Old 12-05-2001, 09:25 PM   #1
Niloc
Member#: 3296
99 2016 STI
Default What does a clutch slip sound/feel like?
I was driving to day & I herd a weird rattle sound on deceleration. So I was driving around doing different things to try to recreate it. I didnít come up with anything but it only seams to do it in the low RPM range. Well anyway, I was pulling into a parking lot so I downshifted from 3rd to 2nt & when I released the clutch Kaboom! Felt like I hit a pothole the car did not stall just the loud nose & an abrupt shimmer. Then the car drove fine; I could not recreate eater the rattle or the kaboom thing. Any Ideas, Clutch, tyranny (god I hope not)?
thank's;
Niloc
Niloc is offline   Reply With Quote
Old 12-06-2001, 01:32 AM   #2
DustinR
Member#: 8264
2001 Impreza 2.5 RS
95 Impreza 1.8 Coupe
as far as the rattle goes i don't know but the downshift sounds like u dropped the clutch with slack in the drive train. Give it a little slip before u let it up to take out the slack and that won't happen.
As far as a slipping clutch. Well mine went last week and basically what would happen is in any gear i would start out in the low rpm range. Floor it. and it would seem to go fine until about 4k then the needle would jump to about 5.5k. That, the dealer told me, was a bad clutch due to a failed pressue plate.
To me what your saying dosn't sound like a slipping clutch.
Hope this helped but it is all from my limited experience so if im wrong someone please correct me.
-Dustin
DustinR is offline   Reply With Quote
Old 12-06-2001, 02:15 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Sometimes our AWD system will make a kaboom when activated. you might have not had the RPM's meshed very good and it shockloaded the car and one set of wheels started to lock and the center diff kicked in.
Slippage is easy to tell. It will usually start in 4th or 5th gear at WOT and your rpm's will raise fast but you will not gain much speed. no noises usually associated with it but you can smell your clutch
Eric
Eric SS is online now   Reply With Quote
Old 12-06-2001, 03:26 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
yeah if you spun the clutch the car woulda just started to coast....and on acceleration it'll normally justs over-rev and bounce off the limiter until you realize the disk is burning.
Jeremy
Old 12-06-2001, 11:58 AM   #5
Niloc
Member#: 3296
99 2016 STI
Thank's big help at least now I know it's not the clutch only have prob at lo speed/ lo rpm. I'll see if it does it agan today.
Old 12-07-2001, 12:58 AM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
The rattling might possibly be your thow-out bearing.
Drac9 is offline   Reply With Quote
Old 12-09-2001, 11:47 AM   #7
PIlo101
Member#: 6640
'11 WRX 5dr LTD
This might sound dumb, but are you manifold heat-sheilds rattling...you'll hear it slight on acceleration, but you'll hear it a lot on deceleration. My legacy did it before I ripped it off, now my RS is...my 2 cents.
PIlo101 is offline   Reply With Quote
Old 12-09-2001, 01:37 PM   #8
nomorefocus
Member#: 9677
2002 2.5 RS
Hey all. I think my clutch is slipping. But I notice it when I shift gears under hard acceleration, especially into 2nd. I shift, let out on the clutch and floor it and the rpm's go up, but I don't go anywhere then it lurches forward. It almost feels like clutch isn't engaged even the clutch is in the up position.. Should I have my dealer look at it? I only have 4000 miles on my car.
nomorefocus is offline   Reply With Quote
What does a Misfire sound/feel like? SubaruImpreza_power Newbies & FAQs 11 01-25-2004 12:04 AM
What does timing belt noise sound like? 98legacy Service & Maintenance 6 01-13-2003 06:29 AM
What does Knock or Ping sound like?? joltdudeuc Normally Aspirated Powertrain 4 05-28-2002 05:51 PM
What does an exhaust leak sound like? protouring72 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-28-2002 12:09 AM
What does detonation or ping sound like? illmatic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-28-2001 09:52 PM
