Old 03-05-2007, 03:49 PM   #1
pdippel
Member#: 20611
2003 WRX
World Rally Blue
Default Need help troubleshooting OEM oil temp gauge
I need help troubleshooting my oil temp gauge. It is always pegged at 160 degrees as soon as I turn on the car. Turning off the car returns it to the lowest reading.
I have taken readings of the resistance of the connection to the sensor. It varies depending if it is hot or cold. I don't remember the actual readings but it was 800 ohms on one of the readings.
There are five connections to the gauge. 3 are for the lighting (I'm assuming because the mechanical boost gauge also has these 3 wires), and 2 go to the sensor. one of the 2 connections also has a connection to the cluster harness. I have not determined is this is power or ground but I would guess it is power.
How can I tell if my gauge is bad or if it the sensor?
pdippel is offline   Reply With Quote
Old 03-12-2007, 12:19 AM   #2
burton2323
Member#: 133820
2002 stage 2
MBP
same exact thing just happened to me except mine was pegged at the lowest reading. somehow mysteriously fixed it when i switched it with boost (OEM gauge cluster)
check the bolt on bottom of oil pan with the wire coming out of it, thats where the sensor is
burton2323 is offline   Reply With Quote
Old 03-24-2007, 10:34 AM   #3
pdippel
Member#: 20611
2003 WRX
World Rally Blue
Yeah, I think the sensor is working because a see a difference in the resistance of the sensor wires when it's hot or not.
Does anyone know how this gauge works?
Old 03-27-2007, 11:40 PM   #4
pdippel
Member#: 20611
2003 WRX
World Rally Blue
bump to get some response
WTB oem oil temp gauge mooserage Private 'Wanted' Classifieds 5 01-08-2008 10:26 PM
OEM oil temp gauge theo79 Electrical & Lighting 1 11-30-2007 10:21 PM
Problem with OEM oil temp gauge txl146 Electrical & Lighting 1 07-23-2006 12:21 AM
need help installing a exhaust temp gauge avengermike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-24-2006 10:43 PM
OEM Oil Temp Gauge wiring wonny Electrical & Lighting 2 11-05-2004 03:11 PM
