Old 03-09-2007, 12:03 AM   #1
Enchantor
Member#: 142137
2006 Impreza WRX STi
Default Where to find an on/off rocker switch that will fit in the switch bay on the STi ????
I'm installing a couple things and am planning on putting an on/off illuminated rocker switch in. I want to put it in the little switch bay in one of the empty slots by the I/C Spray button.
Where would I find a switch or button that would drop in that slot? I'd like for a exact fit so it doesn't look tacky. Any suggestions?
Enchantor is offline   Reply With Quote
Old 03-09-2007, 02:36 AM   #2
Enchantor
Member#: 142137
Someone? Need a switch that will drop in there!!! Or maybe I could order an extra IC Spray button and just paint over the lettering on it.... ideas?
Old 03-09-2007, 09:11 AM   #3
Mechie3
Member#: 120152
digikey.com has electrical components. You can cut your own slot and drop a switch in. They do have a minimum order value though or they add on like...10 bucks.
Mechie3 is offline   Reply With Quote
Old 03-09-2007, 09:18 AM   #4
LastResort
Member#: 99289
See if the fog switch works for what you want.
LastResort is offline   Reply With Quote
Old 03-09-2007, 10:41 AM   #5
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
I found LOTS of switches that fit in the local junkyard. It's a pretty standard size, just go to any U-Pull it type place and for a couple of bucks you can get what you want - though it may have some symbol that is not relevant to the function you are using it for.
Alan is offline   Reply With Quote
Old 03-09-2007, 10:43 AM   #6
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
^^^ good idea
You can just pop out one of the blanks and carefully slot it to fit a regular rocker switch - your main prob is going to be getting the illumination to work right with Subaru's funky switched ground system
UkNuck is offline   Reply With Quote
Old 03-09-2007, 02:25 PM   #7
Enchantor
Member#: 142137
Good suggestions thanks. I'll have to look into it!
Where to find an STi wiring loom? adofly Electrical & Lighting 0 01-23-2008 12:42 PM
Where to find an OEM 2005 STi trunk badge? kangaroo128 Interior & Exterior Modification 5 07-22-2007 09:58 PM
where to find an sti license cover? spoolnSTi Interior & Exterior Modification 1 10-22-2006 02:41 PM
Whats the biggest size gauges that will fit in the OEM dash pod? mjd85la Electrical & Lighting 1 01-31-2006 08:34 PM
Where to find an Oil Press. Fitting nu2rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-05-2003 11:31 PM
