Old 03-06-2007, 09:56 AM   #1
bluesubie
Member#: 767
04 FXT
Forester UOA - Castrol Syntec 0W30 (GC), 7k miles, FXT
UOA by Blackstone and oil was in use from April December 06. My daily trips are 5 miles each way and I drive on the beach in the spring, summer and fall. Engine is stock and I don't race. No oil was added during the interval.
Current fill is Motul Eco-nergy 8100 5W30 because I wanted to try a thinner oil (9.9 @ 100C) due to the short trips (and colder temps). I'll probably be getting a Dyson Analysis shortly.
1st column current; then Gold GC w/ 7,478, Gold GC w/ 6,144 miles, Green GC w/ 5,930 and M1 5W30 w/5,774.
Equipment make: Subaru Equipment model: 2.5L Turbo
Oil use interval: 7,000
Oil type & Grade: Castrol Syntec 0W30
Make-up oil added: 0
Miles on unit: 44,750
Air filter: OEM Oil filter: OEM
Fuel is an on again, off again find in your Subaru. Its off again in this sample. We assume it has something to do with the way you operate the engine racing or idling or doing a lot of city driving. In any case, a trace is not a problem. Wear still looks great and shows no changes that would indicate a problem developing. The viscosity again read higher than expected. Contaminents will cause the viscosity to increase (though a trace of fuel wont do it. Excessive heat, like from racing, could cause an increased vis. We doubt sodium is an issue. Check back.
Code:
Aluminum 5 4 4 4 6
Chromium 1 1 1 1 1
Iron 12 16 11 10 15
Copper 8 7 10 6 20
Lead 3 3 3 2 2
Tin 1 0 1 0 0
Molybdenum 2 9 4 12 63
Nickel 0 0 0 1 0
Maganese 1 1 0 0 0
Silver 0 0 0 0 0
Titanium 0 0 0 0 0
Potassium 2 0 0 0 3
Boron 0 0 1 14 115
Silicon 13 13 15 15 18
Sodium 19 18 6 2 6
Calcium 1783 2165 1689 2582 3394
Magnesium 530 436 398 106 10
Phosphorous 796 816 754 680 764
Zinc 974 1011 909 818 904
Barium 0 0 0 0 1
Properties
SUS Viscosity @ 210F: 66.2 66.4 64.4 64.8 57.8 [58-65]
Flashpoint: 380 380 385 365 395 [>385F]
Fuel %: TR .2.3 .5 1.0 .5 [<2.0]
Antifreeze: 0 ? 0 0 0[0]
Water: 0 0 0 0 0[<0.1]
Insolubules: .4 .2 .5 .4 .5[<.6]
-Dennis
German Castrol Syntec 0W30 stiskeet Service & Maintenance 17 08-24-2009 09:50 PM
German Castrol = Castrol Syntec 0W30 European Formula? Glenn Hough Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-27-2008 08:25 PM
German Castrol Syntec 0W30 Jon Bogert Engine/Power/Exhaust 4 08-19-2007 07:28 PM
Used oil analysis FXT 6,144 miles German Castrol Syntec 0W30 bluesubie Service & Maintenance 4 11-19-2005 08:21 AM
Oil analysis on German Castrol Syntec 0W30, 5,930 miles, FXT bluesubie Service & Maintenance 8 03-26-2005 10:06 AM
