Old 03-07-2007, 01:30 AM   #1
spdracr00
Member#: 65823
1996 Impreza L
Red
Default stock 97 LGT front swaybar bushing
i'd like to keep my stock front sway, but my bushings are shot. no one makes a poly replacement for the leggy.. but i'm wondering if the front bar is the same as maybe whats found on an impreza? anyone point me in the right direction?
thanks!
spdracr00 is offline   Reply With Quote
Old 03-07-2007, 02:31 AM   #2
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Whiteline makes them.
W0405-20
jamal is online now   Reply With Quote
Old 03-07-2007, 02:32 AM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
edit not reply
Old 03-08-2007, 02:28 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Unless Whiteline has changed things, their design is not the correct bushing type for the USDM Legacy. When I ordered bushings from them in the past what I got was a "normal" flat bushing, but the Legacy's front bushings are humped like so:
I "upgraded" to a 20mm Whiteline bar, and the bushings that came with it were also incorrect. I then discovered that the WRX uses the same funny front bushings, and since the OEM WRX front bar is 20mm I picked up a set of WRX bushings from Energy Suspension.
Of course, I'm not even sure the Whiteline bar was an upgrade, as I think the stock front bar may have been 20mm, too. I'm really not sure.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 03-08-2007, 04:53 AM   #5
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Pat Olsen
Yeah, I recently bought a GT bar.
The Whiteline bushing there is 20mm and is the same size as the stock gt bar. And yeah, Whiteline's catalog is definitely wrong. I'm pretty sure the W0405- series is the right shape.
Old 03-08-2007, 07:28 AM   #6
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Yeah the W0405 is definitely the crinkly bushing - and it is the same as on the new age Imprezas
So for that matter if the OP wanted to go cheap, he could pick up a takeoff pair of OEM Impreza rubber ones which are also 20mm stock
UkNuck is offline   Reply With Quote
Old 03-08-2007, 09:23 AM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I can confirm - W0405 is the version that you want.
Here's the package showing the bushings and the part number for proof:
Old 03-08-2007, 07:44 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I'm not sure why I bought the 20mm bar thinking it was an upgrade. I think at the time I thought the stock bar was 18mm, and then afterwards figured out it was 20mm. Ah well... I guess it is an upgrade in that it's pretty blue.
Pat
Old 03-08-2007, 09:25 PM   #9
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Pat
It might be very slightly stiffer. The coating on the GT bar is pretty thick.
97 LGT front cat replacement? boosted02suby Legacy Forum 2 02-01-2009 01:09 PM
front swaybar bushing bracket bolt stripped.. caesar Brakes, Steering & Suspension 3 08-26-2006 12:44 PM
front swaybar bushings gummy Brakes, Steering & Suspension 1 07-19-2006 06:10 PM
FS 97 LGT Front bumper plus Fogs PumpsGOTAWD Legacy Forum 14 05-13-2006 06:39 PM
***FREE*** Whiteline urethane 22mm WRX front swaybar bushings 992.5RS Private 'For Sale' Classifieds 6 09-02-2005 12:32 AM
