Old 12-05-2001, 01:02 PM   #1
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Question temp. rust spot containment?
The other day as I was waxing my scooby, getting it ready for the winter months to come... i notice i had a nice rock ding on my hood... down to the metal.. and beginning to rust... i'm wondering this...
since it's getting too cold to put touch up paint on it... is there anything i can do to try to contain the rust for the winter until i'm able to get everything i need to clean it and fix it? i was thinking maybe a part of a clear bonnet or something... i'm not entirely sure... any ideas????
i put a thick layer of wax on it, that might hold... but the car will unfortunately be outside under a car cover during the harsh weather ahead... and i'd rather not have to get the entire hood painted... any help would be greatly appreciated...
AJ
AJ711 is offline   Reply With Quote
Old 12-05-2001, 02:59 PM   #2
loafing1
Member#: 7133
2002 WRX Wagon Slvr
1991 Toyota 4Runner
It's not rusting from underneath, so it's probably not going to rust much farther, not to mention it's not going to get as much road-crap salt on it up on the hood.
But... you can get 'Rust-Mort' or Naval Jelly. Both should do the trick. I've used Rust-Mort before and it worked. It's a liquid (you'll probably have to clean the wax off of that area first) that you just dab on the affected area with a cue-tip or something. Just tape off that area. After a few times (let dry in between) It will turn the rust into a hard black substance that no longer oxidizes (rusts). Then prime and touch up when you can.
loafing1 is offline   Reply With Quote
Old 12-05-2001, 03:15 PM   #3
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
thanks for your reply... i'll look into that... it sounds like just the product i'll need... thanks a ton...
AJ
patching rust spot on muffler? SlackMeister Service & Maintenance 1 07-15-2005 10:26 AM
Need Help on RUST spot bigbear522 Canada Region Forum 17 02-27-2004 10:40 AM
Rust spot Jersey Mike Warranty Issues & SOA Problems 2 06-30-2002 12:45 PM
Rust Spot Jersey Mike Tri-State Area Forum 0 06-29-2002 07:11 PM
stomung (non SS) with high temp rust inhibitor? HRE | giulio Technical Forum Archive 5 06-07-2000 02:20 PM
