Old 12-05-2001, 11:30 PM   #1
WFO
Member#: 13041
2002 WRX Wagon
Default What type of oil filter and oil for the WRX
What brand of Oil and oil filter are you using? I've read the users manual, just wondering what brand of filter and oil. Just curious. I only have 400 miles on the wrx wagon and will be buying oil and filter soon.
thanks........
WFO is offline   Reply With Quote
Old 12-06-2001, 12:16 AM   #2
wolf8314
Member#: 9185
2012 Toyota Tundra
Default I use
Fram X2 oil filters and quaker state 10w 40. Has always worked for me. One of the mechanics at my dealership said to use puralator oil filters. Then a salesman said he used subaru oil filters.......ive used fram in all my cars and never had a problem.
Wolf
wolf8314 is offline   Reply With Quote
Old 12-06-2001, 12:56 AM   #3
industrial
Member#: 7250
2017 WRX
I'm fairly new to Subaru ownership but I've done alot of "research" on the subject and this is what I do:
Get real subaru filters from your dealer or subaruparts.com. I hear they are of decent quality, purator brand or something like that. They only cost around $5 each with a new plug gasket included. Buy the cheapest oil you can find(that will match the weather where you are from) with the certifing starburst on it and change your oil every 3000 miles. Change your oil filter at factory recommended oil change intervals(every 7500 miles after the first few changes).
I don't buy the hype about synthetics and all that jazz. It's alot better to change cheap dino oil every 3000 than to use expensive synthetics and change every 7500-15000 like some guys do.
Regards,
Bernard
industrial is offline   Reply With Quote
Old 12-06-2001, 01:14 AM   #4
topcover
Member#: 8999
2002 EJ25 FXT Wagon
Platinum Silver, Stage2
Welcome to the board!
Do a search on the threads... this topic has been discussed to death in the greatest detail. Check it out.
Good luck...
topcover is offline   Reply With Quote
Old 12-06-2001, 01:33 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
That's funny. I suppose you put the cheapest gas (read: Arco) in the car too? And when you wash it do you use dish soap? How about when you go to find medical services? Do you cruise down to Mexico to find some back-yard doctor to work on you?
The way I look at it is this: cheap=bare minimum to get the label. Why not get something a little bit better. Or a lot better.
And why bother changing the oil if you aren't going to change the filter at the same time? You change the oil at 3000 miles, again at 6000 miles, then change the filter 1500 miles later, then another 1500 miles to change the oil, then 3000 miles, then change them both after another 3000 miles? That makes no sense at all.
Change your filter every time you change the oil.
Pros of synthetic:
supposedly increased fuel economy + power
supposedly better for the environment
lubricates better (allowing longer intervals)
may make engine last longer under harder abuse
Cons of synthetic:
price.
I've got an RS and I use Mobil 1 + Purolator PureOne PL14460
It's my choice.
CosmoTheCat is offline   Reply With Quote
Old 12-06-2001, 08:00 AM   #6
Martin Ritchie
Member#: 6771
2002 WRX WagonSilver
04 WRX Sedan Red
I agree with horatio. Yes, you should always change your filter when you change the oil, otherwise the dirty oil in the filter mixes with the new oil. If it makes you feel better to change oil more frequently than manual calls for (or if you drive really hard, autox, etc) fine, otherwise it is safe to follow the manual. Personally I use Mobil-1 5w-30 synthetic. I don't use Mobil-1 filter. Subaru OEM filter is a Purolator, I believe PL 14460 is equivalent. Bosch 3310 evidently fits too.l
Martin Ritchie is offline   Reply With Quote
Old 12-06-2001, 09:14 AM   #7
4Runner
Member#: 11096
I use FRAM X2 and Mobil-1 5w-30. I had been driving for over 20 years now and think that it money well spend on synthetic oil. I change my oil every 3000-5000 miles or when it looks dirty.
This is my first use of FRAM oil filter. After 2000 miles, oil still looks clean.
4Runner is offline   Reply With Quote
Old 12-06-2001, 10:33 AM   #8
WRXDAN
Member#: 10224
Try Mobil1 10w-30 FFV, it is a special flexible fuel version of mobil 1 that has no viscosity improvers at all, and only available in California. As for filters, I recommed the purolator pure one part #PL14460
WRXDAN is offline   Reply With Quote
Old 12-06-2001, 10:42 AM   #9
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
Filter: I buy an OEM filter from my local Subaru dealership for $5.
