Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 03-10-2007, 12:33 AM   #1
wrx2k4blue
Member#: 59048
2005 Black S60R
w/ 18" Modas & Sport Body
Default My cruise control button no longer lights up
Probably just a coincidence, but back in November I replaced my gauge cluster with an STi gauge cluster and I noticed a few days later that my cruise control button does not light up anymore.
Is there an LED bulb to change? The cruise control feature works fine.
It doesn't really bother me (that's why it's taken me so long to post a thread about it) but it'd be nice to get it fixed. How would I go about popping off that button to have a look at the internals?
wrx2k4blue is offline   Reply With Quote
Old 03-10-2007, 09:48 AM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
http://forums.nasioc.com/forums/show...ostid=12840875
The whole button comes out the front, & is easly accessible by removing the lower trim piece.
2 screws down low, 1 pop-it on the side, & the top are clips that will pop out by pulling.
GLwagon is offline   Reply With Quote
Old 03-10-2007, 09:55 AM   #3
wrx2k4blue
Member#: 59048
2005 Black S60R
Wow, there is a whole thread dedicated to changing out the bulb? How often does this happen? And does it happen to the other buttons too (e.g. windshield wiper heater, foglight switch)
Old 03-10-2007, 10:22 AM   #4
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
I have an '02 & have had to change 1 lamp in my fog switch.
The real magic of this was someone found an inexpensive fix as opposed to going to the dealer & them scratching there heads.
The button lamps are an oddity compared to the cluster & HVAC.
If you can swap out a cluster you can change any of the other lamps when they burn out in 5-10years...
Old 03-10-2007, 10:36 AM   #5
wrx2k4blue
Member#: 59048
2005 Black S60R
Those instructions do look pretty easy and I'll probably visit Radioshack today to get a pair of those bulbs. The only thing is, I'm not liking the fact that they are shorter than the OEM bulbs and therefore not all of the letters will be as bright. I'm not sure why the OEM bulb isn't available everywhere, perhaps maybe it's a Japanese part?
Another question, are there two bulbs in the CC switch? In the pictures on that thread, it looks like there are two bulb housings. When you turn on CC, is there another light that lights up? It's been so long since I've used CC because I rarely drive on the highway
Old 03-10-2007, 02:08 PM   #6
wrx2k4blue
Member#: 59048
2005 Black S60R
Just got back from replacing the bulb. It was VERY easy. And because the Radioshack bulb is much shorter, I pulled the bulb out a little bit and double wrapped the wires around the socket. The wires are strong enough to prevent the bulb from dangling or coming loose
Thank you!
Old 03-14-2007, 10:31 AM   #7
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
just a note I had this happen on my 03 Forester.. I flicked at the switch a few times and go figure the light came back on :-/ been good so far about 3 weeks.
SubaruImpreza_power is offline   Reply With Quote
Old 03-14-2007, 10:50 AM   #8
wrx2k4blue
Member#: 59048
2005 Black S60R
Nice! When in doubt, hit it!
Old 03-14-2007, 02:11 PM   #9
rkramer
Member#: 118209
2015 WRX Limitec
both cruise and fog have 2 light bulbs each. one for on/off indicator, and one that comes on with the dash lights for backlighting.
Old 03-14-2007, 03:34 PM   #10
wrx2k4blue
Member#: 59048
2005 Black S60R
I only saw one bulb in the CC button. The foglamp button has two because when you turn on your foglights, another light appears on the button indicating that they are turned on. The CC button doesn't have this, but it has an indicator on the instrument cluster to let you know that CC is enabled. I don't believe the foglights have another light on the instrument cluster to let you know they are turned on
Old 03-14-2007, 06:07 PM   #11
rkramer
Member#: 118209
2015 WRX Limitec
depends on model/year i guess... my 02 wrx has 2 bulbs in each. there is no cruise indicator on the console.
A/C button no longer activates compressor. Ideas? lennyTR Off-Topic 57 06-13-2009 05:57 AM
No more Utec and I want my cruise control back. 03twrx UTEC 8 12-30-2008 10:42 PM
Fog Light/Cruise control Button Color change murph32 Electrical & Lighting 0 08-05-2008 01:06 AM
Cruise control button not lighting up... AK*WRX*2004 Electrical & Lighting 5 01-17-2006 02:55 AM
possible to bypass cruise control button? John #555 Electrical & Lighting 13 02-02-2003 01:27 AM
