Old 03-06-2007, 08:42 PM   #1
uathatis
Member#: 117300
Default replacing one tire...
I'm replacing one tire for free (kumho asx 215/45/17)
The rest of the tires are the exact same but worn slightly. they are 5~6 / 32's
the new tire is 9~/32's
Is this alot to worry about? is there a best place to put this replacement tire (front/back)
uathatis is offline   Reply With Quote
Old 03-07-2007, 02:14 AM   #2
div
Member#: 131193
wrb
You wont have any troubles. Kinda funny I just posted about this in another thread.
Placement of the tire will have no benefit, so put it where ever.
What I just wrote:
http://forums.nasioc.com/forums/show...55&postcount=5
div is offline   Reply With Quote
Old 03-07-2007, 03:12 AM   #3
uathatis
Member#: 117300
I was bored and did some math about this 1/4" rule.. on circumference. on a 215/45 tire...17 rim.
cicumfrence of that is 77.34.....
5 /32 down its 76.364
4 32's down down its 76.56
3/32's down is76.75
2/32's down its 76.95
1/32 down its 77.15ish
Notice how its only within little over 1 32 difference? sounds like a little bit to specific tolerance to me. Tirerack says 2/32's for subaru and 4/32's for audi... and porsche says 30%...
i"ve had my tires about 5k... and the new one says its 10/32's on website, i measured one around 9 new and guess that'll be it more likely meaning my 5-6ish should be ok acorrding to audi's standards...
I"m getting realigned too and the guy says not to put new tire in front.. thats why rear.
SO audi's circumfrence :OK: is 3/4 in according to this size tire...
hopefully i'll be within 3-4 myself... in 32's...
Old 03-07-2007, 03:17 AM   #4
div
Member#: 131193
wrb
Right side rear?
Old 03-07-2007, 03:22 AM   #5
Wannascooby
Member#: 112992
2006 WRX TR
Crystal Gray
hmm i just had one bad tire and decided to replace all four. Maybe thats just me to try and be safe then sorry.
Wannascooby is offline   Reply With Quote
Old 03-07-2007, 03:37 AM   #6
uathatis
Member#: 117300
^^^ i did replace all 4 when i had 2 re92's go out on me. at first they tried putting 2 diff brand ones on front of same size, then i read a litltle... and hell no. got 4 asx's..
Old 03-07-2007, 03:38 AM   #7
uathatis
Member#: 117300
Originally Posted by div View Post
Right side rear?
why right side rear? thats actually what i was thinking.. why, i do not know
Anyway hope your right, cause there are no tire shavers around here i'm quite sure... and no way i want to pay for 4 more unless i'm more than 50% sure i should
Old 11-27-2013, 12:01 PM   #8
Garandman
Member#: 101117
2009 WRX, 06 OBW 3.0
Tiger 1050, WR250R, TW200
I just punched a hole in the sidewall of a Conti EC DW. Didn't have a tread depth gauge with me but it's still showing the "DW". I'm trying to decide whether to replace the one, or buy a second new tire and put them both on the front. Because there is more weight there I'm thinking they will wear down pretty fast.
Sidewall puncture FTL.
No rush since I just put the snow tires on.
Garandman is offline   Reply With Quote
Old 11-28-2013, 01:38 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
id take this opportunity to get rid of those horrible asx tires
Old 11-28-2013, 10:57 AM   #10
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Scotty, those are the DW, not the DWS.
I think it's a pretty good "civilized" performance tire.
The best way to know is to measure them. The Tire Rack can shave a new one down to exactly match the others. It looks like there is lots of meat left, so I doubt they would have to shave much.
You don't want a big discrepancy from side to side OR front to back.
I use the DW as my winter tires. Awesome rain tire.
Bikelok is online now   Reply With Quote
Old 11-28-2013, 12:39 PM   #11
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
Get a tread depth gauge. Call Tire Rack and order one tire and have them shave it to match the other 3.
MD04WRX is offline   Reply With Quote
Old 11-28-2013, 12:50 PM   #12
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Subaru recommends a difference of no greater than 2/32".
Replace the axle-set (two tires).
Old 11-28-2013, 04:06 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
now...where did you come up with anything other than asx???
Old 11-28-2013, 04:16 PM   #14
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Doh!!! You are correct sir. My brain is a bit scrambled.
Happy Thanksgiving.
Old 11-28-2013, 09:01 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
Happy Thanksgiving.
happy thanksg00bling day to you to
Old 11-28-2013, 11:33 PM   #16
Garandman
Member#: 101117
The Tire Rack can shave a new one down to exactly match the others. .
Ah I was wondering if they could shave them or I had to find a local shop.
I couldn't find my calipers or a depth gauge, I'll get around to it. Put the snows on today anyway so I have to March.
Old 12-18-2015, 11:48 AM   #17
JBull
Member#: 295188
2008 Impreza WRX
Mica Blue
So if I am at 6/32 and the new tire is at 10/32, I should at least replace 2 tires that would be on the same axle? What (if any) effect does this have on the center diff?
JBull is offline   Reply With Quote
Old 12-18-2015, 12:05 PM   #18
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Replace all or have the tire that needs replacement shaved down to the proper 32nd by the tire rack.
Excess heat and damage. Shaving a tire or replacing a set is alot better than a trans, center diff or rear diff down the road.
Blingstrom is offline   Reply With Quote
Replace one tire or all four? less than 10k miles chris_photo Tire & Wheel 6 03-19-2009 09:36 PM
Replacing One Tire (clarification) xrw1 Tire & Wheel 2 12-31-2008 08:47 AM
replacing one tire? vinithing Tire & Wheel 13 04-06-2007 02:47 PM
got a lfat, is it safe to replace one tire? chrismindless Tire & Wheel 3 10-10-2005 10:35 PM
Replacing one tire? Gilla-Machster Tire & Wheel 0 04-07-2005 05:52 PM
