Old 02-01-2013, 11:34 AM   #151
CalvinT
Member#: 329025
2002 WRX Wagon
The stock injectors for the WRX have enough headroom to handle a PnP on the stock turbo. IMHO not sure it makes much sense as it wouldn't buy you that much. You could get more replacing the catted up-pipe. You can keep the stock injectors with an aftermarket up-pipe but some say you should retune, others say you don't need to.
CalvinT is offline   Reply With Quote
Old 02-01-2013, 02:13 PM   #152
Maxwell Power
Member#: 190729
You aren't listening.
I said the injectors max out before the turbo. What that means is that the turbo can flow about 5-10 more hp than the injectors. That's PEAK flow capability. If you still have the stock up pipe or exhaust, you won't get peak flow capacity of the turbo. So porting it provides no gains as the limit isn't the turbo, it's the items flowing air in and out of the turbo and engine.
Maxwell Power is offline   Reply With Quote
Old 02-02-2013, 01:05 AM   #153
CalvinT
Member#: 329025
2002 WRX Wagon
Seems to me that would only be a factor if someone does a tune to increase boost over stock.
Old 02-02-2013, 01:59 PM   #154
Maxwell Power
Member#: 190729
dude WTF are you talking about?
Old 02-02-2013, 04:14 PM   #155
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
You don't need a retune for a port n polish on your turbo
So he's saying it would only be a factor if you
re tune ..... But even headers , up pipe And port n polish isn't enough to max out your stock injectors or turbo .....
ANR62NV is offline   Reply With Quote
Old 02-02-2013, 05:14 PM   #156
Maxwell Power
Member#: 190729
thanks I was getting real confused as to what "factor" he was talking about.
As a tuner, I cannot tell you how many times I've seen customers with PnP turbos, factory headers etc make LESS power than guys without it.
Do not port the factory header.
If you aren't getting a tune, why would you change anything? A lot of mods that are done to increase flow can actually result in lower power output as the ecu now sees more air. In the case of my tunes, I add safety features to protect against extra air that would be seen in the case of boost spikes or boost creep. Increasing airflow on some cars after they are tuned will result in lower power output until they are retuned.
PnP the factory turbo? Pointless IMHO.
Old 03-29-2013, 02:29 AM   #157
thehanz123
Member#: 318418
rally blue
I just bought a PnP TD04 for my 02 wrx 2.0... I have a 3 inch hks exhaust and will be getting uppipe and downpipe.
Also have atage 3 clutch and organic flywheel.
Dud i make a mistake in buying the ported turbo??
thehanz123 is offline   Reply With Quote
Old 03-29-2013, 07:30 AM   #158
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Your first mistake was that clutch as it is WAY too aggressive for that turbo....try reading my other FAQs first next time. You did not make a mistake with that turbo as they are WAY fun on a 2.0L....I have one for many years and still fondly recall it.
Old 03-29-2013, 08:02 AM   #159
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
I would try to refrain from using generic terms like stage 3 clutch. Its more helpful to know what brand and exactly what you bought. Bc it sounds like you have a pucked race disc but then you say organic flywheel. Which leads me to believe it might be a really strong pressure plate with organic disk.
Dmochowski is offline   Reply With Quote
Old 03-30-2013, 03:21 AM   #160
CalvinT
Member#: 329025
2002 WRX Wagon
That's good to know. I'm "improving" my 2002 WRX and have been contemplating which turbo. The stock TD04 is a lot of fun. Not so sure I want to give it up for high end power.
Old 03-30-2013, 08:58 AM   #161
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
Why not have the factory headers/exhaust manifolds ported?
2011WRXMT is offline   Reply With Quote
Old 03-30-2013, 09:22 AM   #162
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
he just posted it.
thisisntjared is offline   Reply With Quote
Old 04-27-2013, 06:27 PM   #163
silverstreak02
Member#: 316307
2002 Impreza WRX
My wrx is my DD, and I don't want to go crazy with it. Having said that, would it be more beneficial to purchase a lightly used TD04 and AP for a tune rather than upgrading to something larger? I take my car to the mountains on some weekends, but its mostly just to get to and from work/home.
Thanks guys
silverstreak02 is offline   Reply With Quote
Old 04-28-2013, 12:26 AM   #164
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You don't need to purchase a used one, use the one you gots.
Old 04-28-2013, 08:34 AM   #165
silverstreak02
Member#: 316307
2002 Impreza WRX
We discovered a tiny crack on the down pipe side inside the housing...with roughly 11 years and 180K is that going to hold up? Not being a doom and gloomer, just a little worried
Old 04-28-2013, 10:08 AM   #166
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Do you have VF-39? That is super common and no cause for worry. Its a common seen thing and only cosmetic.
Old 04-28-2013, 11:15 AM   #167
silverstreak02
Member#: 316307
2002 Impreza WRX
It's just a TD-04, I've been thinking of a VF39 upgrade, just more concerned with maintenance at the moment due to budget. Crack inside worried me, glad to hear its primarily cosmetic.
Old 04-28-2013, 12:14 PM   #168
silverstreak02
Member#: 316307
2002 Impreza WRX
Thanks for your FAQ's, btw. Extremely useful for guys like me looking to learn everything about mods without getting way over my head with technical info
Old 05-09-2013, 09:17 AM   #169
GC8TimeAttackNZ
Member#: 354633
1999 WRX
Just read the whole turbo FAQ. What a wealth of information. Definitely answered some questions I've had for a long time and gave me a headstart on my research for an eventual turbo upgrade.
GC8TimeAttackNZ is offline   Reply With Quote
Old 05-16-2013, 04:30 AM   #170
thehanz123
Member#: 318418
rally blue
Would i benifit alot from getting the usual supporting mods for bigger turbos, for my PnP stock Td04?
Old 05-16-2013, 08:00 AM   #171
quazimoto
Member#: 70395
A better intercooler would help along with a better fuel pump. Bigger injectors not so much.
quazimoto is online now   Reply With Quote
Old 05-16-2013, 10:27 AM   #172
thehanz123
Member#: 318418
rally blue
Thanks Quasimoto
- cmon feet..
Old 05-17-2013, 08:09 PM   #173
Maxwell Power
Member#: 190729
Thanks Quasimoto
- cmon feet..
you're the one asking the same question that has already been asked in this thread more than once!! Also.... a PNP TDO4? Reallly? What the hell do people think porting a turbo is going to do for you? Almost nothing.
Old 06-13-2013, 12:33 PM   #174
Lord Quas
Member#: 352972
02 Bugeye
Rally Blue
To me a PnP turbo sounds like a good idea. The more airflow the better right
Lord Quas is offline   Reply With Quote
Old 06-13-2013, 01:47 PM   #175
Masta Splint
Member#: 189211
2005 18g WRX wagon
Love these info threads! Thanks for the info!
Masta Splint is offline   Reply With Quote
Differential FAQ: Read if you are thinking of upgrading! Unabomber Transmission (AT/MT) & Driveline 139 04-23-2016 01:04 PM
Transmission FAQ: Read if you are thinking of upgrading! Unabomber Transmission (AT/MT) & Driveline 217 04-10-2016 05:06 PM
Injector, Fuel Pump, and Fuel Rail FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 158 07-13-2015 03:19 PM
Turbo Timer FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 88 02-02-2015 10:10 PM
Turbo FAQ: Read if you are thinking of upgrading! Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 70 06-19-2006 04:37 PM