Oil: I buy Mobil 1 Tr-Synthetic Formula 10W-30 motor oil.
I change both the filter and oil every 3,000 miles.
One word of advice: when I changed my oil and filter for the first time, the filter was on so tight, I thought it would never come off. Although it did come free after 30-minutes of work, one suggestion posted on i-clib was to ram a screwdriver into the side of the filter to aid removal. Its most likely a vacuum issue rather than having been fitted too tightly, but ramming a screwdriver through the side sure beats lying on the ground for 30 minutes. IMHO.
Cheers!
David
Bradus is offline   Reply With Quote
Old 12-06-2001, 10:45 AM   #10
Julian
Member#: 1182
MY00 RS
BRP
Purolator is the OEM for Subaru filters. If you can find a parts store that stocks them, that's what I'd suggest. $3-4 per filter (PN 14460).
As far as the cheapest oil with the certifying starburst on it compared to more spendy oil...I agree with Industrial. All oils have to meet certain requirements to get the burst logo...what's better about Castrol? Maybe they charge that much more for their Marketing Department?? And yeah, I run Arco gas, or USA gas here in SoCal. Until there's proof of some benefit/return on investment for the spendier stuff, why bother?
It all has to meet the same requirements.
Julian is offline   Reply With Quote
Old 12-06-2001, 11:00 AM   #11
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Default subaruparts.com
Just received my order of oil filters from www.subaruparts.com. From the main page, click on the "Catalog" link, then "Subaru Parts", then "Tune-Up Section", then "Impreza", then "Tune-Up Items", where you will find the "Oil Filter Kit" for $4.62. This includes the oil filter and the drain plug washer. You will probably want to order a few of them at once to save on shipping charges ($6.95 for the 6 I ordered). It took about a week for the order to arrive. I plan to do the oil change this weekend, but I'm very confident that this is the proper filter, it's the Subaru OEM filter made by Purolator.
TheWRX is offline   Reply With Quote
Old 12-06-2001, 11:13 AM   #12
WFO
Member#: 13041
2002 WRX Wagon
Thanks for all the reply's, I appreciate the info!!
WFO
Old 12-06-2001, 12:00 PM   #13
industrial
Member#: 7250
2017 WRX
Ummm...yes I put the cheapest gas I can find in my car that meets the minimal requirements (i.e. 91 octane). Usually that's Arco, sometimes it's Moblie. What the heck do you do? Look for the most expensive price? Do you actually pay the extra ~3-7 cents a gallon for cleaning additives in Shell/Texaco gas? 91 octane gas is 91 octane gas. R/M method.
Why would I use dish soap? Your talking about using expensive oil: $8/quart, 4.8quarts/change = $40/3000miles. Buying nice car wash soap is like $9 and it'll last me about 40 weeks.
"How about when you go to find medical services? Do you cruise down to Mexico to find some back-yard doctor to work on you?"
Regardless, WFO: I suggest you do some research on your own before you blindly put $32/3000miles extra in to the oil companies pockets. Consumer reports had an excellent write up on oil and synthetics. Search the web and you shall find.
Regards,
Bernard
Old 12-06-2001, 12:16 PM   #14
4Runner
Member#: 11096
How can they do that in the US of A? I paid 2.97/quart for Mobil-1 at Target or Wal-Mart.
Old 12-06-2001, 01:51 PM   #15
industrial
Member#: 7250
2017 WRX
Just using extremes. Try pricing some Amsoil or Royal purple. If our cars are good enough for Moblie-1 why not go Amsoil 0W-30 uber synthetic oil?
BTW: $3/quart for Moblie-1 is a nice price. Wal-mart and target around here charge anywhere from $5-7 per quart depending on how much you buy.
Regards,
Bernard
Old 12-06-2001, 02:49 PM   #16
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Let me remind you that you have a high performance turbocharged vehicle. A turbocharger can spin in excess of 10,000 rpm and generate a tremendous amount of heat under full boost. Use cheap dino oil and you'll be coking up your turbo. Synthetic oil can withstand the extreme heat better than dino oil and doesn't break down as easily. The flash point of dino oil is between 400F and 415F. On the other hand, the flash point of synthetic oil is at least 445F. But hey, it's your turbo, so you can use whatever cheap dino oil you want with it.
