Old 03-09-2007, 11:48 PM   #1
shaggadelic
Member#: 102475
Chapter/Region: HIIC
2001 impreza RS-T
white
Default Cleaning out the carbon build up in my exhaust.
I have searched, yet all i find is polishing the out side. i wanna know how to get all that junk out of the exhaust and pipe's. what is the best way of doing this. my exhaust has alot of miles on it since i got it 2nd hand so i think it's time to clean it inside out. please post up.
also i dunno if this is in the right section so mods you can move it if need be.
shaggadelic is offline   Reply With Quote
Old 03-11-2007, 12:40 PM   #2
azterik
Member#: 130725
2004 WRX
San Remo
if you have a dremel just go over it a couple of times w/ a pointed grinding stone and then a flap wheel if you don't want to port it. It helps to have the attachable extenstion so you can stick it all the way down your crossover pipe too. But should use an pneumatic die grinder if you plan on porting.
azterik is offline   Reply With Quote
Can A Wastegate Stay Partially Open Due To Exhaust Carbon Build Up??? Kahn23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 02-25-2010 10:29 PM
carbon build up at the exhaust tip Serkan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-25-2009 03:37 PM
The other WRX driver in my building seems to be warming up Asinine Off-Topic 25 04-18-2005 12:09 PM
Check out the spam I recieved in my regular inbox JMP73 Off-Topic 9 05-12-2004 09:03 AM
How to clean exhaust carbon build up? FryRice Newbies & FAQs 12 11-24-2003 10:32 PM
