Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 03-06-2007, 11:26 AM   #1
BDR
Member Sales Rating: (59)
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
Default 02-03 WRX PSI3 ECU Monitor(PIC)
For Sale: $300+shipping and Paypal fees
Older version, in "EXCELLENT" condition. comes with 4 spare faceplates. Only works on 02-03 WRX's. all you will need for install is the OEM dash pod kit($50).
Link to PIC:
The Psi3 ECU monitor is a device designed to monitor the sensors and operation of the vehicle engine management system, and assist the driver with performance information and useful diagnostic information when a fault occurs.
The monitor reads its information directly from the vehcle ECU via a bi-directional serial communications link via the OBD-II connector and updates the display data approximately five times every second. The user is able to customize the data points displayed based upon personal preferences. The data is displayed on a 2x24 character vacuum fluorescent display, and is controlled by four buttons. The unit does not interfere with the operaiton of the vehicle in any way (except ECU reset function).
Here are some of the data points that are monitored by the Psi3 unit.
* Boost Pressure (BAR or PSI)
* Intake air temp (C or F) This is NOT charge temp
* Coolant temp (C or F)
* Engine speed (RPM)
* Battery volts
* Throttle Position % (some cars have limited range EG 5-85%)
* Road speed (KPH or MPH)
* Ignition advance (deg. BTDC)
* Air flow (Grams/sec)
* Lambda Ratio
* Knock correction degrees
* Injector duration (milliseconds)
* Exhuast gas temp (WRX only, stock EGT probe only)
* Time of day
* Oil temp (requires external sensor kit)
* Oil pressure (requires external sensor kit)
Additionally the monitor will display:
* Peak boost
* Peak coolant temp
* Peak RPM
* Peak road speed
In additon to monitoring all that data you also get all sorts of other cool features such as user definable alarms for the following:
* Low battery voltage
* High battery voltage
* Overboost condition
* High coolant temp
* High oil temp
* Low oil pressure
On top of all that you can set the unit up to for a shift light, automatic water/methanol spray control (many folks use this for automatic I/C spray), displaying CEL codes, and resetting the ECU. Shift light and spray control require external relays and parts.
BDR is offline   Reply With Quote
Old 03-06-2007, 11:46 AM   #2
soulska
Member Sales Rating: (27)
Member#: 131412
"03" RA~VF34 Beast
~ECKK/F4F RMK#3~
PM Sent
soulska is offline   Reply With Quote
Old 03-06-2007, 03:17 PM   #3
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
Old 03-06-2007, 05:20 PM   #4
acurry420
Member Sales Rating: (2)
Member#: 117792
2006 WRX wagon
Too bad it won't work on an '06, otherwise you would have it sold. Do you know why it wouldn't work on an '06?
acurry420 is offline   Reply With Quote
Old 03-06-2007, 10:48 PM   #5
Turn in Concepts
Vendor Sales Rating: (159)
Member#: 93646
Many Track Records
Let us help you go fast!
It will work with any 02+ subaru.
Old 03-08-2007, 09:53 AM   #6
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
well thank you sir!
Old 03-08-2007, 05:02 PM   #7
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
Old 03-08-2007, 05:31 PM   #8
SQ3.0dotJP
Member Sales Rating: (1)
Member#: 136330
# OCCUPY
wow, im poor this week but i want one... may eliminate my carputer needs. does this work with wideband afr?
SQ3.0dotJP is offline   Reply With Quote
Old 03-09-2007, 08:13 AM   #9
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
not sure, but you can ask the guys at Turn in Concepts few posts up. they'll probably be able to answer that.
bump!
Old 03-09-2007, 12:21 PM   #10
Unabomber
👌 Big Ron 👌
Member Sales Rating: (11)
Member#: 18062
on car parts so PM
me b4 j00 buy
Wont work with wideband as I have one of these as well.
Old 03-10-2007, 09:28 PM   #11
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
Old 03-11-2007, 09:28 PM   #12
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
Old 03-11-2007, 10:05 PM   #13
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
These units are awesome. I just installed the ECUTek version in a customers car and was blown away by the amount of information it displays and how much it can do.
These arent sold any more and the manufacturer's website is gone. ECUTek has told me they will be making a new version soon though.
I will let some of the locals know and see if I can help you sell it. I would take it but it wont work in my LGT.
-Matt
ShaggyGT is offline   Reply With Quote
Old 03-12-2007, 04:02 PM   #14
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
thanx for the bump bro!
Old 03-13-2007, 12:03 PM   #15
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
Old 03-14-2007, 11:32 AM   #16
BDR
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
Old 03-14-2007, 11:14 PM   #17
AudiobahnSTI
Member Sales Rating: (24)
Member#: 99339
04 STI
I def want to get this from you. I have the money in hand.. Call me asap. I can meet up with you anytime today or tomorrow.. Let me know.
Thanks
Robert
AudiobahnSTI is offline   Reply With Quote
Old 05-07-2007, 10:36 PM   #18
acurry420
Member#: 117792
2006 WRX wagon
Sold yet or still for sale?
Fs: 02/03 Wrx Mt Ecu (ny) txl146 Engine/Power/Exhaust 3 12-29-2008 02:52 PM
FS 02-03 Wrx Ecutek'd ecu 150. LiquidForce Engine/Power/Exhaust 2 02-08-2008 07:03 PM
WTB: 02-03 WRX MT ecu ICECREAM ///MAN Private 'Wanted' Classifieds 1 03-28-2007 08:30 PM
02-03 wrx stock ecu needed Under_pressure South West Impreza Club Forum -- SWIC 5 12-14-2006 06:54 PM
New service bulletin for 02-03 WRX ABS ECU file_id Southern California Impreza Club Forum -- SCIC 24 08-26-2005 03:01 AM