Richard
Richard L. is offline   Reply With Quote
Old 12-06-2001, 02:59 PM   #17
CosmoTheCat
Member#: 3409
98 My FMIC
The price difference between Mobil 1 and Castrol GTX over 100k miles is only about $20 total. That's figuring 5k intervals for the synthetic and 3k intervals for the dino. If you go out to 7k miles then you're spending about $130 LESS with the synthetic. If you use 89 cent/quart oil then you're only spending $80 more. Is it worth $80, knowing that you're using the cheapest stuff out there?
Old 12-06-2001, 03:51 PM   #18
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
And you will not find cheap dino oil being used in a Dodge Viper, a Mercedes, a Chevrolet Corvette Z06, or a Porsche 911 Carrera. None of these cars even has a turbo.
Richard
Old 12-06-2001, 10:40 PM   #19
industrial
Member#: 7250
2017 WRX
http://www.xs11.com/stories/croil96.shtml
http://www.bmcno.org/techtip_motor_oil.htm
http://63.166.240.165/ldgautomotive/newsoil.htm
Lots of reading there. It's amazing how hard it is to find good information about oil that doesn't have some kind of oil company connection. I tend to trust CR more than most other sources but I concede that most New York cabbies don't drive turbo-charged/high compression vehicles. Anyhow, as long as you change out your oil with at least certified oil at the factory interval you should be ok. If you auto-cross or drive your car hard, change more often or use synthetic AND change more often. Your choice.
I've read that even though the base oil in synthetic oil is nearly indestructable, it's the additives that wear out(just as fast as dino oil). I've heard/read numbers ranging from 3800 miles - 5000 miles for additive life in various engines. If anyone can point me to some good independant research I'm open to it.
100,000miles
34 Changes / every 3000
Generic Oil = $146
Name Brand Oil = $326
Mobile-1 = $816
Amsoil = $1305
20 Changes / every 5000
Generic Oil = $86
Name Brand Oil = $192
Mobile-1 = $480
Amsoil = $768
14 Changes / every 7500
Generic Oil = $60
Name Brand Oil = $134
Mobile-1 = $336
Amsoil = $537
Generic Certified Dino Oil = $.90/quart
Name Brand Dino Oil = $2/quart
Mobile-1 = $5/quart
Amsoil 0W-30 = $8/quart
WRX Oil Capacity = 4.8 quarts
Regards,
Bernard
Old 12-07-2001, 02:25 AM   #20
CosmoTheCat
Member#: 3409
98 My FMIC
Even the expensive synthetics (typically, $3 or $4 a quart) worked no better than conventional motor oils in our taxi tests, but they're worth considering for extreme driving conditions high ambient temperatures and high engine load or very cold temperatures
I consider my driving to be more extreme than a New York cab. Why? Because they drive around, stop and go (more like crawl), here, there, everywhere. The only time those cabs rest is when they're getting gas and service. The oil barely ever has time to seep back down into the oil pan. My daily commute consists of jumping in the car, driving the .6-.8 mile to the freeway, going another 1.5-2 miles on the freeway, then another .8-1 mile to the school parking garage. The car barely has enough time to completely warm up. Then I shut it down for two hours, jump in the car, and race back home. If there isn't heavy traffic on the freeway, I'm usually on the gas.
And the chart at the bottom of the CR page noted that the synthetics had better low-temp flow characteristics. That is actually a good thing. I think your numbers were a little on the high side, but maybe it's just the .6Q difference between the 2.0 and 2.5.
Old 12-07-2001, 02:27 AM   #21
CosmoTheCat
Member#: 3409
98 My FMIC
Oh. I wanted to clarify something so those who don't read between the lines are kept up to speed.
In the quote above it was noted that the synthetics didn't seem to make a difference. Here's my arguement: If the vehicles had been allowed to cool overnight, or for several hours between short trips, there may have been more noticeable differences between the dino and synthetic results. Maybe, maybe not.
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! Unabomber Service & Maintenance 1061 10-22-2015 10:38 PM
what type of fuel line is connected to 03 wrx fuel filter? Lordhowe Newbies & FAQs 0 01-10-2009 08:50 AM
Anyone know the type of thread, count and pitch for an STi stick? bduly Transmission (AT/MT) & Driveline 5 01-28-2005 02:06 PM
what type of relay do i need for the fog lights? macroman Legacy Forum 0 09-04-2004 12:51 PM
What type of inline fuse to use for Sony MP3 deck and wacky wiring? remarcable Car Audio, Video & Security 4 08-23-2001 10:21 PM
