Old 03-06-2007, 10:44 PM   #1
redrexmeister
Member#: 111692
04 wrx wagon
Default DieHard Gold weight?
it looks like it's time for a new battery. Consider buying DHG, I hear its weight is comparable to that of stock battery, so it should be around 31lbs.
Can someone post exact weight for DHG?
redrexmeister is offline   Reply With Quote
Old 03-06-2007, 11:10 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Found with a quick search on sears.com-
http://www.sears.com/sr/javasr/produ...cemldffidfki.0
Specs say 39 lbs., it's a porker.
Optima Group 35 Red Top is 33 lbs.
Old 03-07-2007, 12:43 AM   #3
redrexmeister
Member#: 111692
04 wrx wagon
thank you Sir. I'll probably get Optima redtop unless I will convince myself to get somewhat lighter Baker or Miata battery.
Old 03-07-2007, 06:45 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Best to avoid a lightweight unless you really need the weight reduction for competition. IMO not worth the tradeoff in cranking and reserve capacity for those few lbs. on a street-driven car especially since you're in NJ where it gets cold.
I've had my Red Top in the car for almost 5 years now and it's still doing great. No problems starting with the current cold snap.
Old 03-08-2007, 09:47 AM   #5
Scoobypup
Member#: 17148
2004 WRX Sedan
I have the DHG that I just got to replace my crappy stock battery. It is a bit heavier than stock and the Red Tops as well. I'm not too concerned about a few pounds as I really need the CCA's that this thing has for the -30 ish winter days I get here. Plus it's a good deal cheaper than a Red Top.
Does a few pounds in the front really matter anyway? I mean, how much difference does a half tank of gas in the rear make? Exactly, so just keep the tank always full and it'll help offset the extra weight upfront.
You'll also have a few extra presidents leftover for some other mod/upgrade as well.
Scoobypup is offline   Reply With Quote
WTB: 18x9.5 +40 SSR Type-F Touring Gold Trigg Private 'Wanted' Classifieds 0 06-03-2010 11:41 AM
FS: 12x1.5 Light Weight Racing Lug Nuts w/ locks in Gold. BEAUTIFULL Gami004pilot Wheels/Tires 0 06-19-2009 05:23 PM
Weight of 98 gold wheels? MichiganRS Brakes, Steering & Suspension 2 01-11-2001 10:39 PM
