Old 03-06-2007, 12:19 AM   #1
pillarguy17
Member#: 103392
Default endlinks needed for 22 mm rear swaybar?
Do I need upgraded rear endlinks for a 22 mm swaybar? How have the plastic ones held up for some of you over time. I am excited, I am putting on the new swaybar on tomorrow. Any tips, I am guessing it is just as easy as a front swaybar.
Thanks,
pillarguy17 is offline   Reply With Quote
Old 03-06-2007, 02:08 AM   #2
glider
Member#: 133427
2011 STI Sedan
It's actually a lot easier than the front sway. No subframe removal or anything.
Received wisdom is to upgrade the endlinks. From what folk say you might want to upgrade to 2004+ mounts, too.
glider is offline   Reply With Quote
Old 03-06-2007, 07:45 AM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
+1 and +2. Glider is spot on.
Old 03-06-2007, 09:50 AM   #4
greenguy
Member#: 221
08 Oddyssey
2011 GTI
greenguy is offline   Reply With Quote
Old 03-06-2007, 09:55 AM   #5
ray101381
Member#: 131327
2012 Audi A7
2013 Raptor, 2013 Ducati
kartboy ftw
ray101381 is offline   Reply With Quote
Old 03-06-2007, 09:56 AM   #6
ray101381
Member#: 131327
2012 Audi A7
off topic but TiC ftw klunk killer is great
Old 03-06-2007, 01:49 PM   #7
PARANOID56
Member#: 22035
2008 STI
Yes, upgrade them. and yes get the Kartboy ones.
Shane
PARANOID56 is offline   Reply With Quote
Old 03-06-2007, 08:37 PM   #8
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
Whiteline has a great tech paper available online where they discuss the benefit of their alloy/poly HD endlinks vs. the stock subaru plastic/rubbers (rears). In summary, their analysis shows that for a 20mm rear bar, adding the HD endlink would be similar to running a 20.07mm rear swaybar on the stock endlinks. And for a 24mm bar, adding the HD endlink would be like running a 24.17mm bar on the stock endlink. These are for street cornering maneuvers with 1g peak loads.
The greater the cornering force (race setups) and the greater the size of the bar, the greater the benefit of the HD endlink.
http://www.whiteline.com.au/articles/WL_Alloy_link.pdf
Mind is online now   Reply With Quote
FS : OEM STOCK 08 STI Front Sway Bar, OEM Endlinks Frt & Rear CH Conceptz Suspension/Brakes/Handling 5 06-23-2010 09:54 PM
need suggestions on springs for KYB G2's deftonez99 Brakes, Steering & Suspension 3 06-05-2010 11:21 PM
The Eyes Have It: No Need for Radar Gun in Ohio bangedlegacywagon97 Off-Topic 17 06-04-2010 08:54 AM
Need wiring diagram for 04 sti ocv solenoid sti3573 Factory 2.5L Turbo Powertrain 1 06-03-2010 04:59 PM
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
Message Board Statistics All times are GMT -4. The time now is 09:43 AM.
