Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 03-05-2007, 10:54 PM   #1
SubaruCrazy
Member#: 114474
2003 WRX
Default FS: USED Zeal Function V6 Coilovers
Zeal Function V6 Spring Rate Hard 10K/8K PM for pricing
This steel-type, inverted-monotube type shock absorber is produced for specific vehicles with strut-type suspension. The shock absorber for this type of set up takes great abuse, thus side load attributes must be strengthened. An inverted monotube with a Friction-Loss Cylinder was developed for this matter. While using the Function Series' technology, we've produced the new Zeal model for high performance driving. The nitrogen gas camber is positioned higher up and farther away from the braking area creating less heat transfer and thus, less chance for overheating. Also, under-spring weight is now lighter enabling handling to become sharper, quicker, and more responsive. Our easy-to-read and use, 6-Way Piston Valve Shock (PVS) Dial mechanism adjusts the rebound/compression force with its Piston Valve Shock Technology, Level 1 being the softest and Level 6 being the stiffest. Dial can be turned either direction infinitely. Pillow Ball camber adjustable upper mounts for direct feel of suspension motion help to decrease piston rod tension. ID60 Basic Spring (Street or Hard rates) maintains stroke and ensures a "seated" fit with upper and lower portions processed to a flat cut. The Adjustable Shock-Stroke System is a separate, adjustable lower cup/bracket used for height adjustability which eliminates problem of sacrificing stroke and altering spring tension. Spin the mechanism over the threaded shock casing up to lower (and down to raise) vehicle height. All Zeal Function Series systems include this height-adjustable system.
Thanks,
Greg
SubaruCrazy is offline   Reply With Quote
Old 03-06-2007, 02:35 PM   #2
SubaruCrazy
Member#: 114474
2003 WRX
Fits MY02-04
Old 03-06-2007, 05:13 PM   #3
speednby
Member Sales Rating: (17)
Member#: 86316
2003 WRX Wagon
I eat rice...Its good 4 u
PM Sent...
speednby is offline   Reply With Quote
Old 03-06-2007, 10:29 PM   #4
SubaruCrazy
Member#: 114474
2003 WRX
PM received and responded. Need to sell ASAP!
FS: ZEAL Function V6 coilovers DrewSTi Suspension/Brakes/Handling 1 12-12-2007 11:31 PM
FS: ZEAL Function V6 coilovers DrewSTi NESIC Private Classifieds 0 08-28-2007 06:50 PM
FS: Zeal Function V6 coilovers Oregon TicketsForMePlease NWIC Private Classifieds 8 09-26-2006 11:15 PM
FS: Zeal Function V6 Coilovers for 05 STi z3coupe Private 'For Sale' Classifieds 15 01-23-2006 06:16 AM
