Old 03-10-2007, 03:19 PM   #1
mumbles-wrx
Member#: 139168
Default 05 WRX Stage 2 Car w/ stage 2 map loaded, only 11psi max
could someone please give me some insight as to what could be wrong with my car... i have an 05 wrx stage 2, uppipe,downback all that jazz and spt short ram intake... I have loaded cobb's stage 2 map and there is no difference in power from my stock map and with the stage 2 map loaded i'm only hitting 11 maybe 11.2 pounds of boost.... something is wrong.. please help..
Jason
mumbles-wrx is offline   Reply With Quote
Old 03-10-2007, 11:09 PM   #2
awdG35killer
Member#: 75698
2013 Legacy 2.5i
RMK #2 !!!
11psi in ALL gears?
awdG35killer is offline   Reply With Quote
Old 03-14-2007, 10:10 PM   #3
2QuickZ's
Member#: 92786
2005 Saab 9-2X Aero
I'm having similar problems. I'm an 05 9-2X bought new. Added up, dp, IC hoses, 1 turn on the wastegate and AP v1 stage 2 93 oct tune (stage 1 91 oct base map). Everything was done a long time ago and it was boosting to 14.5 psi which is still low. I replaced the IC hoses and found the bolts to the IC had loosened and was presumably leaking and thought I figured the problem out. I never rechecked boost but it felt stronger. Lately it has been feeling slower so I checked boost again today and I'm hitting 12 psi in 1st, 13 psi in 2nd and 14 psi in 3&4. I don't hear any vacuum leaks nor does it sound like the uppipe is leaking. I'm kind of at a loss. I guess my troubleshooting plan, in order, is as follows:
- double check all IC and vacuum lines (especially IC)
- Upload stage 2 93 oct. base map
- Upload stage 2 93 oct. HWG real time map
- Add another turn to the wastegate arm
Before I update the base map and turn the wastegate arm, should I reset the ECU back to stock or reset it? Also, if none of the above works, what should I look at next?
mumbles-wrx - I don't meant to hijack your post but I figure it is possible we are having the same problem so I thought I'd post in your thread rather than creating my own.
2QuickZ's is offline   Reply With Quote
Old 03-15-2007, 12:13 AM   #4
hondaeater69
Member#: 60324
OP sounds like lack of restrictor pill/pill in the wrong place.
Old 03-15-2007, 12:39 AM   #5
Bbasso
Member#: 66235
2005 WRX
Adjusted the WG arm?
Bbasso is offline   Reply With Quote
Old 03-15-2007, 12:51 AM   #6
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
when you plug the ap in does it say you are running stage 2? check it.
gingertooth is offline   Reply With Quote
Old 03-15-2007, 12:06 PM   #7
tex_wrex
Member#: 132971
2011 STI
was that boost reading from a boost guage or the accessport? i thought i had the same problem until i realized that my boost guage was 5 psi off...
tex_wrex is offline   Reply With Quote
Old 03-15-2007, 02:58 PM   #8
2QuickZ's
Member#: 92786
2005 Saab 9-2X Aero
I was reading boost off the accessport. I don't have a gauge. I checked the vacuum line with the pill in it yesterday and the line appears fine and the pill is there. I didn't pull anything apart to check internally but I'm the original owner of the car and I didn't change it so unless something happened when I had the intercooler off it should be in the same position it was in when I got the car. I do have one full turn of adjustment on the wastegate arm. I may turn it another turn or two tonight and see what it does since it only takes a couple of minutes.
As for my accessport, I have one of the older style ones that will only show you what base map is installed. It won't show me the real time map.
Old 03-17-2007, 01:34 PM   #9
WeldingHank
Member#: 98645
2002 WRX Wagon
When I started tuning my own car, I found to hit target pressures I had to put almost 3 turns on my wastegate arm to make any difference. I would turn it 2 turns at a time till you over boost, then back it off 1/2 to 1 turn. wherever you like most.
WeldingHank is offline   Reply With Quote
Old 03-17-2007, 10:46 PM   #10
2QuickZ's
Member#: 92786
2005 Saab 9-2X Aero
I finally played around with mine today. The only thing I did was turn the wastegate arm another 2 full (360*) turns. That seemed to cure my ills. I'm now hitting 13.5 psi in first, 15+ in second and low 16's in third and fourth. And that is on a nice, cold 25* day. I'd say I'm good now.
Old 03-17-2007, 11:02 PM   #11
eggeegg
Member#: 118769
2006 WRX Sedan
Aspen White, XPT Stage 2
just some nobody blames the intake later, i also have an SPT CAI and running stage2 (osecuroms.org) fine. i didn't mess with my wastegate arm.
eggeegg is offline   Reply With Quote
So Cal: 05 WRX 5spd Swap car EvilRB Private Vehicle 'For Sale' Classifieds 24 05-22-2010 01:44 PM
05 wrx wagon complete car cheap surfwalden Private Vehicle 'For Sale' Classifieds 40 06-08-2009 07:05 PM
fs: 05 wrx tampa florida car ej20dett Private Vehicle 'For Sale' Classifieds 1 03-14-2007 10:42 AM
PA: 05 WRX Accessport, Helix DP, Greddy EVO 2 Rwu00313 Private 'For Sale' Classifieds 7 01-06-2006 11:52 AM
