-2006 08:49 PM
shimmy that goes away at 70mph? sick1.8t Brakes, Steering & Suspension 14 10-22-2005 10:00 PM
Help, squeaking noise from a 04 STI clutch pedal bestsw20 Transmission (AT/MT) & Driveline 9 12-09-2003 10:52 AM
