Old 03-06-2007, 04:28 PM   #1
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Default Discuss: Water and water+meth tuning
I've read the thread over at Aquamist's forums completely. Not for lack of trying, and no offense to the posters there, but I found it lacking in modern real-world data.
The 1943 NACA reports are useful (if you can extract them from NASA's very tantrum-prone server), but it seems high time this area was evaluated again.
Yes, I know, we'd all love to have per-cylinder pressure sensors, engine dynos, and all sorts of fun and expensive equipment. I know we don't, and I know it's out of reach, but I have to believe that everyone is interested in using the tools we have to determine somewhat conclusive information about :
* best water:fuel ratios
* best water+meth:fuel ratios
* timing adjustment logic
* anything else
I'm looking to gather water/meth injection testing results from at least the last few decades in this thread.
If anyone has anything to contribute, or if anyone else wants to join the search for good information, please chime in as you find things.
Here's what NASA/NACA has to offer from the end of WWII:
Evaluation of centrifugal compressor performance with water injection (1951)
Abstract: The effects of water injection on a compressor are presented. To determine the effects of varying water-air ratio, the compressor was operated at a constant equivalent impeller speed over a range of water-air ratios and weight flows. Operation over a range of weight flows at one water-air ratio and two inlet air temperatures was carried out to obtain an indication of the effects of varying inlet air temperature. Beyond a water-air ratio of 0.03 there was no increase in maximum air-weight flow, a negligible rise in peak total-pressure ratio, and a decrease in peak adiabatic efficiency. An increase in inlet air temperature resulted in an increase in the magnitude of evaporation. An analysis of data indicated that the magnitude of evaporation within the compressor impeller was small.
Summary report on the induction of water to the inlet air as a means of internal cooling in aircraft-engine cylinders (1943)
No Abstract Available
Effect of several methods of increasing knock-limited power on cylinder temperatures (1944)
Effect of water injection on knock-limited performance of a V-type 12-cylinder liquid-cooled engine (1944)
Calculations of intake-air cooling resulting from water injection and of water recovery from exhaust gas (1944)
Continuous use of internal cooling to suppress knock in aircraft engines cruising at high power (1944)
Effect of Water-Alcohol Injection and Maximum Economy Spark Advance on Knock-Limited Performance and Fuel Economy of a Large Air-Cooled Cylinder (1945 -- direct link to PDF)
jblaine is offline   Reply With Quote
Old 03-06-2007, 04:51 PM   #2
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I've purchased this for $30 just now and it looks pretty good.
"Thermal balance of a LPG fuelled, four stroke SI engine with water addition • ARTICLE
Energy Conversion and Management, Volume 47, Issue 5, March 2006, Pages 570-581"
sciencedirect.com
Tested engine specifications
Type 4 cycle, 4 cylinders
Rated speed (1000–4500) rpm
No. of cylinders 4
Bore × stroke (mm) 76 × 71.5
Displacement volume 1297 cm3
Compression ratio 7.8:1
Cooling system Water cooled
Lubrication system Force feed
Old 03-06-2007, 05:55 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Diesel tech, but free, and from 2004...
"THE INFLUENCE OF WATER INJECTION ON THE THERMAL EFFICIENCY & SPECIFIC FUEL CONSUMPTION OF A CI ENGINE"
http://www.fisita.com/students/congr...apers/sc24.pdf
Old 03-06-2007, 07:39 PM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Trying to get this (cleared for public release):
Abstract: Dynamometer studies were conducted at the U.S. Army Fuels and Lubricants Research Laboratory in an L-141 military SI engine to evaluate the effects of intake port water induction on fuel economy, power, and exhaust emissions. The engine was equipped with a variable jet carburetor to permit independent control of mass fuel and air flow as required by the constant speed-constant fuel flow-variable air flow technique used, and the intake manifold was reworked to accommodate a water induction tube at each port. Crankcase emissions controls were deleted to avoid blow-by contamination of the intake charge, and the fan and radiator were replaced by a water-to-water heat exchanger in a vented cooling system charged with treated tap water. Specification VV-G-001690 Special Grade unleaded gasoline and a MIL-L-2104C grade 30 oil were selected as the reference fuel and lubricant, while de-ionized water was used for induction purposes.
