Old 03-02-2007, 05:05 PM   #1
sonny2
Member#: 93182
'08 WRX STI
'03 Porsche Boxster S
Question Windshield covered under warranty?
This might be a dumb question but was wondering if anyone knew if the windsheild is covered under warranty?
I know stuff that is damaged from usual wear & tear or abuse isn't covered (but brake pads & wiper inserts ARE covered by Subaru). In the case of my windshield, a crack appeared on the driver's side this morning & is slowly getting longer/spreading. There is no discernable damage like a rock having hit the glass. It's just a crack starting at the very edge of the windsheild & moving across.
Anyone?
sonny2 is offline   Reply With Quote
Old 03-02-2007, 05:09 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
take a ball point pen and run it's tip in the crack. It will drop into the hole that started the crack.
Subaru does not cover windshields under warranty... but they may do a good will if no rock chip can be found.
Have the crack filled before it spreads though...
Mavrik is offline   Reply With Quote
Old 03-02-2007, 06:05 PM   #3
jeffroh22vtec
Member#: 116136
most insurance polices have total glass coverage built in. call yours and i bet you got it. it shouldn't raise your premiums either.-jeff
jeffroh22vtec is offline   Reply With Quote
Old 03-04-2007, 03:46 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Everything is covered to 3/36k. After that, it's your insurance (if it covers it).
Brian
Old 03-06-2007, 01:48 PM   #5
sonny2
Member#: 93182
'08 WRX STI
News
Just called my local Subaru dealership -- Subaru of Morristown NJ -- & the service guy there said windshield damage is NOT covered under warranty.
But he did suggest I bring the car in next week anyway to have the service manager look at it. (Next week b/c the manager is on vaca this week.)
I'll give it a shot & report what happens.
Old 03-06-2007, 09:11 PM   #6
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Not true.......a broken windshield is usually caused by an outside influence, which is not a matter for warranty. There are rare instances where a windshield can crack from stress, but it's unlikely. Most windshields break because of a chip from a rock, etc.
RexyGirl is offline   Reply With Quote
Old 03-12-2007, 04:01 PM   #7
racingfish
Member#: 60976
1969 LGT
FATURBO
tires? i wish they were covered by 3/36
racingfish is offline   Reply With Quote
Old 03-13-2007, 03:18 AM   #8
wrxEMT
Member#: 5693
2006 MCS, '05 OB XT
'03 SV650
tires...possibly. I have an 05 OB XT and the tires wore extremely fast on the outside shoulder. I thought the alignment and toe were off. After finally getting the subaru tech to check it, I found out it was off by quite a bit and they replaced all 4 tires with an alignment. Apparently it was out of spec from the get go.
wrxEMT is offline   Reply With Quote
Old 03-13-2007, 04:43 AM   #9
randdaman7
Member#: 83587
2003 WRX Boostwagon
2007 Impreza
wiper blades are covered...right fish? lol
randdaman7 is offline   Reply With Quote
Old 03-13-2007, 10:05 AM   #10
RexyGirl
Member#: 63616
with mods :)
The tires were covered because the alignment was off....it was resulting damage, that's why Subaru took care of it.....
But if the tires were just normally worn....not covered.
Wipers are covered....
Old 03-13-2007, 10:18 AM   #11
sonny2
Member#: 93182
'08 WRX STI
No go on the replacement of the windshield by Subaru. There was a pit which could have been from a stone. Just got the windsheild replaced today by a company that comes to you. Job was done quickly & professionally. I would have gone through my insurance company but the cost of the replacement was less than half my deductible so that was a wash.
Old 03-13-2007, 10:22 AM   #12
LastResort
Member#: 99289
Have you actually checked the terms of your insurance? A lot of companies have zero deductible on windshields.
LastResort is offline   Reply With Quote
Old 03-13-2007, 01:36 PM   #13
racingfish
Member#: 60976
1969 LGT
FATURBO
absolutly... which reminds me i have to get my rear changed out. it has prematurly come apart. even tho its 90+ degrees outside i think i should get it replaced.
Old 04-10-2007, 02:50 PM   #14
stu1811
Member#: 124651
2011 LGT
^^ i got my rear wiper blade replace for free. had ~13k on car.
stu1811 is offline   Reply With Quote
Old 04-10-2007, 05:12 PM   #15
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Also there are a few one time adjustments that can be done under warranty and they are alignments and wheel balances, brakes and other wear items can be as well.
blackfang is online now   Reply With Quote
Old 04-10-2007, 06:42 PM   #16
CynicX
Member#: 48199
06 WRX
Should have just called your insurance just in case. Some states require no deduction no penelty glass repair no matter the cause...
South Carolina is like that. If your windshield breaks you call the insurance and they send someone out to replace it. No questions asked, no deductible, no nothing....
My insurance policy in maryland also covers it with no deductible but its part of the policy I took out...
CynicX is offline   Reply With Quote
Old 04-10-2007, 09:30 PM   #17
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Inserts now, not blades. Only if inserts are not available.
Are windshield wipers covered under warranty? thsiao Warranty Issues & SOA Problems 32 08-04-2005 11:46 AM
Is windshield covered under 30k warranty? wildnuts Service & Maintenance 3 03-25-2003 02:39 AM
It might be covered under warranty! kevinsUBARU New England Impreza Club Forum -- NESIC 0 04-09-2001 03:46 PM
Exhaust leak - covered under warranty? Tim K. Technical Forum Archive 8 06-08-2000 12:11 AM
