Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 03-06-2007, 02:10 AM   #1
mogrl840
Member#: 85298
Keep talkin **** you
are makin me famous
Default cobb accessport map help
I have a 04 sti and I would like to know what map I should use and what other mods should I do.
Thanks,
Modifications:
Perrin divorced DP
K&N intake
Turbosmart BOV
Invidia g200 catback
Stock TMIC
Stock up pipe
mogrl840 is offline   Reply With Quote
Old 03-06-2007, 02:19 AM   #2
STIBungy
Member#: 51684
Your mods are what Cobb calls a stage 2 upgrade. Just use their stage 2 map.
STIBungy is offline   Reply With Quote
Old 03-06-2007, 02:25 AM   #3
mogrl840
Member#: 85298
are makin me famous
does it matter what stage 2 map I use? I see they have different octane maps. What would be the best?
Old 03-06-2007, 02:45 AM   #4
mogrl840
Member#: 85298
are makin me famous
I can't find the page on the downloads, is it me or what. I keep clicking on the map download page and it takes me back to the home page??? Can someone find the page and send me the link. Thanks.
Old 03-06-2007, 06:01 AM   #5
djsina
Member#: 142679
2006 2006 WRX
rally blue
It depends. I see you live in AZ thats cool I went to ASU in tempe for a while. Anyway there is a few different Stage 2 maps. Don't worry about the ones that are about different Turbos like "18g" or "FPgreen" as you described you still have the stock turbo. It depends on what octane gas you are using. 91 is the common premium in arizona correct? So also they have a 91 "ACN" map which means Arizona Cali Nevada, cuz those states get crappier gas. So unless you are getting higher octane gas, which is possible, do the ACN 91 maps. there are places that sell 100 octane at the pump, and (and others that sell 110+, but you need to be tuned for that high octane to actual reap benefit) then you can mix that with 91 and run the Stage 2 93 map, which will yield the maximum benefit. I myself now live in cali but go to a specific 76 station to get 100 octane gas at the pump, so I can run the 93 maps. You can mix 91 and 100 too and still run the 93 maps. Also don't use the 93 maps if you arent running 93+ octane, it will cause your car to have "knocking" problems.
djsina is offline   Reply With Quote
Old 03-06-2007, 02:37 PM   #6
mogrl840
Member#: 85298
are makin me famous
^ Thanks. That is some good info.
Old 03-06-2007, 04:55 PM   #7
willz23
Member#: 52954
08 FXT Sport
willz23 is offline   Reply With Quote
Fp 18g Cobb Ap Map Help rainsory Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-22-2007 05:11 PM
cobb accessport w/vf34 map 04wrx555 Member's Car Gallery 2 01-25-2005 02:04 PM
Older revision Cobb Accessport Maps crazymikie Engine Management & Tuning 11 01-22-2005 08:08 PM
Revised Cobb STi AccessPORT Maps Available dsmperformance Engine Management & Tuning 7 10-08-2004 05:23 PM