http://stinet.dtic.mil/stinet/jsp/do...28s%29&MC=&PE=
Old 03-06-2007, 07:43 PM   #5
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
And this is most definitely not supposed to be publicly available, so grab it before the dude notices or he gets sued by SAE:
"Water Injection Effects In A Single-Cylinder CFR Engine" : SAE Technical Paper 1999-01-0568
Though analysed by a few researches, the practice of water injection in Spark Ignition Engines (SI-ICE) does not yield homogeneous results, owing to various typologies of engines used for experiments. In this paper the effects of water injection in the intake pipe are investigated from both a theoretical and experimental viewpoint. Pressure vs. time diagrams were recorded on a single-cylinder CFR engine at AGIP PETROLI, Priolo (CT). Tests were performed according to Research and Motor Method (ASTM). Water was supplied by a continuous injection system inclusive of comparatively high pressure pump. The engine was fed with low O.N. base gasoline (cheap products, intermediate of refinery processes). The water to fuel mass flow rate ratio was varied in the range 0 to 1.5. The NOx emissions measurements confirm the tremendous effectiveness of water injection in reducing the engine environmental impact. Test data have been used to implement a detonation model that allows to predict water injection effects. Results have shown that water injection really represents a new way to avoid detonation, to reduce compression work and to control NOx formation in SI engines.
http://not2fast.wryday.com/thermo/wa...99-01-0568.pdf (Direct PDF link)
Old 03-17-2007, 10:18 AM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
*crickets*
Old 03-18-2007, 05:30 PM   #7
Johnnyblueeyes
Member#: 142528
I have the Aquamist but it is not UTEC tuned yet. I heard WI can be hard on the SB, pistons, cylinder walls . right - wrong?
Johnnyblueeyes is offline   Reply With Quote
Old 03-18-2007, 06:11 PM   #8
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
I am surprised that there are no recent tests data on the SAE library.
Aquamist is offline   Reply With Quote
Old 03-18-2007, 06:18 PM   #9
Johnnyblueeyes
Member#: 142528
Any one have an opinion if WI is harder on the SB.
Old 03-18-2007, 06:22 PM   #10
Aquamist
NASIOC Manufacturer
Member#: 110029
What is SB?
Old 03-18-2007, 06:35 PM   #11
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
SB - short block, or the subaru engine case with internals..
Old 03-18-2007, 06:38 PM   #12
Aquamist
NASIOC Manufacturer
Member#: 110029
Thank you...
Old 03-18-2007, 08:47 PM   #13
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Why would WI be hard on the short block? When properly tuned you see cooler EGTs. Every one we have torn down after running WI or WI/meth injection actually looks super clean inside. I suppose if you pushed WAY too much water through the motor something would start to show, but there is nothing magical about spraying water into the air charge, it is in fact very simular to spraying fuel into the air charge.
PDXTuning is offline   Reply With Quote
Old 03-19-2007, 11:27 AM   #14
root
Member#: 55854
2004 STi
Blue/silver
Two common arguments I've heard for WI being bad for the block. 1. If you use meth, it is corrosive. 2. Too much water (like too much fuel) will wash the oil from the cylinder walls. Both are true, but how much they effect the life of the block, beats me. At least for too much water causing bore wash, don't spray so much water.
Now here is another one I heard with regards to the old WWII airplanes and WI. If you spray too much water and it vaporizes inside the cylinder, since water expands more then fuel (so they say, I don't know, and I might be remembering part of this wrong), it can drastically increase in-cylinder pressures to the point of causing serious damage. I assume this requires A LOT of water. Again, this could be bogus, I don't know. Just a related story I heard about damage to blocks from WI.
root is offline   Reply With Quote
Old 03-19-2007, 11:39 AM   #15
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
That would be a rediculous amount of injected water wouldn't it? to wash oil off the cylinder bore? It wouldn't have to be enough water to push the Air:Water+Fuel ratio well below 9:1 wouldn't it? It seems like an absurd amount of water injection would be required.
Dirty25RS is offline   Reply With Quote
Old 06-12-2007, 04:13 PM   #16
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Wasn't too useful. Oh well. And it cost me like $30 to get it.
Old 06-12-2007, 04:14 PM   #17
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
There may very well be, but I'm not a member of SAE.
Old 06-17-2007, 01:28 AM   #18
ace996
Member#: 79874
2006 STI
GreyDragon
The amount of time that the vapor of Meth is in your intake/combustion tract is insignificant for corrosion. It actually does a phenomenal job at keeping the tract clean and keeping the piston-head/combustion chamber from developing accumulation of carbon-deposits. Think of it as a "steam-cleaner" for your engine.
