Old 12-05-2001, 11:11 AM   #1
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Default Anbody else have problems with their car @ 5K RPM's?? (DTC P1544 related?)
I've been having problems with my car at 5K RPM's and above. Below that the car seems fine. I've had plenty of CEL's...all leading to code P1544 (high exhaust temp). My dealer thought the problem was with the stock EGT sensor, since that was the only code they pulled. I dropped it off with them yesterday and they disconnected the stock EGT sensor. They thought that was the problem, but when I drove the car home...it still drove like crap.
My only mods are a BPM GT turboback and a Turbo XS BOV, and K&N.
Pretty much when I come close to 5K RPM's the car slows down and doesn't seem to pull as hard. Once, I hit 5K, the car starts to stutter and hesitate, and even starts bucking. I also have an EGT gauge and that starts to skyrocket. I mean it shoots right up to 1600 degrees. So, that makes me think that it's not getting enough fuel. That's what it feels like...
Anybody have this happen to them or have any ideas why it's doing this???
redobs is offline   Reply With Quote
Old 12-05-2001, 11:32 AM   #2
mdntridr
Member#: 8886
2004 Ford Ranger
'05 Honda VTX1300C
Hey pete, what kind of boost are you running? Could this be related to the BPM-wastegate-holding-shut thing?
--Greg--
mdntridr is offline   Reply With Quote
Old 12-05-2001, 11:36 AM   #3
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Stock boost...supposedly, I got my exhaust before the problem with the wastegate. Greg, Is this what your car was doing??
Old 12-05-2001, 12:03 PM   #4
mdntridr
Member#: 8886
2004 Ford Ranger
'05 Honda VTX1300C
When I would get on the gas hard I would boost ~18-20 PSI, then fuel cut and CEL. I don't know the code, unfortunately. If you're not seeing boost spikes then chances are you don't have the same problem I did.
Does this problem exist only under boost, or does it occur even while under vacuum? Sounds like it could be a vacuum leak, or faulty MAF (see God's thread. Neither of those explains the high EGTs, though.
Do you have an OBD scanner? If so you can data log MAF and RPM and MAP and see what happens. If you have a bad MAF sensor then maybe it starts reading very little air and cuts fuel accordingly.
I dunno, I hope it works out for you.
--Greg--
Old 12-06-2001, 12:59 PM   #5
redobs
Member#: 1501
2009 WRX wagon
Dark grey
bump
Old 12-06-2001, 04:39 PM   #6
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Start there... Stock boost isn't even close..
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