Second...
Water's effect of cooling when it evaporates, makes the in-cylinder charge contract and lessens the pressure....yes, the water expands but it condenses the air much more.
The problem with spraying too much water is a form of "hydro-lock"....where the intake charge isn't able to be compressed as normal...and that causes insane in-cylinder pressures.....very rare if installed/tuned correctly.
One would need to spray a massive amount of water to have this happen.
Shame that there isn't really that much "new" info around on this subject. I do recall that Volvo used W/I on their cars some time back, though.
Be good,
TomK
ace996 is offline   Reply With Quote
Old 06-20-2007, 03:44 PM   #19
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jeff, give me a few more days and i might be collecting some 1st hand data myself...
-ken
Old 06-27-2007, 04:30 PM   #20
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
If you do a google search for ISSN 0280-3902 you will find a gzipped Postscript file in the results (Title of paper is "Increasing the Efficiency of SI-Engines by Spark Advance Control and Water Injection").
There is a Google link there "View as text" which shows the entire paper except the illustrations.
Somehow, I have the PDF with the illustrations. I may have purchased it. I honestly don't recall.
At any rate, I consider this information now publicly available due to the Google find, so here's the PDF file hosted by me. I suggest you right-click and save it to your local host:
http://www.kickflop.net/temp/Spark-A...iksson1997.pdf
Cliff Notes:
Test engine on engine dyno kept at constant RPM and load (LOW, non-FI). Ionization sensor(s) used for in-cylinder pressure monitoring. Automatic ignition timing adjuster hooked to ionization sensor. Fogged water mist inserted into induction path. Results ensue. See Figure 5 in paper for the meat. 5 degrees of added timing brought torque up past its non-WI peak.
Old 06-27-2007, 05:00 PM   #21
Aquamist
NASIOC Manufacturer
Member#: 110029
The book "Internal combustion Engine Fundamentals" by J.B Heyward is a "must-have" for those who wants to uncover the mystery the engine. Highly recommended. Published by McGraw-Hill. 1988
Old 06-27-2007, 05:10 PM   #22
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Agreed 100000000%. It's been sitting next to my bed for the last year now.
The High Speed Internal Combustion Engine by Sir Harry Ricardo (5th Edition) is another "must have", in my opinion. I paid $145 or so for mine via the link below 18 months ago. It's only $70 USD now... sigh.
http://www.ricardo.com/ricardoStore/...ion=2&P_ID=149
Old 08-14-2007, 04:50 PM   #23
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
-ken
Anything to share yet? Been awhile.
Here's all I have so far. It's always slow-going with me and my schedule/motivation level, so I'll use this post as my starting point.
Mix: Roughly 70/30 (water/meth)
Boost: 17-18.5psi across all runs (sprayed and not sprayed)
Injection Amount: ~20%
Method: DataLogLab processing of Hydra CSV files. 4 averaged pulls with WI on, 4 averaged pulls with WI off. Same day, same hour. Roll on throttle at 2500RPMs in 3rd Gear.
Environment FWIW: 90F, ~60% humidity
Caveat: Power figures on axis are VERY rough. Irrelevant to topic.
WI STATE OF TUNING: AFRs roughly 11.6:1, timing roughly 3 degrees advanced up to 4000RPM and 5 degrees thereafter
Old 08-14-2007, 08:04 PM   #24
Aquamist
NASIOC Manufacturer
Member#: 110029
Good post with practical results - how does the water flow MAP looked like and nozzle size.
Old 08-14-2007, 10:46 PM   #25
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
unfortunately jeff i don't have anything to add yet. boxes of parts sit there and mock me while i have become extraordinarily sidetracked with buying a house and moving... i just keep my eyes focused on that nice two story two car garage!
life is what happens to you while you're busy making other plans, right??
Turbo coolant and water hose mcwc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-05-2012 10:15 AM
ok to run meth/water injection without a tune? arrowscooby Water/Methanol Injection, Nitrous & Intercooler Cooling 6 01-04-2009 02:46 PM
Water/Meth Tuning Question Obsessive Water/Methanol Injection, Nitrous & Intercooler Cooling 8 04-03-2008 11:07 PM
Water/Meth Tuning Questions Obsessive Open Source Reflashes 2 03-26-2008 01:00 PM
Timing values and alcohol/meth, water injection reid-o Engine Management & Tuning 0 04-27-2006 03:45 PM
